Teardown and Rebuild
  • Replies 1.7k
  • Views 322k
  • All done
Threads like this make me happy I stopped where I did. Lot less of...  :truck:
My thoughts exactly. I'm adding a boost elbow to stuff an extra 5 PSI of air in my truck to balance the fuel I have which is already a lot.
3 hours ago, TFaoro said:
7x.013 Sac!! Which equate to 300hp over.
:burnout:
Edited by Vais01
That's why I'm only after 450 tops. Actually, whatever I can get out of some 5x.012 injectors and the correct supporting turbo is what I'm after lol.
I'm running 7x.009" SAC injectors and a 62/68/14 wastegated turbo. Which nets me around the 350 range as a daily driver. The Quadzilla has a custom tune for fuel efficiency with that set up that I wrote for my configuration. It has plenty of pep to it and good fuel economy so I'm happy. I'll be happier when the stone is out of my cab and the knock is gone.
I see most of us try for balance.
22 hours ago, TFaoro said:
I'm done searching. If something blows up I guess I'll find it!
One last video before the big injectors go in
Where are you reading boost? Only 30 to 35 PSI on twins?
That's reading only the 75's boost pressure.
New injectors are in!
I saw 70 tonight after playing with the wastegate.....
What's expected peak?
:think: I don't know haha I've never owned another one of these.
I made 50psi on a smarty only though
Edited by TFaoro
650 or so. I don't know if I'll make it with these exhaust housings though.
It's was probably mentioned somewhere in this thread but I missed it, what transmission do you have?
650 HP :whistle:
It could happen but you will be on the edge of the VP44's fueling abilities. Hope your rod bearings are of the grey looking material otherwise long term your engine won't like you.:2cents:
The fuel is there. Making 650 on a VP happens all the time. For me it's a matter of getting the air in there without too much back pressure robbing power. I've got tight housings to keep the spool up quick and smoke to a minimum.
I'm not worried about the bearings. They're stock and they'll last just fine. It's not like I drive around with it to the floor full time.... other than tuning the turbos the TST gets flipped on maybe once a week. If it's cold even less or it'll blow the tires off.
Reverse level, air compressor style haha! Picked this up for my dad on Thursday. 4 cylinder 2 stage for cheap! Couldn't pass it up.
Nice.  My dad picked up one of those.. the compressor was seized though, but the tank is still good.  Between three huge compressor tanks he has enough air to float a submarine.
18.9mpg after 400 miles. 300 highway 100 city. Those who say you can't get good mileage with huge injectors are WRONG!
This is one reason I don't like levelling kits on a Dodge. As soon as you put anything in the bed heavy it looks like a Ford truck squatting.
As for the compressor I LIKE that... I would love to have a good compressor like that in my shop. :thumbup2:
On 12/1/2015 at 10:54 AM, Mopar1973Man said:
I have to agree with both of the above statements. Thats with near 6k# on the reat axle.
When I get more air into it. :shifty: Still figuring out WOT issue.
I mean we could go slide around I25 if you're up for it :lol:
