JOHNFAK
Everything posted by JOHNFAK
  1. Found it .... Feels smooth as theres not much left is why ...
  2. Gave up on front shaft can't work out how to get joints out in one of the flnges will drive it to shop for bench work and install myself Started on rear - see video - all looks ok .... So not sure where squeal and vibration comming from Thoughts ? video http://www.youtube.com/watch?v=lY822zrIrG4
  3. Cardamom joint - didn't know it was rebuild able as such fill me in
  4. ahh Some reason when I saw the bill for the head work I thought wheres the labor ..... shrug ... Hope I never blow a gasket - taking the twins off would be such a PITA just to do a HG .....
  5. Ok kinda put this on back burner. Found I had to use a wobble extension to get front driveshaft off - PITA Bought a battery powered impact wrench and like is so much easier with the ball joint press. So I started pulling the joints out and then realized I didn't mark which side was connected to make sure all goes back on same - is this a big deal for front driveshaft ? If so how to tell ? Pic below I will definately mark the rear when I start ... Just wanted to get the process down on the front shaft before truck is down for rear Pic Thx
  6. Hard to answer It's better than without it it's much harder Worth $100 shrug I'm moving to a smarty tst stack
  7. Think we can get rid of 2 party system under "national security threat" ? I'm almost serious
  8. ok any tips on how to get the 5/8th (~16mm) bolts out from the front driveshaft attached to transfer case without dropping the crossmember - its a tight fit in there even with a stubby wrench and then no leverage ....
  9. I mean the clips in the head of the ball joint ... Think they have plastic inside ..Not the bolted u frame that's holds it to the axle shaft ...
  10. Do I need a blowtorch for the clips At front ?
  11. but the ujoints are actually different parts right ?I mean when I look on parts stores there are different part numbers depending on which ujoint ?Guess theres a thickness difference ......
  12. lmao - fair enough next question - whats the best way to determine what ujoints I need to order. There seem to be a few different ones .... for rear/ front/ middle section etc
  13. This one mike ? http://www.harborfreight.com/ball-joint-service-kit-for-2wd-and-4wd-vehicles-4065.html any tips ?? - - - Updated - - - sorry man - this does not sound like the road I want to travel ....... not unless your there to fix it after
  14. yeah I heard harbor freight balljoint press works ...... but as my truck will be down and no other car and will be working off back of the truck as my toolshop - need to have all the tools and make sure its works as promised. So keep them comming guys - products you actually used that work awesome !!
  15. What's best tool to make pressing these out easy Any other tips ? What brand of u joints to replace ?
  16. Work ?... Or fail ...
  17. true - but you were directing and slapping me to speed it up for dinner Since then I either have problems wtih the back of the VP44 (need a stubbier wrench) or with the connection tubes (couldnt get one out and took me forever and stripped all the threads) ... or leaks post button up .... Went with teh appraoch of not removingh lines from abck of VP44 .... probably quicker - but not easier as its tight clearance especially on #3 if changing connector o-rings also
  18. Last ones was actually getting one of the connection tubes out ... Funny ( link above )
  19. 4 hours is my best .... Always have a couple small issues ...
  20. 13mpg towing a fifth wheel is about as high as you will get on these trucks
  21. Sounds like you got lucky considering it's aftermarket and it's not slipping with over 400hp Definately a nice addition for towing considering the extra cooling also you found. You could check line pressure without dropping pan to see how much % over stock you are running
  22. Except my trans is built and when it hits lockup you better not be picking up spilt tacos off the floor - certainly launches after lockup
