4X4 bearing Hubs and ABS Discussion....
I have just crossed over the 300,000 mile mark on my original front wheel bearings. I, too, have always wondered if having the six speed transmission and using the exhaust brake daily for the life of the truck has contributed to the long life of the front wheel bearings. It makes sense that the absence of serious heat would give a much longer bearing life. - John
New Tire Size found 235's to 245's
Just finished another round trip to Baker City and back hauling the mini-excavator both ways with the new 245 tires. Fuel mileage ranged from 13.8 to 14.4 mpg and the truck performs great! So far, I have not experienced any negative effects from switching to the 245 tires. Also, another noted performance improvement was during two of my trips through the Columbia River Gorge with gusty winds. When semi's passed me or I passed them, there was no longer a push to the side that I felt before with the 265 tires. I just crossed over the 300,000 mile mark on the odometer. The other photo is the 5 acre parcel of land we just purchased looking at the Elkhorn Mountains. - John
I am thinking the same thing. With the 245's, I towed my tractor with implements from Salem to Baker City via I-84 last week (GCVW over 16,000 lbs) and the truck had all the power I needed and delivered 13.5 mpg. Yesterday I towed the tractor back (minus a couple of implements) weighing in at 15,650 lbs via Hwy 26 and 22 at 15.2 mpg. I checked the miles per gallon from John Day (filled up with B20) to home near Salem. The power and the fuel economy are now the best they have ever been since the truck was new. Still on original injectors and I will pass the 300,000 mile mark on my return trip to Baker City tomorrow with the mini-excavator.. - John
I have now driven over 1,600 miles with the 245/78R16's and I am very happy with the results. About 700 miles of the driving has been towing within a 60 mile radius ranging from 15,000 to 19,600 lbs gross combined weight. With the 6 spd transmission and a 3.38:1 ratio for second gear, I can easily perform second gear starts on flat ground fully loaded now. I like that very much. Heavy loads are now much easier to get up to speed without working the engine. Sunday, my wife and took the travel trailer from home (near Salem, OR) to Baker City and deadheaded back. The trip out yielded 14.5 mpg (12,500 lbs GCW), the trip back yielded 22.3 mpg. I am very happy with that. The trip each way is about 335 miles. MPG's were hand calculated. I will be taking the tractor with implements to Baker City on Thursday and will be expecting to weigh in at about 16,000 lbs. I will post the MPG results later. Everything that Mopar1973Man posted about improved performance has happened for me by going with the smaller tires. With the new 3 1/2 turn stop to stop steering box, the new clutch, and the smaller tires, this truck drives far better now than it ever did when it was new. - John
Can I have two bad thermostats in a row
This is definitely worth looking into. It took me two years of driving my truck to figure this out because the symptoms manifest slowly over a long period of time. The blockage that you see on my radiator in the photo covers the front of the radiator between the charge air intercooler and the radiator where it is very difficult to see. I was always inspecting the radiator on the engine side because that is where I thought the blockage would be. After I cleaned that radiator I was amazed at how much quieter the engine fan became because the air flow became laminar again. And, of course, the overheating problem went away. - John
Time for a clutch
The HYDX1-50 is the complete hydraulic setup (master cylinder, slave cylinder, and hydraulic line - all pre-filled). It comes with an adjustable linkage to lengthen the master cylinder push rod, if necessary. You may not need the adjustable feature, but if your new clutch engages with the clutch pedal real close the floor, you will be glad that you have this adjustment available. If you decide to use this part, set the initial adjustment to match your old master cylinder push rod setup. If your new clutch engages and disengages properly (like the old one did), then there is no need to change the adjustment. I understand your concern here, but I think that you were very fortunate that your old hydraulics worked well with your new clutch. My experience is limited to only three clutch replacements - a 2007 6.7 liter 6spd, a 2006 5.9 liter 6spd (both dual-mass flywheel conversions), and my own truck (a stock replacement). In all three cases, the existing clutch hydraulic system was not adequate to fully release the clutch - the 2006 and 2007 being the worst. These two truck required the kit with the adjustable linkage. My truck is okay, but the clutch engagement occurs too close to the floor for my liking, so I will probably get the Soutbend clutch hydraulic kit with the adjustable linkage. - John
Time for a clutch
Southbend's part # HYDX1-50 has an adjustable pedal feature. This is important as the OEM and other aftermarket non-adjustable pedal clutch hydraulics will likely frustrate you because they probably will not have enough stroke with the new clutch parts. - John
Which billet tappet cover to buy?
