Boost Elbow or J-Hook?
- Replies 23
- Views 11.1k
JOHNFAK 5 posts
fire176969 4 posts
pepsi71ocean 4 posts
jumpjg 2 posts
I recently picked up a Juice with Attitude 2nd hand. It came with everyting except the boost elbow. Not too sure what the elbow is supposed to do. I understand it is an orifice, but in a closed system that will only slow down flow, not limit pressure. I was figuring the concept was to keep the waste gate closed, allowing the boost pressure to rise. I was wondering if I could substitute a J-hook (local fab) for a boost elbow, or should I get a new part from Edge? If a J-Hook is adequate, why not remove the OEM elbow and plug the port in the compressor housing and the hose running to the actuator?Appreciate your time,Joe in St Louis
