JOHNFAK
Everything posted by JOHNFAK
  1. Think there just on hangers .... Think I got it
  2. I waited for a special and got front and back for around $400 or $450 delivered. Have teh fronts on and the base of the rear seat on but hit a problem with the uppe rear bench seat. I think its bracketed to back of the cab so I cant slide down the cover over the top ....... seems strange ........ thought these didnt need seat removal Anyone speak from experience ? How do you remove the rear seatr if I need to ....
  3. Around 4 weeks for order ... Starting Before pics 1st one done
  4. Isx said what I was going to say - hahahahahahshshahahThat stuff
  5. How hard for the dash out of 10 ?Thinking of doing mine .. ..
  6. Ha - yeah I do hit that drum a little - but where else can you get a quick spooling 60mm compressor thats good to 450-500HP (non towing) and only costs around $350 to swap out (used) with you HX35 !! I agree it has some problems towards the upper range ....... but then just TWIN it !! lmao. I just hate slow spooling turbos - that makes for a horrible DD ....... so whilst you get better efficiency at higher load ...... ........super b is good ...... but only truck I ever rode in that had one didnt spool as quick as mine ! Did I mention (agin) I cant peg the pyro beyond 1050 - WOT up a hill on a hot juice/wa and 150 injectors ! :) Personally Id never run a single again ........ and I'd just do a cheap twin kit over a hx35 if I was going from scratch ... a 62/475 if I was really goign for some numbers .............. but whatever I went with I would keep the exhuast side as small as I could for spoolup even if I sacrificed a little
  7. But the super b cheap .... Sell it ..... Buy a he351cw or a hybrid or a super b or a phatshaft 62. Exhaust side will control spoolup and drive pressure and a little egt ..,, I think a he351 cw rocks to 450hp. Only 200 and 100 adapters
  8. Think it was like 200 and the cheapest adapter bar was like 150. cPp have the kit for around 380 complete and bushings look better than the OEM ones
  9. Cant really apart from specs (which are racing specs) and people who use them. Thats why if I ever upgrade my flexplate it will be to one of these - as there are at least 2x ~700HP CR trucks using them for racing for 100's passes and no issues. 700 HP @ WOT using this product is enough testing" for me. How that changes with towing and EB Im not sure anyone could answer apart from theoretical. I'd spend money on the input shaft .... and have the VB modified to reduce the lockup harshness. I have that on my truck and running 450-500hp towing 3x disk , lots of WOT runs when not towing ...... 0 issues so far ........ but I dont have an EB.
  10. Try that - but sounds like your not locked up or your slipping the TC. Could be time for a new TC. For altering OD shift points. http://dodgeram.org/tech/transmission/automatic/TPS_adjust.htm "Always start with the original voltage you had; as you increase your voltage your OD and TCC lock up will start to come in later and later. The down side of doing this is that when you slow down or if you remove your foot from the throttle, the TCC will not unlock unless you step on the brake pedal or your vehicle speed drops below a certain setting."
  11. SFI rated plate on eBay that's in a couple 700hp CR's is around $120. Billet input is around $600. You can drop tranny and install both yourself.Goerand has a video on the input install.
  12. What does it do of you drive with OD off. Should lock up around 35 mph.
  13. Don't think your dropping 600 rpm from ODSounds like lockup to me ? Shrug
  14. Wet okole seat covers ordered 3rd gen brake upgrade sitting here to be done Switch out the juice CTS with my tstPatch some developing paint issues 3rd gen track barLong term ..., Full paint Steering box and tie rods and linkages Dash
  15. Snag me some !!! Give me an excuse to get out to tampa ........ and see this pulltruck of yours
  16. Sweet - that's probably what I'm doing .... After 3rd gen trackbar Nice looking truck
  17. The Irobot vacuumSeriously ..... Havent pulled the real vacuum out in months
  18. Who's traction bars. ?
  19. Anyone know where to get large Rubber exhaust hangers online.... Mine are DOA towards end of truck ....
  20. Some used ones for sale in the classifieds as well ;)
  21. Any of the vendors here are good ..... go to the vendor/wanted section and request a price - or PM them direct
