Destroyed a turbo with a hose clamp
:duh::doh::banghead:Yeah gang... I destroyed my turbo with a wire hose clamp. post-2-138698196468_thumb.jpg During my oil change and boost leak fixing I laid my BHAF on the workbench and inadvertently knocked a wire hose clamp in the BHAF from the peg board above. Installed the filter and took a ride. Boost kept getting lower and EGT rising whistle changed big time. Hua?! Went home to find the first pic and the 2 ears of the clamp in the BHAF. The rest of the ring I'm hoping is in the intercooler. :pray:Engine still runs fine... So I need a turbo... First and foremost.I know that S#!7 happens but man this make me sick... :sick:
  • Replies 66
  • Views 12.5k
Well GOS performance is going to be taking care of my turbo. It being sent off to Industrial Injection to be full rebuilt. Too much broken stuff now. I've got broken studs damaged parts, can't separate the compressor wheel at all. So I'll let Industrial Injection do the work.
Can you fill in the ignorant guy and explain why you cant use an aftermarket turbo with an exhaust brake?
Major Suckage, Michael!!!!:duh::spend::banghead:How long for the re-build???Is there a "break-in" for new turbos??? AH64IUD???Mike, it's really hard to read this and actually comprehend how this happened to YOU!!!!! You're one of the most meticulous and anal persons I've never met!!!!:lmao::lmao2: That said, I still feel for you, man.Here's hoping this works out for you!!
Mike from experience and knowing others personaly who have sent things in to II for repair/rebuild, Word to the wise is to get a quote in first, Most repair / rebuilds they do wind up costing people more or as much as a new turbo would. Do not let them touch it without talking to you first and giving you a "HARD" quote not an estimate.:smart: Not knocking II at all, they are great but they tend to gouge folk more often than not on the service end.
Hopefully it will work out good for you. If there is anyone that a business doesn't want to cross, it's him, He could all but put someone out of business just by his word of mouth and the trust that follows it. IMO.
ive always made a habit of tapping the intake tube with my hand just to get any dirt out, sorry to hear of the messup mike but it happens :(
Broken studs and compressor housing won't come off??? You didn't let the penetrating oil soak in to those bolts did you :evilgrin: The compressor housing is just a snap ring and it pulls straight off. If it was sommmmmehow welded to the wheel, then you could take the nut off the wheel and the compressor housing and wheel woulda slid straight off. So, what was the deal with it? Sounds like you admitted defeat, I want to know why!
Broke one bolt on the exhaust housing (exhaust brake). Then the 4 that hold the exhaust housing on the one behind the oil inlet is frozen can get it loose at all. But it boxed up and ready to head out.I don't have the tools for drilling, tapping and heli-coil the hole properly. I understand the method of it just lacking experience and the tooling.
Sad to say it in progress. Bill is paid and the turbo is boxed up to be sent to Utah.
By saying the Bill is paid does this mean they only charged you a set amount for a complete rebuild site unseen?
Let's say that its will not go up in price. More or less my is going in for as a core nd I'm suppose to get a re manufacture Hx35w turbo in return. The possibility of my own turbo returning is a "maybe" but I kind of doubt it. GOS Performance is the vendor interface to Industrial Injection which I was told GOS will handle everything for me. Aden is a good man (owner of GOS) he's the one that sold me the AirDog years ago.
AAAHHH now it makes sense, had me confused with all the rebuild talk,:duh: so it is an exchange then.:cool:
That sucks!!Good call not going with a 62/70, you would have HATED that turbo beyond belief with how you drive. The fuel you have would certainly warrant a 58/65, or 62/65/12 but any bigger than that wouldn't work for you. Thou I am not sure spending money on a stock turbo is worth it??? But if it works, I guess it works....The exhaust brake does make it a little more difficult, since most go to a HX40 downpipe. I think the BD Special is out of the question, but the Garrett appears to work with the EB. But in the end, it's all what you can justify for the cost. I had never heard of GOS so I was peeking at their site. The turbo they have listed as a 62/70 is a 62/65 so I have no clue what 62/70 means????When I first looked they didn't have a OEM reman on the site, but it just popped up. About 1/2 price, so if your HX35 has been working then go for it. The fuel you have is too much for the HX35, unless you don't use it :-)They are considerably cheaper on their reman's than others I have seen, I hope that it's just a good deal and not a poor reman.
Broke one bolt on the exhaust housing (exhaust brake). Then the 4 that hold the exhaust housing on the one behind the oil inlet is frozen can get it loose at all. But it boxed up and ready to head out. I don't have the tools for drilling, tapping and heli-coil the hole properly. I understand the method of it just lacking experience and the tooling.
I feel your pain on that one Mopar, I broke 2 bolts off mine also...
Mike, have you received any news on the status of your turbo, I know it's early in the procedure but all the same, thought they may have gotten it and tore it down. Just curious.
And get some damn pictures of your exhaust brake and inside the exhaust manifold showing your pyro probe! Need to see what yours look like compared to mine.
I bet that sucker did whistle! LOL
