- Replies 26
- Views 5.7k
Mopar1973Man 5 posts
hex0rz 5 posts
Yankneck696 2 posts
CTcummins24V 2 posts
So, I took the truck to a shop this morning with the intention of achieving the usual alignment interval...
I get a call about a 1/2 hour or so before work, that they were unable to perform an alignment on my truck. What? Bullhonky! So I had him gather info. on what was going on.
1. RH outer tie rod completely shot.
2. Steering stabilizer done for
3. Steering gearbox sloppy
I also asked them to rotate my tires and they said it was done....
Huh, well, little did they realize, my front wheels are discolored from the brake dust. When I got there, they were still in front! grr... They also told me my front outer brake pads were almost worn down to nothing?!
I told them I just replaced the pads/calipers less than a year ago!
I'm not quite sure what to think as I feel like in order to tell what the pad life on the brakes are, they need to remove the wheels. Which they did not do as since they did not rotate the tires. It just raises my suspicions!
I did not realize the steering was that out of whack? I kind of figured the steering was just fine? Maybe I'm just used to how it steers...
I need a couple pointers and diagnosing these parts to see if they are really out of spec and they are not just pulling my chain. I already have a hard enough time trusting auto repair shops. They are my necessary evil for alignments, new tires, etc....
So, if indeed these parts need replaced, I might as well get it all done in one fell swoop if not too spendy. What brands should I go with, and if I need a gearbox, which one. If there are alternatives or something to use to upgrade instead and whether or not there will be interferences with other parts. Like I know the steering brace is not compatible with some gearboxes, etc.
Basically, what do I need to do to the steering components to make this go away and stay away! I'm looking at doing bilsteins for shocks so I will probably get a dampener from bilstein as well...
It was something that was not on my to do list, nor what I wanted to do to the truck. I just ordered head studs to try and take advantage of the deal on it. The wifes not too thrilled about all of this, lol...
