New Kicker Speakers for Beast!
This turned into a problem child to a degree. My driver's side rear door release cable for the inside door latch broke at both ends of the cable. Urgh! I'm going to repair the end hopefully with super glue and atime to till I can order the right cable. 20+ year old plastic is brittle. I've got to pull my dask bezel, and I'm sure more of it will break now, too. Argh!
The other problem you starting to see how often im capable of working on my truck which is all based on weather now.
Old CAT5 cables, replacing with CAT6 cables!
Cables due to be here tomorrow. More to come.
Now today I was wiring up the rear speakers and then lost connection on both left speakers.I pulled the front left apart and recrimp the connector solved. Now the left rear is dead no signal. I think a darn mouse chewed the wires in the dash. Ugh! More to come.
Yeah. I would of bought a box and ends but I already have a 500 foot roll of direct bury outdoor CAT6 cable. I've even got two new cameras I want to mount to pole out in the yard. I need to clean up the yard in that spot so I can place a pole. Shop trash heap is in the way. Then run from the switch to both PCs is just barely 16 foot at the longest. 3 cables coming to replace the CAT5 cables. What bandwidth does your cameras run at? Mine seem to only hook up at 10/100 shown by the network. Just the Verizon extender too. Dang cheap CAT5.
10-4 App
Weird. I would consider either grabbing a small sample and testing both. Maybe catch the delivery truck and talk to him. See if your state has different policies. Last time I caught Maverik delivery I was able to find how much additives are being added.
10-4 App
Your problem could be the Edge Juice most likely too advanced in timing. Then how many miles on your injectors? As injectors wear out the pop pressure falls off for every 10 bar drop the injectors gain 1 degree advancement. This mean you would have to reduce timing in your tune to keep numbers up. Then the high cetane of biodiesel is lower BTUs but also needs less timing (retard) to burn efficiently. Quadzilla im starting at 12°BTDC at 1500 RPMs. Im not sure if your Edge has any timing adjust.
@Tweety Bird asked me to send some documents to her computer workstation. I'm getting a message of "No Route". I check the network switch for her PC to be present. Nope is not even registered in the network. I've been working with damaged scraps of cable, trying to get by. Nope! I'm done. I jumped out on Amazon and found a 10 GBit CAT6 cable rated for 10 GBit. I'm going to upgrade the 2 lines between the workstations so that large data moves can happen quickly. I just remember I need to order one more short cable about 6 feet tonight, so the server and the two stations will all have 10 GBit bandwidth, and I could move data like I have the internet backbone. https://www.amazon.com/dp/B00G9BN4L6?th=1
Titanium Not Going To Forced
This post is going to get political. There is a small group of Goth/Emo/Alt people claiming that if you want to be part of the group, you have to vote democratic. As for me, I started my Goth/Emo/Alt journey into makeup artistry with my bladder cancer. Then I started to catch flak for posting my Goth/Emo/Alt photos on coments ot artist I liked. One person told me if I don't vote democratic then I'm just a poser. Me. I had to create another photo shoot for new photos to handle the punk kids who are just being mean. Yes, I've got a few more photos of me with my Favorite shirt, "If Don't Like Me... F___ Off Problem Solved." I will not be forced to think a particular way or forced into politics for a dress style. Sorry, I will not comply! In the meantime, I've crossed 1,000+ followers on TikTok. Still making friends all around the world with Goth/Emo/Alt makeup designs. Like my newest follower, I found out is Gen X as well, and that enjoys the same kind of makeup artistry. Say hello to N.U.Noni... (Header photo)
Bearing preload
There was an awesome write but all photos and the photobucket account was lost by that member so the page went blank. @Tractorman is correct on the specs. Most impacts won't make the grade. The article is had talked about torque multipler gearbox for the torque wrench.
Hello There, I'm Back!!! Crazy Life Update!
Thank you for the wonderful conversation. Thank you for sharing your story!
You are in Central time, so I'll hit you up at 5 pm our time here in Idaho (Mountain time)
For fellow CPAP users and Linux Users
Another member here told me some information about the CPAP software he was using for his CPAP device. He referred to a program called Sleepy Head. I did a quick search on Google and found OSCAR. OSCAR does the same task of showing off all the medical data from your CPAP device. I wanted to share this knowledge with other Linux Users.
