The TP is Smaller.............But is My Arse Getting Bigger???
- Replies 15
- Views 3.7k
dorkweed 5 posts
Mopar1973Man 3 posts
ISX 1 post
War Eagle 1 post
I know not many here use TP bypass oil filters like Michael and I; I have to ask, why are the TP rolls getter smaller????You'd think with the "obesity" epidemic in our country, the TP rolls would be getting larger IMHO!!!! My MotorGuard bypass oil filter was designed with 4.5" wide TP rolls in mind..........just as I believe the Frantz TP filter was also.I the last couple years, the TP rolls have gone from 4.5" wide, down to 4.25" wide, now down to 4.1" or even 4.0" wide!!! For a while I thought my ___ was getting wider..............but I still have the "Schwarzeneggarian" 180lb. physique I had in high school!!!My question to all using TP bypass filters is this............what are you doing, if anything, to accommodate the the narrower asswipes in you bypass filter setups??!!!
