Going for a full build!
- Replies 52
- Views 11.7k
pepsi71ocean 14 posts
Dave3500 7 posts
Mopar1973Man 6 posts
JOHNFAK 6 posts
After much back and forth arguing i decided to do a full build, my new job assignment more or less requires a truck that is 4wd capable, reliable and gets great MPG.and as such my 99 is well suited minus the missing trans.The problem is the job is in Philly, which is nothing but traffic, mostly going home that is, i'll sit in traffic for the first hour of my drive, once i get out of the construction zone im all good and its highway speeds from there.After a failed attempt at a shift kit install, i sent the kit back to DTt with my VB, where they have been sitting for a few months.I decided to just get a built transmission, i decided on DTT since they already have the shift kit, and Stephan is a site sponsor, plus they are good people to deal with.the question is how do you guys think a fully built trans will handle the drive, plus towing i still tow, and there are opportunities to tow as well as i might buy my first toy hauler as well.I will be adding a Pac Brake on the truck down the road to aid in braking and in warm up.my other question is can a fully built trans handle towing in 4th gear? i used to tow in 4th on level ground with my stocker trans but that might have been part of the problem. i will not like when i say the Camper sticker said that the GVW was 13,900.Now i have hauled before way heavier stuff then this, i just want to know how the built trans will handle the constant double duty as a DD and a heavy hauler.I will be posting videos once this truck is all together again. i miss the sound of my truck
