Borgeson steering box
I installed a new Borgeson steering gear box on my truck a few years ago. You may not be getting what you think you are getting, but I think you will like the steering gear box either way. Borgeson sold two different steering gear boxes under the same part number - one is a quick ratio, and the other is a variable ratio. I got the variable ratio. The following information is copied from a post I did for the TDR about three years ago. You may be interested in the read. "Borgeson Steering Gear Box 800120 - Things You Should Know..." Last winter I did some steering and suspension maintenance to give my 2002 truck (then at 215,000 miles) a second life. I upgraded to a Borgeson steering box and a Borgeson steering shaft. At the time Borgeson advertised that model 800120 steering box would reduce steering wheel turns from stop to stop to about 3 1/2 turns. My original steering box that I removed from my truck took 4 1/4 turns from stop to stop, so I was looking forward to a significant improvement. After installing the pitman arm on the new Borgeson steering box I noticed that it took exactly four turns from stop to stop. I thought that was rather odd, so I contacted my supplier who confirmed that only one model was made by Borgeson to fit '94-'02 Dodge trucks. So, I installed it on the truck and gave it a test drive thinking that it would feel much the same as my other one. Actually, it steered much better straight ahead and definitely had a faster ratio when turning sharp which didn't make sense to me because the ratio was only slightly faster than the one I replaced. I contacted Borgeson and explained that although I was happy with the overall results, I was really expecting significantly less turns of the steering wheel - as was advertised. The representative said that the 800120 is the only steering box available for '94-'02 Dodge trucks. I asked if there was someone I could talk to who could explain why the steering box that I purchased takes four full turns from stop to stop. I was transferred to an engineer and during our discussion the engineer noticed that there were two slightly different steering boxes that were being packaged and sold under the same part number (800120). She said that one was a 14:1 ratio (3 1/2 turns from stop to stop) and the other was a variable ratio with a higher ratio in the centered position. Now things began to make sense to me as to why the steering box installed on my truck felt so responsive, but did not meet my expected 3 1/2 turns from stop to stop. The engineer also said that the customer could not choose which one to purchase; either one could be shipped. I thanked her for the information she provided and I offered a recommendation that Borgeson might consider re-wording how the steering box is marketed (specifically the 3 1/2 turns statement). Even though my initial expectation was for a faster ratio steering box, I am still very satisfied with what I received. I just wanted to let other Dodge truck owners who are considering upgrading to a Borgeson 800120 steering box that I believe it is a very good upgrade, but one may receive a steering box different from their expectations. - John
Hard start after grid heaters disconnect
I just realized that I gave the incorrect information in the above post. As of 7:25 pm I have corrected that post. I should have said that I installed a switch that supplies 12 volts to the control relays for the air intake manifold heater solenoids (I erroneously said that the switch grounds the air intake manifold heater solenoids). Below, you will see the text I copied from a post that I did several months back. I did not have to splice any wiring.. "Find the two relays that control the intake heaters. They are located just below the driver's side battery and power distribution center. You will see the two relays side by side, each with two small gauge wires and push-on connectors. One wire on each relay comes from the ECM (12 volts when commanded) and the other wire on each relay goes to ground. Remove the two wires from the ECM side of the relay and protect them from the elements (the wires will no longer be needed). The wire colors (according to the diagram) are orange with a black tracer and yellow with a black tracer. Sometimes colors differ slightly. From an un-switched 12 volt source add a fuse, a momentary switch (your choice of location), and enough light gauge wiring to complete the job. The wiring and the switch will only need to handle less than 150 milliamps of current. Coming from your switch, connect to each exposed terminal of each intake heater relay The terminal posts are threaded, so you will need to provide a nut with the proper thread pitch for a secure connection." Good luck with the project, - John
The only benefit to this method is that no codes will be set, but as you see, you don't get to use the grids when you want them or need them. I chose to wire in a momentary switch and mount it on the steering column. The switch supplies 12 volts to the air intake manifold heater control solenoids so that I get to choose when to use the grid heaters. Yes, codes P0380 and P0382 Intake Air Heater Relay #1 & #2 Control Circuit are set, but the check engine light stays off. To me the benefit of being able to have control over the grid heaters far outweighs having two codes permanently set. The momentary switch has been operational since the truck was new. - John
Brake upgrade option & opinions
You should have a 48RE transmission. You can compare gear ratios in the chart below. Even if the torque converter could be locked in every gear (simulating a manual transmission), you still would not get the braking that a manual transmission would give. However, if you can modify your transmission to lock in all gears, then 1st gear with an exhaust brake would help you in the 10-20 mph range. Study the gear ratios. Note that 1st gear in the 48RE is in between 2nd and 3rd gears on the manual 5 spd and 6 spd.transmissions. Hope this helps, - John
I agree with you on the exhaust brake, but we have manual transmissions - yours a 5 spd, mine a 6 spd. We can use every gear to our advantage which really enhances the exhaust brake performance. Baja has an automatic transmission (stock I think), so only four gears and the first two gears are probably without converter lock-up capability. The grades he mentions are " winding, narrow, long 15+m and steep, + 8% in parts". In these situations I don't think an exhaust brake will help him much without doing some major transmission modification. On more popular highways where the grade typically maxes out at 6 or 7 per cent and curves are more gradual, the exhaust brake would really help him out, providing he can manually lock up the torque converter. I know that you already know all this, but I just didn't want the guy to get his hopes up thinking the exhaust brake would work as well with his automatic transmission as it does with a manual transmission. - John
Maintenance/performance upgrades
Those were supposed to go on the fuel lines..... Anybody knows that magnets won't work on plastic lines - Dieselfuture, you were right!
