Retired Staff
  1. I know that Auto Computer Specialist actually rebuild wiring looms. https://mopar1973man.com/forums/forum/210-auto-computer-specialist/ The voltage of the APPS seems low at .112 volts. I would suggest getting a Timbo APPS and ditch the old voltage APPS of the OEM and Wells (Magnetics). Timbo APPS is a true mechanical APPS. Bad idea.. Again, that is not how that system works. That voltage is determined by the sensor; each manufacturer is differen,t and the value never matches!
  2. Basically, in a nutshell, the alternator charge line is hooked to the passenger side battery. The engine grounds for the ECM and VP44 are separated and relocated to the driver's side battery, so the ground cannot be cross-polluted by the fact that the positive charge line is run next to the master ground for the engine. AC noise jump in that 4-foot run of wiring. So the mod was to separate the positive charge line away from the master grounds for the VP44 and ECM. Ground on the left (black/tan) and alternator charge on the right (black) then the crush crimp of ground wires under the black tubing on the black/tan wire.
  3. If ACS said the ECM is good then check wiring for faults shorts etc.
  4. Mopar1973Man posted a gallery image in Titanium
  5. Mopar1973Man posted a gallery image in Titanium
  6. Mopar1973Man posted a gallery image in Titanium
  7. Mopar1973Man posted a gallery image in Titanium
  8. Mopar1973Man posted a gallery image in Titanium
  9. ECM might have a bad solder joint that is breaking connection during warm up. Test you electrical (wiring first to be sure).
  10. First problem, there is no 24 valve 6BT engine. They were all 12-valved engines. Then the 6-speed NV5600 was released in 2000 with the high output 24V 5.9L ISB engine trucks. Now as for getting rid of the ECM it won't happen because you need the ECM for gauges like coolant and oil pressure. The p-pump was a bad choice for swapping to being its a static timed pump and had zero advancement technology where the VP44 has a full range of 30 degree BTDC worth of advancement. Cluster requires the ECM to report the oil pressure, volts come from the PCM, fuel gauge from the PCM and the coolant temperature.
  11. That should give you all the info for testing the overflow valve on the VP44. Just remember the little hole is always open and some pressure can bleed. The check ball should stay closed completely at 10 PSI. Fully open by 14 PSI.
  12. Love it. You are going to find the answer now that you have a nose for what you are looking for!
  13. Your subscription is worth it, right? 😁 Good, at least you have the knowledge to do a scientific study to figure out what your transmission is like for fluids. Remember, this is a temporary weather issue, but you can make a better choice of fluids for your transmission. When we modify these trucks for more power, more torque, more towing abilities, there is going to be a forced change of fluids that fit the new design. Like my example of the manual transmission, I was seeing extremely high transmission temperatures on 75w-80 SynTorq Fluid back in the day, this became to thin and cause my damages. Now with thicker fluid to cling to the gear and not easily spun off the gearface so there is something between the gear face protecting the gears from touching. This is a known issue for G56 (manual 6 spd) for using ATF+4 in my 2006 G56 transmission. Yeah, that will be another fluid I'll even change and upgrade too. Again, I've increased power on Thor, and you need better protection or the transmission will wear! Point I'm making once you leave the stock power realm start researching your lubricants. Don't just settle for Redline or AMSOil synthetic because of the brand name. Also look at the temperatures you operate at what is your power increase over stock. Just consider true 1/4 mile trucks don't run just 80w-90 in the axles because its too thin. I've seen some professional trucks running 250 wt in the axles. Just consider factory 85w-140 for limited slip axles factory setup. Again needs friction modifier too. Keep the axle clutches from ratcheting. You are right about this being real too. There was a flash update for the PCM to correct for this in stock form for the most part. I'm missing that TSB from the article database and will have to hunt it down. His I think is a bit deeper issue with viscosity being more the issue.
  14. Just a quick search on Google AI turned up... There is your thicker fluid that needs a bit more time to warm up in cold climate. Might look at the specifications sheets of different fluids and them figure out which fluid is better based on "kinematic viscosity" scores.
  15. Beast has developed a problem with the hydrobooster being the main booster piston; the seal failed, and even brake pedal usage was leaking hydraulic fluid from the hydrobooster. There is a bleed hole on the bottom of the unit. This was just replaced, as the article was created in the 2nd Gen brake and axle category. That particular day, I was wearing my black hair and basic black makeup. Then on Thor, it was a matter of replacing the battery terminals. Using the really basic tools I do have after the landslide its rather challenging to do some jobs because you just don't have the right tool and needs to be done. All the factory lead terminals were cut off with a dull hacksaw. Then trimmed back to find copper wire. Clean any corrosion off the wire before crushing copper lugs to the wire. Improved the starting and power stability for this truck since the passenger cable was held on with a C-clamp. That day, I was enjoying my red hair and flame colored eyes. Some of you wonder why still. The makeup work of Titanium becomes a line in the sand for me for protection for myself. Knowing my ostomy bag is there, I must keep my bag area and my hands clean. My dress code limits me from rolling in the mud or dirt to do work. Remember, the landslide took my shop and the dry space I had. The last 2 days here have been raining so no work was done last two days because of zero dry space to work. I'm going to continue to produce as many articles as I can with my limitations. You have to remember my right kidney is only 17% remaining and my left is 82% remaining.
  16. Mopar1973Man posted a gallery image in Titanium
  17. Mopar1973Man posted a gallery image in Titanium
  18. Mopar1973Man posted a gallery image in Titanium
  19. Mopar1973Man posted a gallery image in Titanium
  20. Mopar1973Man posted a gallery image in Titanium
  21. Mopar1973Man posted a gallery image in Titanium
  22. Mopar1973Man posted a gallery image in Titanium
  23. Mopar1973Man posted a gallery image in Titanium
  24. Mopar1973Man posted a gallery image in Titanium
  25. Mopar1973Man posted a gallery image in Titanium
