JOHNFAK
Everything posted by JOHNFAK
  1. Glad your ok
  2. Disconnect the wire tap of the comp Have you tried running smarty only with your injectors ... No comp Get the timing from smarty I don't think you can run level 5 comp stacked and just get timing. Your still getting fuel and timing from comp and then fuel signal via CAN and no timing from smarty
  3. Can't get over 20 drives me nuts no I'm not complaining its just a ceiling I want to beat 11.5 towing 15-16 mixed 13 heavy stop start Stop start kills these autos
  4. Wow I once did a large acerage controlled burn in Australia . Never felt heat like that. Can't imagine in real life.Glad your safe boss
  5. Good luck JL Dibs on your 3rd gen
  6. yeah theres that Good thing is the stock turbo is almost always the best fit for mid range trucks. So main cost is in piping - if you an bend and weld - you can do pretty cheap. I cant - so it wasnt cheap
  7. Couldnt help it. Yeah I know how you guys feel ........ never had 1500 but I just hated EGTs and I knew I was being overconservative. Water methanol is a PITA if you ask me. So apart from going twins really the only other choice I see is oversizing the TURBO for the fuel - just slightly. And tuning.
  8. Twins baby Can't get over 1050 Hahaha
  9. It's called a manometer I think Isx had a link to it somewhere here
  10. Basically yes. You need a wifi device to carry with you so you can get on the WWW. That is one with no contract and you just add minutes. You can do it with other carriers/devices and different plans with or without contract. There are apps that allow you to make calls via VOIP from your ipod also ....... its just not good enough to use as a phone only solution .... yet.
  11. Like this Pick your carrier No contract http://www.virginmobileusa.com/shop/mobile-broadband/broadband-2-go/mifi-2200/features/
  12. iPod with a wifi tethered device or straight wifi like a mifi. Have to carry both devices is all . You can even make phonecalls it's just not too reliable for that.
  13. Nice Now your ready for the dyno haha
  14. Not going to use the stake holes as I have rail cappings on that I like too much to part with Going to stick with having it strapped to bed for now thx guys
  15. Not all autos had the hy35. Think 2001-2002 . You need to check what turbo you have on truck from the ID plate Hy use a jhook Hx use a elbow If you already had an elbow likely you have a hx35 That's probably why confused
  16. Everything ^^^^ here And the puck is awesome for $90
  17. Looks clean .... How's 2nd any different or you just learning it ?? Have to come look sometime
