Everything posted by dripley
Blue-Top vs Redhead steering gear
They cant hurt as long as they work.
dipstick differences?
11 quarts gets mine to the full mark. Never used 12.
Spitting and sputtering
Its good info. We have bounced that one around here for many years.
I did not see one on there either. It did say in the products section that them from the early 80's to 2008, but iI did not see them listed at all. @Blue-Top Steering have you stopped on the 2nd gens?
01 cummins not getting fuel to injectors 1 and 3
Might be time to make a warranty call to investigate at least. https://www.bluechipdiesel.com/troubleshooting-1 Here is some trouble shooting on the pump you can also try. Good info.
2000 Honda Accord using oil
No wonder I never knew about codes. Never had anything newer than an 84 until 1998 when I bought my first 3/4 ton. It was a 96 with a V10. It only gave me one problem in 2001. It was spitting and sputtering with oil running out of the tail pipe. Did not need a code for that. I am still sitting in its replacement.
ABS/ Brake light on
Me too. I had 2 and put them on last brake job. The old ones had 200k+ on them.
He does have them. Sometimes he is out of stock which means you have to send yours in for him to rebuild. Need to do this myself this summer. Though the Chevy box has my attetion too.
You did have the 3 with fuel tightened up right?
The ECM controls the WTS light. Could be in there also. I had an ECM failure but did not set a code for it either. When it dies for hours or days does the WTS light come on at key on. If its warm outside it will only light very briefly so watch closely.
ABS/ Brake light on
When the oe hubs went out I had to drive the truck for them to go out. Drove maybe 100 yards and off they went.
Headlights not fitting
Nothing wrong with that either.
When I am thinking "stall" i am thinking shutting down. I saw them WTS flash on and off 4 times while the engine was running. That seems odd to me but dont really know what it could mean. Maybe an ECM issue, just dont really know.
The key to silicone is remeberiing it is easier to add more than it is to wipe off excess. Back when I was carpenter building resteraunts caulking the interior was one of my jobs. I used to have to show many folks that you can seal joints quite well without having caulk smeared everywhere. Just because you cant see it does not mean the joint is not sealed. Your picture is a good example of that.
ABS/ Brake light on
I am just lucky my light went off and stayed off. Had me guessing too.
Thats what I was thinking. Had this truck for 8 years before I knew wwhat an error code was. Funny how a blown ECM will educate you.
Sometimes they can be stubborn. Good fuel to 3 cylinders ought to start it.
ABS/ Brake light on
My abs and brake were on and I replaced both front hubs and they stayed on. Replaced the rear after that and they stayed on. Rode like that for a few months and they went off. Cleared the codes and all is still well. Never figured out what was wrong.
Did vehicles set codes back in 88?
Did you bleed the high pressure lines?
Landmark photo's
Getting a picture with the cow just did not seem apropriate. Plus the first chicken houses I built were KFC's, long ago.
Landmark photo's
Hard to tell whats going on in the video. I do see the WTS light flashing on and off thru it all. How are you checking for codes? How are you monitoring the fuel pressure?
Got mine done but still some back log to clear. Just started my new job last Monday. Got the permit on Wednesday, beautiful weather Thursday and then Friday a hell of a wave of rain, heavy winds and some tornados came up from the gulf and drowned every thing in its path. Rain thru Saturday at the job and home. Hope this isn't an omen of a wet summer. Building on Georgia red clay. It hates water. Likes to grab it and not let it go.
Careful now.
