  1. I've rebuilt many boxes over the years for older Dodges and Ford trucks with the sagnaw steering boxes. Not my first rodeo... Doing seal kits in them are super easy, cheap and typically the steering box does not wear out just needs adjustments. There is no real book info of this slack adjustment, just over the years I found 1 to 1.5 turns out is about good for average slack. Like my OEM box Blue Top Steering said my box was like brand new yet and only needed one seal and out the door again in less than 1 hour was sold.
  2. Either.... Bad injectors washing down cylinder walls and creating blowby. EGT's ran too high and did damage to a cylinder wall and/or piston. Using a washable filter and dusted out the engine rings are wiped out. Vacuum pump has a vacuum leak pressurizing the crankcase blowing oil out. Fuel leak into the crankcase front seal of the injection pump. My thought would be to do a compression test and find out where you sit. Then you'll know if its rebuild time our not.
  3. Everything here is back to normal for the most part... Stores are fully restocked. Price of Gasoline in Boise is 1.999 a gallon but diesel still lingers at 2.659 roughly. The stay at home order has been extended to April 30th for Idaho. The biggest thing I still fight with is going to the city and needing a bathroom still hitting locked doors, no public restroom usage, etc. Like my last trip to Boise to drop off Eileen's Grandson back to his parents, I was hunting for a restroom just to pee, had to pick a side street and pee behind a tree in a industrial area. Stupid laws and really becoming tough for people that travel. Still hearing strange laws of cops turning people around at state line to go home. Never seen it yet with crossing into Washington or Oregon yet. Even heard of the local cops in McCall, ID turning people away because there plate are not Idaho, Valley county. Never seen it yet either. Other than that the weather here has been cold and nearly snowing. Dipping into the 20's every night and warming up barely to mid 50's. Get down to Lewiston or Boise its more like 60's and 70's for day time weather which is nice.
  4. Not much. Stock transmission is rather marginal at best in stock form. The valve body is going to change up your shift. Like my 46RE has a Dynamic custom build and it bangs the gears yet just wonderfully. The difference is my 46RE is more like 47RE after Dynamic built the rest of the transmission for me. Milled the clutch baskets an 0.1 of inch and added in an extra disc in both overdrive and direct clutches. Plus with all the other goodies, levers and pistons, spring kit, etc. Even added extra oil cooling jets for the clutches.
  5. All explained here... The original...
  6. Typically the burp problem shows up if you been turning the steering wheel without the engine running will possibly burp fluid out. Since the pump is a restriction to the intake of the gear box so it doesn't refill the box as fast as the return to the pump. Hence it burps out the cover.
  7. Stacking tuners just turns the throttle into a light switch. By the time you reach 30% of throttle by position the ECM will be at 100%. fuel rate.
  8. ECM most likely took damage. P1475 will require the ECM to be rebuilt and repair the 5V generator for the sensors. This right here the excessive AC noise, damaged the ECM and the 5V generator internally.
  9. @01cummins4ever Never got much light from the factory lights. Hence why there is a pair of 100w lights tied to the rear axle. Same problem with both trucks.
  10. You might test that out during the dark of night.
  11. If so you might have to send the Quadzilla back for warranty repairs.
  12. At least by 1996 was RE styled transmissions. My 1996 has a 46RE. That has to be either 47RH or 47RE. 4 - How many forward gears 7 - Scale of 1 to 10 of how much torque it can take. R - Rear wheel drive vehicle. E - Electronic Shift 4th Gear. -or- H - Hydraulic Shift 4th Gear. Still all based on the original 727 Torqueflite transmission from the 60's. 46RE's are used in the half ton trucks. 47RH or 47RE were used in all 3/4 ton and 1 tons. Majority is 47RE. 48RE came out in the 3rd Gen body.
  13. You need some slack in the gear to prevent binding up over the center position. You add slack to prevent it from binding up. If 1.5 turns is still stiff add another 0.5 turn out. If you removed the box and rebuilt it you would do the same thing bottom out and set you slack. Just the output shaft has nothing attached. So backing off is easy because no drag link hanging.
  14. Basically if you keep twisting the adjustment downward or tightening the output shaft is push down into the the rack of the gear. Now once bottom is found you lift up with your hand and push the output shaft back up as you get your slack adjustment. The weight of the drag link and the pitman arm prevents the adjustment screw to lift the full load. Just using the screw you'll get roughly 3/4 of turn and it will stop, till you lift the pitman arm up pushing the output shaft back up since the adjustment screw can't lift the weight. Looking at the photo the adjustment screw is on the other side. Pushing downward or towards us in the photo. The drag link is hanging from the output shaft. Soo as the adjustment goes tighten (downward) int the gear rack then it will hit bottom. Now lifting up allowing the screw to lift the output shaft back up from bottom to set your slack.
  15. Quadzilla does not use IAT signal in any part of the tunes. Be aware that using level zero you return back to ECM software and then the IAT signal is used. Don't use a K&N filter good way to dust out an engine. Every time you wash the filter the media is being broke down and bigger and more particulates will pass through the filter. True test is K&N filter run up a dirt road and then white glove the turbo. I'm pretty sure you'll chuck that K&N in the trash. Also if you are a big washable filter fan there is washable oil filters but I don't know anyone crazy enough to use it. MAP sensor on the Quadzilla does not always show accurate numbers. Like on mine my ISSPro boost gauge shows a max boost of 47 to 49 PSI. Then Quadzilla will record a max boost of 69 PSI. I don't worry about the MAP sensor because the 0 to 30 PSI is OK. Close enough being that's all the Quadzilla uses for the CANBus fueling.
  16. Automatics ground the starter solenoid relay. Manuals use a slide switch to supply +12V to the starter solenoid relay.
  17. So very true. I'm also got a Quadzilla Adrenaline been running it now for 5 years. If you want to disable the Quadzilla just set it for level ZERO and it stock once again and you can drive on that and realize that you lost quite a bit of power. I've gone from the 235 HP/460 TQ to somewhere around 500 HP now and still capable of reaching 21 MPG. My list of mods... https://mopar1973man.com/garage/vehicle/101-2002-dodge-ram-2500/?show=mods
  18. Yes you can but... Grid heater will not shut off above 20 MPH so be aware. Battery charge time needs to be extended. Cruise control doesn't work need to be above 30 MPH to set.. High idle will work but will not cancel from no speed signal. Speedometer will not work. Lack of signal. Might impact automatic trans being road speed is considered.
  19. Yup, I run the the adjustment screw all the way to bottom just lightly seating then I back off from bottom 1.5 turn to give slack to the gear teeth. You'll have to lift the output shaft a bit so you can get the slack you need. You can do the 1/4 turn method but you might have to do it like 20 times till you get the slack taken up.
  20. Because you are looking at the same sensor. This why you need a external boost guage.
  21. Ouch... Yup, I'm could use a bit of that stimulus check.
  22. Yup. Level zero basically shut down the entire Quadzilla. It only in read mode read data but there is no enhancement. Strictly Stock ECM software.
