Tractorman
  1. I agree with you here. A few months ago I converted to an after market Sports headlights version from Headlights Depot. I chose to go the aftermarket way because of the very high cost for the OEM headlights. The optics on the Headlights Depot lights are definitely not OEM quality. Fortunately in my case the headlights were of better quality than many others out there and there was a significant performance improvement over my two-bulb system making it well worth the purchase. I would rate the low beam circuit as good. The roadway is well lit when looking down the road and to both sides. The low beam works good in rain and fog conditions as well. The beam can be properly aimed and does not interfere at all with other drivers on the road. The downside is that the light is not evenly projected onto the roadway - there are some dark areas (although small). These dark areas do not cause any problem, but they should not be there. I would rate the high beam as very good to excellent. The beam projects very far and is evenly spread. The high beam is properly aimed when the low beam lights are adjusted properly. I wired my headlights the same way an OEM Sport version is wired. I also used Philips Extreme Vision lamps as Daniel Stearns recommended. Katoom, if I understand correctly, you have OEM Sports headlights on your truck and you were very satisfied with them, but they are yellowing now. I am curious as to why you are not replacing them with OEM equipment. Is it because of cost? - John
  2. Unfortunately, the my particular switch is no longer available. It was made in China and cost less than $5.00 at the time, including shipping. I think it was made by 8 - 10 year old kids because it was of good quality. II think if you keep searching on Amazon you will come across something that will work. A Linemaster T-91-S Treadlite II looks like it would work (1" tall). It sells for around $20.00. It looks like you can get it with or without a cord. Either way you will have to do some modification. - John
  3. I tried different setups and I found that a momentary, easy to actuate ,low profile sturdy switch worked the best. It took me awhile to find my final switch, but I did find one on Amazon. The switch is contained in a metal frame that is less than an inch tall and has a large operating platform that has a mechanical stop so the switch inside will not be damaged. I have the switch held down by two carpet tacks and Velcro backing so the switch won't move around. This mounting method also allows for the switch to be placed anywhere and for easy removal when cleaning the floor. You could wire the switch in parallel with an LED light and have a nice setup. If you are considering this approach, just search on-line for "foot switch on Amazon" and you should be able find one right for your budget. - John
  4. I used to have a 99 Dodge with an automatic as well. I used a momentary switch mounted on the floor near the park brake pedal. The momentary switch was actually a universal horn switch (button). It needed to have a low profile, be easy to depress (just the weight of your foot), and be robust. The floor switch made it very easy and natural to control the lockup feature. Whichever switch you use, you may find the converter lockup feature doesn't perform the way you might expect. From what I recall, here is how I used my switch: I put the gear selector in "Drive" and turned the "Overdrive" switch off and started driving the truck. When the transmission shifted into third gear, I watched the tach for a small RPM drop noting that the PCM had just locked up the converter. When converter lockup occurred, I immediately pressed and held the floor switch as I modestly accelerated the truck in lockup mode. As the transmission approached the shift point for fourth gear, I easeup on the throttle and released the foot switch momentarily to allow for the shift and for the PCM to command lockup in fourth gear. When that occurred I immediately pressed and held the foot switch. Under normal driving at highway speed the PCM will keep the converter locked up, so you can release the foot switch and drive the truck. If you need to slow significantly for a curve, but don't want the converter to unlock or the transmission to downshift, then you press and hold the foot switch (before PCM has a chance to unlock the converter) and drive through the curve in a normal manner. Once you have manually locked the converter in fourth gear with the foot switch, it will remaine locked in fourth gear whether accelerating, coasting, or braking until you release the foot switch. This feature is useful to help slow the vehicle when traveling down grades as well. Reverse the procedure when shifting from fourth to third with a touch of throttle during the downshift. After a little practice you will see that it works quite smoothly. By using this procedure you will never have the converter locked during a shift, and it makes for smooth and precise shifting even pulling heavy loads. When I had my 99 with an auto, I had an exhaust brake controlled through the same foot switch as well - a great combination! Attached is a schematic confirming what Jlbayes posted. - John
  5. That's even easier to remember! - John
  6. Here is what I wrote down in my notes for my 02. For left side adjuster, turn star wheel tooth up. For right side adjuster, turn star wheel tooth down. Hope this helps, - John
  7. I converted my headlight system to the sport package system last July. I chose to use two fuses and four relays for the following reasons: * one fuse and two relays per side for safety * one fuse and two relays per side for lower amp draw (10 amp per side with four high beam bulbs activated) * two relays per side using both 87 an 87a terminals on both relays so low and high beams are not mixed when switching from low to high or vice versa. I wired my headlights per OEM specs and Daniel Stearns recommendation. Even though I purchased my Sport Package headlights at HeadLights Depot.com, the greatly improved lighting is very good on low beam and excellent on high beam. I am not talking about how bright they are, but how well they light up the roadway and surrounding area without impacting other drivers. I think one important step is overlooked much of the time and that is to perform a voltage test at the headlight bulb when the project is complete. Most bulbs manufacturers require 13.2 volts AT THE BULB to perform to their specs. This means making the check with engine running and headlights on. Both test leads should be placed at the connector on the bulb for most accurate reading. In my case the low beams showed 13.4 volts and the high beams showed 13.2 volts. In the diagram below I interfaced the factory schematic with my modifications. I used 14 gauge wire in the relayed part of the circuit. The schematic works for either two bulb or four bulb system. The factory part of the schematic makes it easier to find wires however you decide to do the project. - John
  8. I installed a vacuum operated switch ( a GM heater / AC control from a wrecking yard) years ago. The cost was $5.00 and it has worked for over 250,000 miles. I think it is the best option because it allows for easy engagement and release of the CAD with vehicle slightly rolling. I use the 2WD Low frequently and I believe this is an excellent upgrade. If you go this route, just about any automotive HVAC control with vacuum ports and a rotary control knob will work. You will need to figure out which ports will work for you - a vacuum pump with a gauge will be very helpful. You will probably need to cap off some ports to make it work. The end result is well worth the effort. - John
  9. I very much agree you and here is why. I am the original owner of my 2002 truck. The VP44 and lift pump were replaced in 2005 at 87,000 miles under warranty for timing piston failure code on the VP44. The lift pump pressure was in specs before the VP44 and lift pump were replaced. I drove the truck for a week (50 miles per day before I gave the truck to the dealer)with a fuel gauge attached to my windshield wiper and the fuel pressure always stayed within specs under all driving conditions. After the replacement of the VP44 and the factory modification of installing an in-tank lift pump, I installed the same fuel pressure gauge and fuel pressure was much lower than specs under all driving conditions (6 psi at idle and 3 psi under a load). I questioned the dealer mechanic (a very knowledgeable guy) about this and he said he is aware of this, but the new lift pump installation change is required by Dodge. Fast forward a few years - I currently have 267,000 miles on the truck (180,000 miles on the replaced VP44). In the spring of 2016 (at 251,000 miles) I replaced the in-tank lift pump (which was still working) with a frame mounted used FASS lift pump. I only did this in case the lift pump failed while on a road trip which would make for an easy repair. So the VP44 ran for 11 years and 164,000 miles with the in-tank lift pump operating at very low pressures and the VP44 is still running fine. Hmmmm.... Thanks for listening - John
