Everything posted by flman
Fun at the CF
The 5 PSI is enough debate rages on.................. http://www.cumminsforum.com/forum/98-5-02-powertrain/239338-installed-new-vp44-running-like-crap-again-help.html
data from my drive on the highway
Funny my engine don't have an apps on it? But my TPS has about 8 wires on it.
Took my son to his first fight...
He sounds like a true hockey player
CAI in Summer VS Warm Air in Winter
And I never plugged in a block heater since the age of diesel electronics, I am not even sure if they would work if I did plug them in? So for sure with electronic every thing has been optimized.
airdog install ?s
Seems like the PF7777 is the older style? http://www.baldwinfilters.com/literature/english/8%20Service%20Engineering%20Bulletins/06_1.pdf
airdog install ?s
A yahoo search of specs brings me to our friends a CF http://www.cumminsforum.com/forum/3rd-gen-powertrain/101850-baldwin-pf7777-filter-please-help.html
airdog install ?s
The PF7777 is rated for light duty and the PF7977 is rated for heavy duty trucks that would burn more fuel stock. The PF7777 looks like paper by its yellow color, the PF7977 is a white synthetic fiber, and the Fleetguard FS1268 that my truck calls for is the white synthetic fiber as well.Here are the pics side by side. Could you give us a link where you got the data on those filters?
A Dirty Word... Oil
Running Amsoil throughout as well, except for the tranny. It calls for 50 weight ATF that would be used in an Allison automatic. But the last time I picked up some synthetic lube at FleetPride, their own brand that is more like a gear lube, the guy at the counter said' "every one is using this in their trucks". It shifts just fine in all temps, quieted the gear box down, and it offers more lubricity then the ATF. The only drawback to that Fuller Eaton is you have to buy the fluid in 5 gallon pals, so I can get 2 changes out of it any ways. In the engine, I use the 15w 40.
New VP44, the results are in!
Thanks a bunch every one. Being in the refrigeration biz, knowing temps is very important. The warranty process is open until the pump is torn down and the failure is determined, I should know by next week, I will let you know how it all works out.
airdog install ?s
Baldwin crossed the FS1268 to this part number PF7777, for heavy trucks, and Chrysler. It looks just like the Fleetguard filter. They are all the same physical size as the PF7977? http://catalog.baldwinfilter.com/
IR thermometer fun
I thought it was ironic that you posted this thread. But now that you know that temps. You have a guideline to use if you have any problems in the future.
IR thermometer fun
Good idea, you can check their mood. LOL
airdog install ?s
No such thing as a Freightliner part number, because this could have been built with a lot of different engines. I just have the Fass pump, I was mainly concerned about positive fuel pressure.
IR thermometer fun
It is great way to check those critical temps on the VP44. That is the Achilles heal of our ISB's. I am going to check mine when summer comes and the hot weather hits. http://forum.mopar1973man.com/showthread.php/1266-New-VP44-the-results-are-in%21 You can use it for lots of other things too, rear differential, transmission temp, fuel temp, and alot of other things that may not have a gauge.
I got it from Blue Chip, supposedly it has a 1 year unlimited warranty, and the failed VP44 is still under warranty with them (less then a year old), so of course that is where I got it.
airdog install ?s
Mine take the Fleetguard FS-1268 Fuel Filter cartridges, I am not sure the Dodge has the same filter, but I can get Baldwin products at Fleetpride.So I want the 5um?
Well, I got to use the Freightliner quite a bit today. Any ways she is back to full power. Enter highways from the ramp when all the cars go to the left to allow right of way and pass that big slow truck , they get quite the run for their money, I lay onto the accelerator, and they find them selves going alot faster to get around me. Also, at the bridge toll, 3 tolls wide, big blue took the lead up the grade to the bridge, left all the cars behind. It has always been a fast truck since I got it. Has some real tall gears. top speed of 85 mph at 2500 RPM governed. It has a 3.31 rear axle, and runs on 22.5 tires, so yeah it is long legged.Any ways after a 45 minute run home on the highway, I got out my infared temperature gauge and check the critical temps. Out door ambient +14 degrees, VP44 computer 50 degrees, pump body 46 degrees, fuel in tank 30 degrees, all fuel components cool to the touch. Considering the fuel tank was in a wind chill and had fuel in it at 30 degrees is a good indicator that the fuel is definitely getting good flow.Well, I am happy now, thanks for all the help and suggestions.Bob
airdog install ?s
The Baldwin will pass 3x more fuel, how does it filter? I have always used OE since day one on my ISB.
Custom bumbers: Let's see 'em
Nice custom bumpers guys, and I think the 16 YO has some good talent, he will go far with that.
FASS DDRP: Why not????
In Plumbing 3/8" OD tubing is called 1/4". So yeah the wall thickness makes it smaller, steel tubing is probably a little thinner then copper tubing?
Newb with low power all ranges
Got the VP44 swapped out today, so far so good, big blue feels like her old self again :)1/2' supply lines are next on the agenda, I have to make this pump last.
I would be concerned about that, being I dont know what kind of impeller or tolerances the Fass pump has? The OEM pump seems to have big slots in the impeller, that would easily pass a chunk of crud? I would like to see the inside of one of these Fass pumps. Has any one opened one up yet?
Synthetic oil: Any leaks?
I run Amsoil in my vehicles, and yes the oil pan on my Cummins leaks a little bit, I heard over in ILD one guy took out all the bolts and put loctite on them, and supposedly stopped the leaking?
I just ordered the 1/2" fuel line from Vulcan, I am going to use this filter before the pump, I like the piece of mind, that some piece of grit is not going to wipe out my new pump. https://www.vulcanperformance.com/ProductDetails.asp?ProductCode=ILFF500 I know you guys like the air dog and all, but I was just looking for adequate pressure for my VP44, I am sure the 1/2" line should help with this during the fuel thickening winter temps. Even on a home oil burner, the line size goes up with distance, and lift.
Why can't our diesel's idle?
With the 4 valves per cylinder you get alot of air flow going, mine will drop the temperature at idle in frigid temps. All that air causes cooling in the cylinders. I had Cummins speed up the PTO idle so that I could run my engine at a high idle if I want.
