DTT Assassin not pumping!
- Replies 76
- Views 12.4k
rancherman 16 posts
ISX 10 posts
Ilikeoldfords 9 posts
JAG1 8 posts
Hello ladies and gents!! Hope everyone is ready for Christmas and New years and everything is going well for everyone.
Now, on to the problem.
My brother has recently purchased a very clean 2002 Ram 2500 CTD. It is a five speed and completely bone stock from bumper to bumper. He is going through the motions of basic bullet-proofing (Gauges, Lift Pump, Etc.) I talked him into getting an Assassin mechanical lift pump because that is what I will probably end up getting if and when my Raptor gives up. He also went with the beans diesel sump at my suggestion versus the draw straw.
My father and brother are working at installing the entire system this weekend and just got it all buttoned up. One slight problem... they cant get the lift pump to move any fuel!! They had assembled the entire fuel system but left the line off that goes into the VP. They were going to prime the fuel system then hook that line to the VP very last. To prime the lines they just put an electric drill on the lift pump shaft and used that to turn the pump.
They never could get fuel to the VP. Not even air!! So they pulled the lines off of the Assassin and sucked on the fuel line coming from the tank. They had fuel in less than 30 seconds just from manually sucking on the fuel line. Hooked it all back up, and still wont pump any fuel.
They have triple checked that they are in fact driving the pump the correct way, and even tried turning it the other way with no luck. I have never heard of anyone having such an issue with the Assassin. It is such a simple design I just cant figure out what could be wrong with it.
Anyone have any kind of a clue as to what they could try next?? They are in central WA state working on this and I am in western MT state so I am trying to help them over the phone. Thanks a bunch as always!!
