- Replies 36
- Views 3.9k
Doubletrouble 12 posts
JAG1 9 posts
Tractorman 4 posts
wil440 4 posts
All very good information to take into consideration both when changing filters and when dealing with a freeze issue. I will keep this info stored away in my memory banks (sometimes they freeze
Can you imagine an upside down picture of @wil440with pins in his eyes!? Here is something that will help build trust in the government. Not. In the mid '90's, my wife and I moved from
The filter housing and LP are in the stock locations. I belive the small factory line from the tank to the LP could be the issue. I may have gotten a little air in the filter housing when I remo
So, weather sucks. It's like 4°F here with wind chills of -25. Truck won't start. I though it was gelled up. Poured power service in the tank, went to pour some in the filter housing and the fuel in there is fine. I reinstalled the filter top. Still no start.
Put a fuel pressure test gauge on it and no fuel pressure.
truck was plugged in, ran fine before thos cold weather, plenty of fuel pressure before also.
Is it possible the lift pump froze?
