flman
Everything posted by flman
  1. ISX, believe me, I don't think he is an idiot, he knows what he is doing, I might be more at ease if he was an idiot. At 47 I have never felt so helpless as an American citizen with an over bearing government. I even took a look at candidate Barak Obama my self. I did not think he was all that bad of a guy at first. He was the new kid on the block, he seemed to be well educated. But then I saw through the smoke screen, when he was campaigning. Now as the president, he bows to our advisories, will not salute the flag, and even serves other governments besides the US, every thing he does is against the constitution.
  2. Sorry if I offended any one, this is general conversation. And the opposing side would jump in to go against the other party in a heart beat, so what comes around goes around. And my real goal is to help America, my family, my grand children and the future. To me, this is more important then how my truck is running. These people need to be warned, and there is nothing wrong with being the messenger, if the bridge was out, you would not be offended if I warned you?How did he get there? Those voters were not the first in history to make a bad choice, and wont be the last. He hid his Kenyan citizenship, told alot of lies, and got a lot of people in a bad economic situation to fall for it. Alot of them voted out of desperation. Isn't that how most dictators got into power? At least Hitler was loved by the German people, BO not so much.Personally I am a Libertarian, but even the Repubs are looking the lesser of 2 evils for the last 16 months.You are a Mod, if you want to delete this entire thread, and ignore our country being destroyed, go ahead.
  3. These ones tell the truth http://www.antiobamasticker.com/
  4. Its a joke by some other BO supporting ******.
  5. I agree he is an illegal alien. But a seven second sound bite is not enough to impeach a Democrat. But any other party, that would be plenty of evidence.
  6. Forget the Star spangled banner
  7. http://www.summitracing.com/parts/ATM-3279/ This fitting really reduces they rate of flow, my truck has to run like 5 seconds to read above 0 PSI on start up. It would even make it safer to have no isolator, as it would not allow much fuel in the cab, in the event of line breakage or an accident.
  8. Thank you, you listen, could you run for President in 2012? We need a man that listens and is not controlled by special interests and Wall St.
  9. The Dodge/Chrysler section looks like the rest of the forum. No one has said boo in the Chevy or Ford sections. I still say we need "General Diesel" section.
  10. I would be concerned, but I would not immediately worry unless it went below 10 PSI, but I would swap the filters out the first chance I got, and take if from there. If the pressure remained low, then you have other problems to deal with.
  11. Funny, my FL build truck does not even have an apps? But it does have alot of wires on the TPS.
  12. I keep my needle valve cracked just enough to pressurize the gauge, it is only 1/6th of a turn open.
  13. No, it actually has sintered metal in it like a restricted filter and is Dodge Cummins specific, and yours has a small orifice hole?
  14. This is the fitting I use, and it works well http://www.summitracing.com/parts/ATM-3279/
  15. Anything oil based that I drain out of my vehicles (motor oil, atf, differential lube, etc., and even vacuum pump oil from my refrigeration biz) goes into the fuel tank of my home oil burner, And it is used to heat my home and make hot water, it is blended with no. 2 fuel oil. I have been doing this for 20 years, the detergents makes the boiler all white inside.
  16. Thats a good thing to know, considering I will be the owner of a JD compact tractor in a week or so It is in my bookmarks. BTW, for all of you with multiple PCs and notebooks, you should get Xmarks, at www.xmarks.com it syncs all of you bookmarks and passwords with a server, you can even use your own private server. I do not use the passwords option however, I would rather keep them local.
  17. Are you taking the engine out of the FL, or are you going to run the FL? Are you referring to Ram Truck mods? Being a mechanical IP, mods would be easy, what is the engine rated at now? I am sure it is higher then a stock Ram to begin with.
  18. If I don't have any CCV build-up, why should I bother? I wonder if installing performance boxes like the Edge causes the excess CCV build up?
  19. I heard alot of those dedicated doctors are going to be retiring, so much for the best health care in the world. And as an employer, I might just become a one man band again, with those kind of regulations. If that thing passes we are going into a depression any ways. Is that video of the current bill, or the one that was voted down a while back? I am sure the newest bill still looks alot like Soylent Green. If it was a good bill, it would be an easy win. It is not hard to tell, the current cartel in power really hates America and the hard working people that make it the best country in the world.
  20. Wow, some dirty oily engines and radiators? The only oil on mine is the pan gasket leaks a little bit. I have absolutely no oil or grime on the front of the timing gear cover.
  21. That is some scary ____, and it could all happen in a day or so:ahhh::banghead:
  22. I am not counting on our NY AG to take a stand, and I am sure Ed Casey is not counting on the MA AG to take a stand.
  23. Damn, you have the worst luck, I hope you are putting a warranty pump on? Otherwise I would have P-pumped my truck by the 3rd pump, if I were getting that little use out of pumps.
  24. It is said to see all those in Congress line up behind this one term president, and give him this kind of power to destroy America, and he is not even a citizen. Barry Sotaro's party is the majority now, fools voted for change, and they are gonna get it right up the butt.
  25. Well, I bit the bullet, I am going to sell my POS Troy Bilt lawn tractor, and my POS White 45" snow thrower and replace it with some thing that better fits my taste for mechanical power. I put the money down on a John Deere 2305 3 cyl diesel powered tractor. For now, I am getting a 54" snow plow, and a 54 inch mower deck. I took it for a test drive yesterday and it was smooth, vibration it the drivers seat is almost absent. I probably wont be able to wait for the grass to grow or the snow to fly. http://www.deere.com/en_US/ProductCatalog/HO/servlet/com.deere.u90785.cce.productcatalog.view.servlets.ProdCatProduct?pNbr=0140LV&tM=HO&link=enav
