Tractorman
  1. Here is a different way to look at it. Let's say the truck is going down a grade at 1700 rpm's with the torque converter locked up, no throttle input from the operator, and the truck's speed is being held constant with just the friction of the engine being forced to run at that rpm (the drag). If the torque converter is switched to unlock, the engine rpm's will fall immediately, not increase. The falling engine rpm will reduce engine braking. The truck will begin to accelerate. I have no experience with Toyota transmission controls, but I am guessing that there is more going on than just unlocking the torque converter. - John
  2. IBMobile and I are saying the same thing. I hope we are not being included in the "you guys have it wrong" part. - John
  3. I know that the automatic transmission does not shift into neutral when coasting, but it gives a similar sensation when the converter unlocks. Is it possible that you are feeling a programmed downshift when the brake is tapped in the circumstance you described? I believe that transmissions that have the "Tow / Haul" feature will automatically downshift on a downgrade when the brake is tapped if the "Tow / Haul" feature is turned on. In this case the converter will unlock during shift but locks up again after the shift and it is the lower gear that you feel holding you back. - John
  4. Try this scenario. Pretend you are climbing a grade with a load using 5th gear in a 6 spd manual transmission. You crest the top of the hill and begin descending the other side. You like the feel of the engine holding you back a little.. You approach a curve and need just a touch of brakes to help maintain your speed. Would you shift the transmission into neutral at this time? I don't thinks so. If you were driving the same scenario with an automatic transmission in 3rd gear (OD locked out) with the torque converter locked up, then you would not want it to unlock the converter when you stepped on the brake. It would be kind of like putting the transmission in neutral. - John
  5. I just realized that I gave you wrong information. I had it in my head that we were talking about a second generation truck. You are correct - on your truck the fan is controlled by the ECU, either when the engine temperature is high enough, or when the AC head pressure reaches around 250 psi. With that said, a different but similar situation could be occurring. If you have your ventilation setting in the defrost mode, the AC compressor will be cycling by default. With very little air flow through the AC condenser, the ECU could be telling the fan to come on because refrigerant pressure has increased significantly. It could be a combination of both engine temperature and AC head pressure. I apologize for the confusion on my part. - John
  6. Possibly what is going on is that you have disrupted the engineered smooth, laminar air flow through the AC condenser core, CAC core, and radiator core . If very little air can enter the fan intake area, then very little air can leave the fan exit area so the temperature in that immediate area may rise fairly quickly and the thermo-sensor in the center of the fan hub will engage the fan. Once the fan is fully engaged, it will generate a considerable amount of turbulence and air recirculation because its air intake supply has been essentially cut off. The engine would not have to be "hot" for this to occur and the fan may run for some time. Without a winter front installed the thermal sensor in the center of the fan hub always has a smooth stream of air flowing across it - so it is very stable and engages the fan with repeated accuracy when necessary. What you could try is to have at least four separate openings in your winter front. They should be equal in size and be evenly spaced around the perimeter of the winter front area. The idea is to have several places for air to pass through without creating turbulence and to also have enough air flow to keep up with the fan speed when it is disengaged (the fan is always moving some air) If you get it right, then the thermo sensor will always have a stream of air passing around it. Some of the better winter fronts on the big rigs are set up like this. - John
  7. I looked out my window this morning. There was a guy standing in the street with a breaker bar. I pulled the shade down. - John
  8. Yes, you did mention it first - I missed that on my first read, so I apologize for that and thank you for letting me know. I had a '99 with an automatic (with temp gauge) and an exhaust brake for 70,000 miles. I controlled the exhaust brake and the lockup converter with a momentary floor switch and a throttle switch. This way I could lock the converter with or without the exhaust brake. Like you said, the transmission always runs cool. I have had the '02 with the six-speed manual for the last 16 years and 283,000 miles. For me it is a better solution. - John
  9. You have now read several posts for different scenarios for having the torque converter locked up, and they are good posts. But, the really important reason hasn't been mentioned... and that is heat from normal torque converter slippage. Serious heat if you are towing up a hill for any distance and the torque converter is not locked. Heat takes out transmissions. The moment the torque converter locks up (with a lockup switch that you control), the automatic transmission instantly behaves like an manual transmission and the only heat that is generated is from moving parts, and that heat is minimal by comparison. - John
