- Replies 18
- Views 1.9k
Mopar1973Man 6 posts
IBMobile 4 posts
Threadzy 3 posts
Max Tune 1 post
They must be making better trucks now, 'cause before they just shut down by themselves, even if you made payments. - John
Our truck are kinda like us. The older they get, the more little issues cause problems. Only positive in the truck aging scenario is we can do our own repairs. I try to tell the youth around me, ther
Next time I'm in a pic a part yard I'll try to acquire a used right rear tail lamp assembly wiring harness for you.
So you all seen my post about being pulled over twice for a failed driver-side tail light? I pulled the entire pigtail out and the bulbs and found a single wire that folded over and broke the wire but the jacket was undamaged. As I gave a small tug on the wire it separated completely. Sadly the wire itself was oxidized pretty badly. The break was within about 1/2 to 5/8 from the plug. I attempted to solder it back together and shrink tube the repair but the wire just refused to accept solder from being oxidized so badly. I opted to use a standard butt splice and seal the ends the best I could and then taped the repair over.
Then finally I was cleaning out the cab and found the door cam spring in my driver-side door pocket. I went to work to pry that spring back into position in the door. Sadly this is just a band-aid repair for now but I'm going to need to replace both door hinges soon being the pin bushing is shot for the most part.
Being the weather here was warm today I started doing my hinge lubing practice. I grabbed my small oil can and filled it with some 30-weight engine oil and hit all the door hinges, and door latches then moved to the hood and did the pivots on the hinges and the hood latch. Now everything shuts nice and smooth once again and doesn't require much to get a full latch on the doors. While I had the hood open I shot the battery terminals with engine oil as well.
On my trip back from Boise I had a popping noise start as @Honey Badger and I left. I shoved the truck into the shop and got Mark to help out and hunt down the popping noise which we thought was the steering box. I quickly pulled the steering box and open it up and didn't find any problems. Quickly reassembled and started rocking the wheel without the engine and popping started again. Come to find out the track bar on the ball stud was moving again. When I tighten it last I tighten as far as I could and ended up passing the hole for the cotter pin so a barely backed it off to hit the hole but that was the wrong move. I ended up laying a washer down to offset the pinhole on the castle nut. Torqued the heck out of that nut with a 1/2 breaker bar and was really close and struggled to just get a bit more out to line up. Nevertheless, I nailed it. The popping noise was fixed.
Yeah, I didn't do much for the website for the weekend. But I did get repairs done on Beast to keep it going legally on the highways and fix issues before they become big issues.