Everyone post a picture of your truck!
I am assuming the turbo whistle is a pleasing sound to your ears, not an annoying one. Which turbo model do you have? - John
All turbos should sound like this! Mine doesn't - I'm jealous! - John
Turbo blanket?
I never have taken any decibel readings. I have done small things over several years to tame some of the harsh sounds that the Cummins engine emits. My focus has been to do things that reduce the source of the sound. For example, I have not spent a lot of time and money in attempts to insulate the cabin from the noise of the engine because when you roll down the window or step outside, all of that engine noise is still there. Instead, I have tried to reduce the noise from the engine right at the engine itself. The valve cover and especially the oil pan act as speakers and really do transmit a lot of engine noise. The best material for insulating those items would contain some dense solid mass (like lead) to have the best results; however, the additional weight is usually not desirable, so we compromise. When I worked around heavy equipment in the high country of Colorado, I could hear that an idling 3208 Cat engine with an insulated oil pan was much quieter than one without it. I didn’t need a decibel meter to observe that. Adding Mopar1973man’s IAT resistor circuit reduced engine noise during cold weather (around 50 degrees and especially colder) by modifying engine timing. An excellent idea – thank you Mike. I made and installed a length of ribbed plastic 3” drain pipe inside the BHAF. This pipe reduced engine air intake noise in the same manner a muffler does. It also reduced exhaust brake noise that backfeeds into the intake side of the engine. It is the combination of these additions or modifications to the engine that have reduced the overall unwanted noise coming from the Cummins engine that I can’t live without. I can tell you that if my truck is parked by another 24 valve second generation truck and both engines are idling, my truck will be quieter inside and outside. Each modification or addition by itself offerd small benefits in engine noise reduction, but when added up, the difference was noticeable even without using decibel meter before and after. Probably the one thing I miss most now is the turbo whistle – it is gone, and it is the one sound I liked! John
Turbo blanket?
I have a heat blanket covering the exhaust manifold, turbo charger (exhaust side), exhaust down pipe, oil pan, and valve cover. This heat blanket is designed to easily withstand temperatures well above 2,000 degrees F., so the material does not deteriorate. The heat blankets were custom made and installed by Advanced Thermal Products in Irvine, CA The engine compartment runs considerably cooler, the seals in the exhaust brake vacuum cylinder no longer get scorched, and the passenger side floor now stays cool when pulling a long grade on a hot day. My wife likes that. I also removed the homemade heat shield protecting the BHAF as it is no longer necessary. There are noise reduction benefits, as well. The raucous idle clatter is subdued when standing outside of the vehicle as well as when sitting inside or driving down the road with the windows up or down. My wife likes that, too. The purpose for covering the valve cover and oil pan was for engine noise reduction only. The purpose for covering the exhaust components was for heat reduction in the engine compartment. There was some noise reduction benefit, as well. I can't make any claims as to the turbo spooling faster or that it is more efficient, but the turbo performs well (spools up early) and EGT's stay under 1200 degrees on a long grade pulling hard. This is with stock injectors and the Smarty programmer set on SW5 with default timing and fuel duration. As far as turbo cool down, it is always below 350 degrees by the time I park the truck, so I don't treat the cool down period any differently than I did before the heat blanket installation.. I can't compare EGT before and after the exhaust blanket installation because I had the EGT gauge and Smarty installed after the exhaust blankets. The blankets have been in use for over 45,000 miles and over two years. In my opinion the benefits are worth the money. - John
Limp mode with codes
I would go to the Blue Chip Diesel site for VP44 and other components diagnostic chart. There is very good information at this site. Also, you will want to confirm that batteries, battery connections, grounds, etc. are all in good operating condition. Others will chime in soon to help. - John
How to heat my shop?