  10. I know I am posting this a little bit late, but I wanted to clarify some things. I also apologize for any confusion on my part as to whether you should use the hand-operated vacuum pump or use the engine-driven vacuum pump for troubleshooting vacuum leaks. I use the hand-operated vacuum pump for troubleshooting vacuum leaks for two reasons. First, it comes with a vacuum gauge and a release valve which allows you to verify that the circuit being tested is holding a vacuum when you stop pumping. The second reason is that the hand-operated vacuum pump pumps a very small volume of air so that even a small vacuum leak is easily detected. The engine-driven vacuum pump is so powerful that even moderate vacuum leaks will go undetected because of the large volume of air it is capable of pumping. This is why it is not a good tool for finding smaller leaks. Also, If you do have small to moderate leaks, the air from the leaks will be continuously pumped into the engine crankcase by the engine-driven vacuum pump. This air will combine with normal engine blow-by gases and then exit through the crankcase breather.. The higher flow of gases (air mixed with engine blow-by) exiting the crankcase breather will make it appear that your engine has excessive blow-by. The additional volume from the combined flow may not allow the screen in the crankcase breather to catch all the oil droplets, so you may see an oily mist, as well.. In the last 283,000 accumulated miles on my truck, there were two occasions that under certain conditions I noticed an excessive amount of vapor in the air when the engine was idling. In each of these occasions (using the hand-operated vacuum pump) I found there were moderate vacuum leaks due to failing hoses or connections. Also, in each of the occasions all of the vacuum operated components (HVAC, CAD, etc.) performed as they should. So, just because all the vacuum components are working as they should doesn't mean that you don't have vacuum leaks. It is for the above reasons that I recommend using a hand-operated vacuum pump for troubleshooting vacuum leaks. Thank you, - John
  11. A hand operated vacuum test pump is a good investment, is not that expensive, and will allow you to accurately diagnose vacuum related problems. For example, the CAD unit can easily be tested. Place the transmission into a gear and select 4-high or 4-low with the transfer case. Jack up the right front wheel and disconnect the vacuum lines at the CAD unit on the axle. Connect the vacuum pump to one port of the CAD unit; leave the other port vented to atmosphere. Operate the vacuum pump and hand rotate the right wheel to ensure engagement or release of the CAD. Swap connections and test again. Assuming that vacuum held on each test, one test should allow the wheel to rotate freely, the other test should lock the wheel in place which means that the CAD is mechanically doing its job. Using the vacuum pump you can continue with testing of all vacuum lines until you find the source of the problem. If both tests pass and the 4WD light does not come on, then you have a bulb failure, an electrical wiring problem, or a CAD switch contact failure. If the right wheel spins freely during both tests, then you have a CAD failure. Vacuum leaks on these trucks are commonly overlooked until something fails. The vacuum pump is very powerful and vacuum leaks can go undetected until they become large. Remember, all air from these leaks pass through the vacuum pump, into the engine crankcase, and then out the breather vent. You do not need this additional air flow out the breather vent! This issue alone is reason to invest in a hand operated vacuum test pump. - John
  12. I just replaced my heater core about two weeks ago. I had the HVAC unit on the bench (the only way to do it in my opinion) and spent some time replacing weather stripping around doors and duct connections. I bought some universal adhesive weather stripping in various sizes for windows at a local hardware store. In some places where I needed a thin seal, I used the fuzzy side of adhesive Velcro. Whatever you use, just make sure it has a strong adhesive. I had already done the Heater Treater blend door repair and all vacuum lines and motors were in good condition and passed the vacuum test. I will be getting the after market cabin filter from Geno's - I definitely recommend it. My evaporator core had lots of debris blocking air flow. My windshield and side windows now stay clear and the heater keeps the cab warm on the lowest settings. Success! - John
  13. I wired the intake manifold heater in my truck in the same manner right after I bought it in late 2001. I mounted a momentary switch on the steering column so it is very accessible and cannot be accidently left on. I don't mind the two codes that are set since I know what they are. My truck has been wired this way for over 280,000 miles and has never required any repairs. Mopar1973man makes a good point for those who live in areas that require vehicle inspections or emissions testing. - John
  14. I would very much like to see some on-highway photos (low beam and high beam) of the light pattern from your truck's headlights. Hope you take the time to do that on one of your trips. - John
  15. Dieselfuture is right on here. The factory evaporator drain on the firewall side does not have a downturn. So, when the seal between the AC housing and the firewall fails over time the condensation dripping from the drain follows the pipe right back into the passenger compartment. It took me awhile to figure this out because I thought it was from the windshield as well. I found a piece of preformed 90 degree heater hose the right size and pushed it onto the drain pipe. Problem solved - that was over two years ago. - John
  16. Since there has been some interest in the heat blanket, here are more photos. All the pieces were installed in October, 2015 and have 42,000 miles of operation with no signs of deterioration. This product was expensive, but since I am keeping the truck for a long time, the decision was a good one. - John
  17. The valve cover cover is a heat blanket developed by Advanced Thermal Products in Irvine, CA. It is custom fitted to the valve cover. I also so have the exhaust manifold, turbo charger (exhaust side), exhaust down pipe, and oil pan covered with the same material. This heat blanket is designed to easily withstand temperatures well above 2,000 degrees F., so the material does not deteriorate. The engine compartment runs considerably cooler, the seals in the exhaust brake vacuum cylinder don't get scorched, and the passenger side floor now stays cool when pulling a long grade on a hot day. My wife likes that. There are noise reduction benefits, as well. The raucous idle clatter is subdued when standing outside of the vehicle as well as when sitting inside or driving down the road with the windows up or down. My wife likes that, too. The purpose for covering the valve cover and oil pan was for engine noise reduction only. The purpose for covering the exhaust components was for heat reduction in the engine compartment. There was some noise reduction benefit, as well. - John
  18. I am tired of struggling to do repairs in that confined area between the front of the engine and the radiator shroud. I modified the top of my fan shroud and now the work area is very accessible - I should have done this a long time ago! The belt tensioner, water pump, and fan clutch are now very accessible, in fact I removed the belt and then the fan clutch assembly just so I could clean and inspect the fan blades. The work was very easy. I know that someone has probably already done this, but here are some photos anyway. I made the cut in a specific manner so there would not be any sharp corners when you reached into the work area. I used two zip ties on each side for easy removal and installation of the modified shroud top. Note that in the photo with the shroud top installed, the zip ties are not very conspicuous. - John
  19. My truck is a 2002 with a manual six speed transmission. I am not sure if your '01 truck will be the same. The wiring diagram for my truck shows that the ECM supplies the "speed control switch signal" and the PCM handles "sensor ground" and "speed control supply". I know that some of the circuit has to pass through the clutch switch and brake switch, as well. I would check these two areas first. The only problem I ever had with my cruise control was a broken power supply wire in a panel just below the steering wheel which was an easy fix. The broken wire was caused by lots of use of the tilt steering wheel. In my case I had code "0577 - cruise control switch voltage high" set. Do you have any codes set? Hope this helps. - John
  20. If you still have the parts, you may be able to do a close inspection and figure out whether you had a loose wire connection, or the contactor failed internally.. When inspecting the wire connection (after the damage has occurred) look at the copper eyelet, the two nuts, and the stud for extreme discoloration. Then make the same inspection where the contactor connects with the post. Whichever location shows the most evidence of an extreme heat source would likely be the problem area. Not an absolute method of troubleshooting, but usually the source of the problem can be detected. - John
  21. I removed the insulation from the PCM wire and soldered in the wire that I added. I brushed on a couple of coats of liquid electrical tape for water proofing and finished with regular electrical tape. I actually ran the added wire through a relay to a good ground contact and wired the foot switch to operate the relay. This step probably wasn't necessary, but I wanted to keep the tapped PCM wire separate from the foot switch wiring to protect the PCM from any possible unwanted electrical voltage. Let us know how everything turns out. - John
  22. I think that there is a definite benefit to having a momentary switch on the floor by the park brake. Just make sure the switch has a low profile and that it is durable and can be activated with light foot pressure. I had this setup on my 99 truck for 70,000 miles and I liked it very well. I used the lock-up feature in 3rd and 4th. With a little practice you can have smooth, quick manual upshifts from 3rd locked up to 4th locked up (unlocked during the shift) Once up to speed the floor switch no longer needs to be activated, but if you are accelerating after a curve or you are cresting a hill and don't want a downshift to occur you can just step on the switch and pour on the power without an unwanted downshift. Also, if you are pulling a grade in 4th gear and it is inevitable that a downshift will be needed, you can keep your foot on the switch and pull hard until the shift is required. Then ease up on the throttle, manually downshift while simultaneously releasing the foot switch and then quickly activate the foot switch when the converter locks up in 3rd gear. Again with a little practice you will find the shifting will be smooth. The foot switch can also be used to keep the converter locked up going down a grade, thus giving you a little hold-back power. When I had my 99 truck my foot switch (wired in series with a throttle switch) also operated an exhaust brake - a great combination. - John
  23. Yes, you can. I have had mine wired with a manual momentary toggle switch since the truck was new. It is simple to do and works very well. Since your truck is an 02, you should be able to use the attached wiring diagram. Find the two relays that control the intake heaters. They are located just below the driver's side battery and power distribution center. You will see the two relays side by side, each with two small gauge wires and push-on connectors. One wire on each relay comes from the ECM (12 volts when commanded) and the other wire on each relay goes to ground. Remove the two wires from the ECM side of the relay and protect them from the elements (the wires will no longer be needed). The wire colors (according to the diagram) are orange with a black tracer and yellow with a black tracer. Sometimes colors differ slightly. From an un-switched 12 volt source add a fuse, a momentary switch (your choice of location), and enough light gauge wiring to complete the job. The wiring and the switch will only need to handle less than 150 milliamps of current. Coming from your switch, connect to each exposed terminal of each intake heater relay The terminal posts are threaded, so you will need to provide a nut with the proper thread pitch for a secure connection. Codes P0380 and P0382 will be set, but should not activated the CEL. - John
  24. A couple of thoughts: * What happened to the alternator 30,000 miles ago that it needed brushes and bearings? * Disconnecting the alternator output wire and then running the engine is never a good idea. The field circuit for the alternator is controlled by the ECM and could easily damage the ECM. Before you remove the alternator you can inspect the alternator output wiring and fusible link as you mentioned, as well as inspecting the ground circuit and the field wire to the ECM. You could use a jumper lead from the alternator case to a battery ground as a test to bypass a potential ground circuit problem. - John
  25. I understand and I like having a simple circuit, but are you not concerned about having only one fuse for all of the headlights? If that fuse blows for any reason, it could be exciting getting your truck stopped. Also, are you using heavier gauge wire from the 87 terminal of each relay to each headlight, or are you tapping into the existing very small wiring to each headlight? - John
