Was my engine not getting worked hard enough?
- Replies 29
- Views 6k
LiveOak 5 posts
Mopar1973Man 4 posts
ISX 4 posts
flagmanruss 3 posts
So, I know that these trucks were not designed to just be making trips to the supermarket & back home every day, but I have a truck that basically has just been used as a daily driver all its life. The truck got used once to tow a trailer from Oregon to Alabama & that was the most work it has seen in its entire life.....Basically, right now, I am using the truck to drive back and forth to work every day.....The problem is that I live so close to my shop that most of the time the truck never even gets up to normal operating temperature from the time that its started till it is shut down.What I'm wondering is if this is bad for the engine over time to not get it up to normal running temps when it is driven a lot of the time. I've just recently been trying to get the truck out on the interstate two or three times a week & getting on it pretty good & getting rpm's up to work the engine some.....It seems to have helped in getting rid of a little ticking noise I could hear after the truck was warming up a little....Could this cause some problems that the engine doesn't get up to normal temps every time it is driven back & forth to work? I just know that these engines were designed to be worked a little to stay happy.....