I have a shop heated with a wood stove and I work in it almost every day. The shop is considerably smaller than yours, but the idea is still the same. The shop is 36’ x 30’ with 14’ eve walls and a 17’ peak. There is also a 200 square foot room with a 10’ ceiling attached. The total shop area is just under 1300 square feet. The building is a pole barn style (girts and purlins) with metal roof and metal walls. For the ceiling (roof) insulation, I have R25 fiberglass batts placed between the 2 x 8 purlins (24” on center) covered with white plastic sheeting. For the walls, I contstructed 2 x 4 inner walls (16” on center) which provided space for 5 ½” fiberglass batts for insulation (the extra 1 ½ inches of space came from the width of the girts). I covered the wall studs with OSB sheeting so I could hang anything on the walls anywhere I wanted. I also installed a commercial ceiling fan about three feet down from the peak of the ceiling. The woodstove came from my house when I upgraded to a larger woodstove in the house. The woodstove in the shop is a Regency 2400 series with a 75,000 BTU capacity. I also live in the Pacific northwest (the Willamette Valley in western Oregon). I can tell you that on a day that barely makes the freezing mark, I can easily keep my shop at 70 degrees. The air is always dry, even when you walk in first thing in the morning. The ceiling fan is a must; I reduced my firewood use about one-third after I installed it. Also, the ceiling fan makes the temperature throughout the shop much more uniform. I know that you are trying to do something for the interim, but with the size of the building you have, I think I would put all my energy toward the final product. I think I would get the walls and ceiling to at least an R21 rating, otherwise the shop will be difficult to heat no matter which choice of heating source. If you use portable propane or kerosene heaters for the interim, you will be adding moisture to the air. That heated air with the added moisture will likely condense on objects far away from the source of heat. - John
Well the Order is in
I will be replacing mine very soon as a maintenance item - no sense in taking a chance for unnecessary damage. You must have treated your clutch right! I see by your signature that you have a six speed. What brand is your replacement clutch and how do you like it? - John
So far I have 288,000 miles on my original factory clutch. How many miles do you think you will get from your original factory dual mass flywheel? Sorry..., I just had to ask. Enjoy your new ride! Will you still help us out with questions about our ancient trucks? - John
Installed a Nations alternator - results
13766-180HP. It must be the 180 horsepower alternator for the V6 Cummins 24 valve. - John
High amp alternator
I have also wondered why I have not experienced some of the electrical problems that many others have. I bought my truck new and right away I put the grid heaters on a manual control switch. I very rarely use the heaters. And, like you, my alternator (a Bosch) has never given me trouble. I replaced brushes and bearings (only for maintenance, the alternator was working fine) three years ago at 216,000 miles. I am currently at 285,000 miles and the alternator passes your AC voltage test. I never tested for AC output until I came across your website and I will be keeping a close eye from now on. - John
A/C leaking
That's the trouble with this site - lots of information tossed around about the beer, but no information of any value; like, where is the beer and who is bringing it? - John
A/C leaking
I understand your dilemma here. If you replace a component and then recharge the system with refrigerant and it slowly leaks out, you will have three choices: go to an AC shop to recover the remaining refrigerant (the best solution, but costs money), wait for the remaining refrigerant to leak out (could be a long time), or intentionally dump the remaining refrigerant into the atmosphere (an environmental no-no). This same issue is what got me to start looking for a used R134A refrigerant recovery machine. I found a used Snap-on ECO 134 A for $650. It came with a new 30 lb tank full of R134A and a 20 lb recovery tank, lots of AC parts, seals, gaskets, tools, etc. This particular machine recovers, filters, and recharges refrigerant. It has a very accurate digital scale that measures refrigerant in ounces for recovery and recharging purposes. It is capable of collecting and releasing non-condensable gases and has an oil separator. It also comes with a vacuum pump for removing non-condensable gases, moisture, and for performing the leak test. When I was looking for a recovery machine I actually ran across two of this specific model Snap-on machine - the second one went for $250 (it had no extras). So, there are good used recovery machines out there and they cost a lot less than I expected. For me the refrigerant recovery machine has given me peace of mind because I now do not have to worry about the high cost of repairs and I can keep all of my vehicles charged with the proper amount of refrigerant at the beginning of each summer season. - John
