I know you all know I use my ScanGauge II for getting the most MPG's from my vehicles as in the other thread I kept going over here. So here is now the last few trips to McCall, ID now in my 2002 Dodge Cummins... :whistle:http://g.co/maps/ezxhe post-2-138698187789_thumb.jpg post-2-1386981878_thumb.jpg
  • Replies 115
  • Views 22.8k
I don't think its being dipped but not positive. I have had a few 10 minute warm ups on this tank but its never made this huge of a drop. Sent from my Amazon Kindle Fire using Tapatalk 2
In my prior post, the 19.6mpg tank, I had several 10 minute warm ups to get the ice melting off the windows!!! You and trucks don't get along it'd seem. You must have someone dipping you, or you've got a brake dragging or you're using tar as engine oil!!!! You did get rid of the Frankenstein shoes......didn't you??? I couldn't get that bad of mileage even if I tried to!!!!:ahhh::shrug:
nope, I've got no frankenshoes :)The 24V had a few issues. This one has given me problems since day one.My '96 was the best truck of all. I loved that thing. I sold it due to it being a single cab, and the 4 of us couldn't go anywhere in it together, unless we took two vehicles..
  • 4 weeks later...
Okay, my first MPG "report."This is going off of the odometer. (I don't have a GPS)~10.45 MPG.311 miles on ~29.75 gallons. A lot of 10 minute warm-ups, and driving a couple miles here and there, through pastures, etc, towing about 5K - 7K pounds. . . Only about 80 town/highway miles were driven with no load. . .I need a BHAF, and straight pipe. I haven't even done that yet. :wow::doh:NV4500, 3.55's, 215/85/16 road tires. . .
I got her out on the hwy this last weekend and went about 300 miles at 80mph and it killed my mpg. I had the topper on and my average was 16.4. I did have a few miles on that tank pulling the trailer but it was mostly a clutch break in tank and now the fun begins. I stumbled on a smarty cheap so I hope it will improve mpg after the new wears off.
My last one was 16.8 with a lot of warm ups. I usually get around 17-17.5 ever since my VP was damaged from 2 factory lift pumps going out 4 years ago. Before that I used to get 20-22 mpg
I talked with Michael about a week ago and he said to help mileage turn my Edge Comp all the way up. I kinda thouhgt he was crazy at first but I went to my girlfriends house on Sunday which is a 100 mile round trip. i was driving with the tailgate down and was showing 19.5 avg on the factory trip computer but I have bigger tires so I know that it is wrong, just not sure if it is better or worse than what it shows. Been looking at getting the SG2. Any ideas? Just ordered the BHAF to put on and hope that helps some with mileage.
I'm not sure I guess I've always driven around with the Edge Comp on 3x5. Are you talking about the economy display or are you hand calculating it? If you're talking about the economy display, you can't rely on those. They are almost always off.
Yea the overhead console said that. I went ahead and bought the SG2 today and put it. Did the same drive at same speed but had some wind against me and SG was showing 15. But I just put it in and idk if that has an effect or not
Just had the valves adjusted and got rid of my 100hp injectors for some 40hp ones. They are not the Bosch rv's, but they were built and tested by an injection shop in Oregon. Just did a trip this weekend and I'm pushing 22mpg's!! I was really excited because that's on my 35's with no tuner or foolers. It was a 540 mile trip on 25 gallons. Mixed city/highway.
Is that going off of the odometer, or GPS?
I was getting somewhere between 19-21 when I first bought bought my truck 120k miles ago. Now I am getting 14-16. I would like to know what I can do to get it back to where it was. I am running a comp as a ez. So I am going to try and tap the pump and see if I can get the mpg to come back up with that. I am also running 265/70/17 and and wieght of the tire and wheel is the same as the 265 that I was running before. I am lost at what I could do to help.
  • 4 months later...
I have a 2000 with 376k miles, 150hp injectors, FASS fuel, quadzilla w/adrenaline, 3.54 gears (5 speed) and as long as I stay at 68 MPH or below i get a hand calculated 24 MPG. Diesel is 3.89 per gallon today here in western KY.
Are you running an aftermarket turbo or anything? That's a lot of juice for a stock turbo.. Otherwise that's pretty darn good. I would love it if my diesel was that cheap...
That would be a lot of injector for a stock turbo $3.69 here in VA Sent from my SPH-L710 using Tapatalk 2
Riggins, ID is at $4.159 for diesel. As for me I couldn't even play the MPG now that I kind of nuked the MPG number getting a fire call in Whitebird, ID get almost to Riggins, ID and get called off. So this tank is going to be a dud and lower. That why I love the ScanGauge II being I can calibrate it and see it on per day basis then I'm not having to baby the truck every single day but drive as needed.
Hmm seem's mine is about the same as everyone else before i junked my Bad Bank's Ottomind i got 14 mpg avg now i get 16.9-17.5 with the truck in my sig but now it only smoke's on start up i miss rolling coal on tailgater's:ashamed: Gonna get a smarty soon .... well after i find $699 laying around. :cool:
