- Replies 23
- Views 10k
hex0rz 4 posts
Ilikeoldfords 4 posts
MnTom 3 posts
skellyman 2 posts
Alright, someone please tell me this is about normal? I switched to Amsoil on my last oil change. I'm now about 4300 miles into it, and I checked the oil level recently before I went down to see my parents for christmas. Its a good thing I checked! The level was below the add mark and I had 2 quarts left of this liquid gold to add back into the safe area. I noticed the oil pressure gauge showed a little bit longer of a delay in building pressure on initial startup and pressure was a little lower than normal. Nothing that raised a red flag, but now I know why it was so.
I have noticed since the change that the blowby vapor looks as though it has increased and there is some more oil "condensating" on the differential from the breather. As well, using more than 2 quarts up in approximately 4300 miles.
Is this a sign of a failing engine?
I was running DELO 400LE before the switch and maybe added a quart or so during the life of an oil change(7500 miles).
..believe you me, I can't pull my 5th wheel with a couple mules!