A/C leaking
How many miles on the AC components, especially the compressor? Last spring I had some of the same concerns that you had. I knew I had a refrigerant leak, but I didn't have any means to find it. I ended up buying a used Snapon 134A recovery machine at a reasonable price. Since my truck had the original Denso AC compressor still on it with over 260,000 miles, I decided to change it out with a new Denso unit. I then pulled a vacuum on the system; it passed the test so I recharged the system with 30 oz of refrigerant. I drove the truck for 600 miles and then recovered the refrigerant. I pulled out 30 oz, so I knew I had found the leak. Later, this fall I replaced the heater core. Again, I recovered 30 oz of refrigerant confirming that I had found the leak. When I replaced the heater core, I did not replace the evaporator core because it looked to be in very good condition. Time will tell whether or not I made a good decision. So, if you have high mileage on an original compressor, I would start there. The condenser would be the next likely place if it has never been protected by a screen. I believe that the o-ring connections on all of the line fittings are pretty reliable since there are two o-rings on each fitting. I have read that some people have had evaporator core failures. I would suspect these failures could be from some rubbing in the housing or from debris packing into the core since the evaporator core is the first place unfiltered air comes into contact with after passing through the blower fan. - John
Smoke and runs rough
Since you just installed the engine, I would check all air intake connections for the charge air circuit for boost leaks from the turbocharger outlet to the air intake plenum on the engine. - John
Brake HydroBooster Rebuild
Excellent write-up! ... and complete with photos and wrench sizes. I know that I will have to address this at some point in time due to the age and miles on my truck. This is the kind of information owners of older trucks need to help keep repair costs down. Thank you. - John
Crossing Headlights
It is true - there is no horizontal adjustment. My guess is that there has been some minor body damage on the left front side or right front side of your vehicle and that damage has misaligned one of your headlights. With your low beams on at night, can you tell which headlight is aimed correctly and which one is out of whack? It is likely that only one headlight is the problem. When you make this check, do it when it is not foggy. Thick fog can distort what you see. First make sure that you have the correct bulbs and that they are installed properly. Then inspect the area around each headlight to see if any of the headlight fixture's fasteners are loose, out of place, bent, broken, or missing. Worst case scenario is that you may have to take some things apart and reshape some body parts to correct the alignment. - John
So I made a decision
I did do something similar back in 1988. I wanted a pickup or a van with a diesel engine and I became very frustrated at the choices available at the time. Choices like a heavy V8 engine, no turbocharger (really!), three speed transmission, all accompanied with lots of noise, smoke, high rpms and … no power! Just what I wanted. So, in the spring of 1988 I purchased a new Cummins 4BTA engine kit and put the engine in my 1984 Ford E150 van with a factory 4 spd manual overdrive transmission. I drove with this configuration for 87,000 miles (by then I had 212,000 on the vehicle). I lived in Leadville, Colorado (elevation 10,000 ft) at the time. With the Cummins engine, I could drive up a 7% grade at 65 mph in overdrive, and still accelerate! And no smoke! I was a happy camper. The van had two factory fuel tanks, one 18 gallons, the other 22 gallons. On one occasion after driving back and forth from home to work for a week (50 mile round trip) and then going on vacation traveling on top of the Grand Mesa pulling a small trailer with two ATV’s, I drove just over 1,000 miles without refueling. I netted just over 29 mpg on that fill-up. In 1991 I bought a new Ford F150 Extended Cab 4X4 and immediately swapped in the Cummins engine. Everybody thought I was nuts. I drove that truck for over 200,000 miles and then sold it. I kept fuel logs for over 100,000 miles of driving. The overall fuel mileage for the first 100,000 miles ( which including all driving and idling) averaged out to 22.5 mpg. It was a great engine! My next vehicle was a new 1999 Dodge with a Cummins. Somebody finally did it right! - John
Purpose of lockup switch
My 6 spd manual transmission locks up in every gear, even reverse! However, it is very annoying the way you have to unlock it - you can't just flip a switch. If you don't unlock it during shifts, it makes grinding noises. - John
