White smoke under acceleration until warm
- Replies 29
- Views 14.1k
BugJEB34 10 posts
pepsi71ocean 5 posts
Mopar1973Man 3 posts
CUMMINSDIESELPWR 3 posts
I need some advice from someone smarter than myself on what may cause my issue. I am getting white smoke under acceleration until the truck gets to operating temp then it goes away completely and I can't make it smoke. No smoke whatsoever at idle just a puff of black just as it starts. I just recently replaced a head gasket so EVERYTHING has been taken off my truck recently and I'm not sure where to begin to start if I have a connection that may be fouled up. One thing I do need to do after reading some of Mopar's articles on injector and fuel line reinstalling after the change and I have realized I need to first take the tubes back out and clean the tips of them as well as tighten the fuel lines onto the tubes before I tighten the injector down to ensure I tight seal. That being said I do smell fuel when the truck is running and an near positive I am getting air intrusion, I just want to make sure while I have it all apart that I check anything that may need checked. Since the replacement of the head gasket I am getting no fluid mixing, no bubbles in the coolant, and no overheating issues, so I don't think its the head gasket again. I am going to re-torque while I have everything apart just as a precaution just to check, but like I said many of you know much more than I do, so while I'm working I want to make sure I check anything that could be problematic. Thanks in advance for any advice.Jason