This seems logical, but I have always wondered that with so many gears rotating and flinging oil everywhere, could the OEM vent be overwhelmed? It would seem that a tappet cover vent would be in a lesser turbulent environment and would have less oil entering the vent so it could do its job better. Just my thoughts. - John
This is what I want to do. I was just wondering if someone else has already done that and if they are happy with the results. - John I agree that a vent is a vent, unless one style separates oil from the vapors more efficiently. This is why I was wondering if the tappet cover vent may be a better solution. Thanks for the tip on the stock fuel pump bracket. I would probably trim the bracket as you did since I have a frame mounted lift pump. - John
Can you tell if one breather is more oil-free than the other? I like the idea of using only the tappet cover vent if it works equally as well or better than the factory vent just to get rid of the additional plumbing to extend the factory vent. - John
Thank you, appreciate you doing that. - John
Did you actually wait 24 hours for the silicone to cure and THEN tighten the bolts? Or did you re-tighten (re-torque) the bolts 24 hours later? Just trying to get clarification on your procedure, because if the bolts weren't tightened when you installed the cover, then tightening the bolts 24 hours later (after the silicone cured) would likely cause a leak. So you are actually running two breathers on your engine. I would be very interested to know if the tappet cover breather stays dry. - John
I have a related question to ask about the tappet cover. I have done the oil crankcase breather mod similar to Mopar1973Man's, but I still get some oil dripping out of the tube. It has always dripped the same amount of oil since it was new. I have seen aluminum tappet covers and 12 valve factory tappet covers advertised that have integrated the crankcase breather and vent into the tappet cover. Has anyone installed either setup on a 24 valve engine and did it stop oil from dripping out of the new crankcase vent tube? 3979-01dodge24v59, I don't mean to hijack your post, but maybe we both an get answers to of our questions here. - John
Well the Order is in
Sounds like is time to put it all behind you and enjoy your new truck! - John
Mystery tube
Whew! For awhile I thought I was being taken too seriously. I ran your idea by my wife - she said, "Install the RV injectors!". I guess I will just have to risk the chance the vacuum hose will pop off. - John
Mystery tube
So the vacuum line pops off when you install RV275 injectors. Does this happen when you install other injectors? I need to know because I have a set of RV275 injectors to install. The vacuum pump is gear driven and is attached to the front gear cover just below the fuel injection pump. The power steering pump is piggy-backed onto the vacuum pump. Follow the power steering hose from the brake booster to the power steering pump which is attached to the back of the vacuum pump. - John
Mystery tube
It is likely a vacuum line, which would explain why you can't change your mode settings. Without a vacuum source, the HVAC system will default to defrost mode. Start at the vacuum pump location and follow the lines up to the firewall (near the top part of your photo). You should be able to find the other disconnected part. - John
When I check tire, brake, or bearing temps by feel on road trips, I am not looking for a specific temperature - I am looking for a different temperature between like objects doing the same duty, for example: one front hub bearing being considerably warmer than the other front hub bearing. - John
This has been an interesting read. I am now at 297,000 miles with original non-greased hub bearings. So, should I go to the trouble of greasing them, or should I just replace them? On road trips I routinely check the hub temps by feel, especially on the interstate - I will pull into a rest area using only the exhaust brake and gears to get down to 10 mph and then feel the hub temperature after I have parked. Now I wonder if I should be more concerned after reading the reports of sudden bearing failures. Did anyone happen to do routine hub checks for heat prior to their sudden bearing failure? - John
Clutch replacement at 297,000 miles
Since the very tip of the pilot shaft did not receive any damage, a sleeve would not fit over it. I think that in order for a sleeve to work, some machining would have to be done to reduce the diameter of the whole bearing area on the pilot shaft. - John
I am thinking that it was a very good decision. I was getting ready to buy the 235 tires, but you started experimenting with the 245's with even better performance for our application. It is rather ironic though, how long it takes for us to put on the tire that is recommended on the label in the door jamb on our 2002 trucks. How did those guys know that? Another benefit for the 235 or the 245 tire that hasn't been mentioned - a reduced chance for hydroplaning. - John
No, and of course it would have been the most important picture. The needle bearing chewed away a few thousands of an inch of pilot shaft material all the way around the bearing area precisely the length of a needle bearing. Because of the missing material, the new needle bearing will not support the pilot shaft as well as before when the clutch is disengaged. - John
I thought I would share my experience with the clutch replacement job on my truck. I just did a clutch replacement on my truck after a good service life of 297,000 miles. However, in hindsight, I know now that I should have replaced the clutch much sooner, perhaps at around 225,000 or 250,000 miles. The primary failure was the pilot bearing which I had noticed recently because at times there was difficulty getting the transmission into gear with the engine running. Eventually, the needle bearings were spit out and the shifting problem went away. However, the failed pilot bearing damaged the bearing surface area on the input shaft to the transmission. I replaced the clutch disc, pressure plate, T/O bearing, pilot bearing, and flywheel. I decided to go with Napa because the clutch and pressure plate were manufactured by Luk, as were original clutch parts. I elected not to replace the damaged transmission input shaft at this time because I think that even with the pilot bearing surface damage, I can still get a reasonable service life before doing another clutch job. At that point the transmission may need other parts as well and all the work could be done at the same time. The photos show some of my observations. The friction surface of the pressure plate is not shown, but it looked the same as the friction surface of the flywheel. Also, the heat marks on the flywheel and pressure plate were caused by one event in which I was slipping the clutch repeatedly under a light load to diagnose a steering problem. I could smell hot friction material during this testing. Not one of my brightest moments. - John
Doing some math (3.55/410 = .865 (about 87%) and comparing your speed vs. rpm and my speed vs. rpm, I am guessing that you have a 4.10 axle ratio. One way to check axle ratio is to mark a relationship spot with chalk on the driveshaft end yoke and the rear pinion housing. Then do the same on each rear tire to the ground. Chock the front wheels of the truck and place the transmission in neutral. Have a helper jack up one rear tire and rotate that tire one revolution while you observe and track the revolution of the drive shaft. Then have the helper lower that tire to the ground and repeat the same procedure with the other rear tire. If you have 4.10 axle ratio, then the driveshaft will have rotated 4.1 times. If you have a limited slip rear axle, then both rear tires can be raised at the same. With limited slip, both tires will rotate together. Hope this helps, - John
