Destroyed a turbo with a hose clamp
:duh::doh::banghead:Yeah gang... I destroyed my turbo with a wire hose clamp. post-2-138698196468_thumb.jpg During my oil change and boost leak fixing I laid my BHAF on the workbench and inadvertently knocked a wire hose clamp in the BHAF from the peg board above. Installed the filter and took a ride. Boost kept getting lower and EGT rising whistle changed big time. Hua?! Went home to find the first pic and the 2 ears of the clamp in the BHAF. The rest of the ring I'm hoping is in the intercooler. :pray:Engine still runs fine... So I need a turbo... First and foremost.I know that S#!7 happens but man this make me sick... :sick:
  • Replies 66
  • Views 12.8k
That sucks, Mike!!! :banghead:Where you gonna get another? Used? New? Upgrade!?! :hyper:
Dang Mike, you will never find a used turbo that clean.:cry: Sounds like its upgrade time, maybe an HE351:whistle:
Ahh, thats no good bub. I did the same thing once, but with a rag. I still had my factory air box at the time, pulled the filter to replace it and was cleaning the bottom of the box out while I had it apart. I dropped the new filter in, and somehow ( I still dont know how or why) I must have set the rag on top of the filter and at that point got side tracked. Came back a few minutes later, threw the lid on clamped it down and jumped in to take off. As you can imagine it sucked the rag right up and into the turbo. It completely blocked the air flow off, I had no power whatsoever. To make matters worse I didnt put 2 and 2 together and I screwed with it for hours before I figured it out. Yep, makes ya feel like a real dunce :ashamed:Whats your plans for a replacement?
So far both vendors I've talked to have been nice enough to admit I need to upgrade. (KT Performance & GOS Performance)So far GOS Performance seem to have the winning price so far for a PhatShaft 62/70Second in line is KT Performance with Diesel Power Source 64/65/12 I could also buy a use HX35W for $250 buck but both vendor suggest against because of my current mods.Still waiting for DAP and Walt at FTE to call back... Any other suggestions?
I can tell you from experience with several different turbos and knowing what you use your rig for and the territory and I can say I would not go with even a 62/70 as it is going to be very lazy and smokey in them thar hills, Definately stick close to what you have now, Or a Super B at max, a 62/70 is too much for your needs and current fuel.
HX35W is 56/60/12 for reference...For those that want to know, 56=small diameter of compressor (in millimeters), 60=small diameter of turbine (also mm), and 12 is cubic centimeters of exhaust housing.
Point me to a link of a product you suggest so I can see it... :shrug:
BD super B, 58/65/14. I ran this with 90 hp injectors and it was lazy & lagy and hot compared to the stock hy with wastegate linkage hook and comp on my 02. I think the Super B would work with RV injectors or 40-60 hp sticks and comp, 90 hp was a bit much. You are not going to have enough fuel to run a PS62/70 :2cents:http://www.dieselperformance.com/index.php/product/index/3P http://dieselperformance.com/pdf/BD_Single_Street-Tow_Turbos.pdf
Another problem I got is the exhaust brake. The guys over at CF.com reminded me about. :banghead:
In your shoes I would stick with an HX version.
I second this idea...you have a proven set up now. You might lose mileage and bottom end response with a bigger turbo. I'm happy with the used HX that I put on mine. I only paid $250 for it and the manifold.
I was going to recommend the Super B with a set of 7x.009 sticks. But since you have the exhaust brake, you might just need to stick with the HX35. :shrug:
Sorry to hear about that Mike, but as the guys on the Viper forum say, "that'll buff right out" :wink:
Don't you hate it when someone assumes your like them. But I think a lot of people on this site are like each other. We like to work on em and keep them running good, and that's how they treat us once in a while. Sorry mike. Selfishly though, I'm waiting to see what you do about it cause if I ever need to replace I'm doing what your doing. I'm sure you feel the pressure so make a good choice for us. Just kidding, but not really. Really though I'm sorry that happened.
I nearly sucked a rag up a few weeks ago. I was messing with the pcm or something and pulled my BHAF off and put it in the backseat of my car and put a rag over my turbo. I got busy with something else and forgot about finishing what I had started and went to start the truck. Luckily, I never plugged the pcm back in either or that rag would have been eatin by a hungry turbo.:doh:
I think we've all made mistakes... some more costly than others... but if we admit out screw ups perhaps others can learn from our mistakes. At least it's a way to salvage some benifit from it. At 60+ years, I've had a lifetime of bonehead moves to learn from!
can you get away with putting a new comp wheel and housing on it?
Yeah there's a writeup on CF for doing it yourself as well
