Tractorman
  1. Great - glad you like it. I noticed that the switch you ordered is waterproof. I have a windshield on my truck, so I don't need waterproof switches inside. Actually the switch you ordered is a good looking switch with the illumination around the push button. I am jealous. - John
  2. Although I have not resolved this problem, this article has given me a solid direction of diagnostics to narrow down the problem. Thanks, - John
  3. A friend of mine is the second owner of a 2007 Cummins 2500 truck, 4x4, auto transmission, - all stock parts. He purchased the truck in January of 2013 with 104,000 miles on the odometer. The odometer currently reads 205,000 miles. A tuner has been disconnected from the engine for troubleshooting purposes. Until recently, the truck has started and ran well. I am trying to assist him to diagnose the following problem. In early December, he notified me that the truck started to run very poorly just as he was arriving home. He recorded these codes: P0205 Fuel Injector 5 Circuit P2149 Fuel Injector Group 2 Supply Voltage Circuit Using a multi-meter he checked the resistance of all six injector solenoids for comparison. All were normal except for cylinder #5 which showed a high resistance. On December 15th he replaced that injector solenoid with a new Bocsh unit. After the repair was completed the engine would crank over, but would not start. He said the starter seemed to be cranking at the normal speed. On December 17th he was able to get back to the project. He primed the fuel system with the lift pump using the “bump the starter” technique for about 25 seconds. With battery jumper cables hooked up from another vehicle the engine started quickly and ran smoothly. All seemed well. He drove the truck for about 15 miles over the next couple of days. It is a couple of days later and he notifies me and says that “check gauges” light came on and the engine oil pressure was reading very low. He checked the oil level and found that it was way over the full mark. At this point I recommended to not drive the truck and I would come over to his house and assist. I checked the engine oil level – it was very high and diluted with fuel. I removed #5 injector solenoid to inspect the two o-rings. The one on the injector looked like it had a possible tear, so I installed a new one. The o-ring in the nut looked fine. I re-installed the injector solenoid and placed the valve cover on loosely, started the engine, and then shut it off about a minute later. I then removed the valve cover and restarted the engine to check for possible fuel leaks. Right away I noticed fuel coming out of the top of #5 injector solenoid. I realized then that the ball and set screw must be missing. Since my friend had already discarded the old injector solenoid, I removed #1 injector solenoid and removed the set screw and ball for a sample. We went to the hardware store and with luck we were able to identically match both the ball and set screw. We put everything back together and went to start the engine. The engine would crank, but not start (just like a few days before). Except, this time after many, many attempts it will not fire at all. We have now hooked up a battery charger to maintain the charge. A few minutes later I crank the starter for a longer period of time and the engine catches, but only on one cylinder and is detonating as if the timing was extremely advanced. I release the key and the engine continues to barely run in this manner. A few seconds later I turn off the key because none of the other cylinders are picking up. During the time the engine was running, heavy white smoke was coming out of the exhaust. A few seconds later I crank the engine, but no fire at all – just like before. I do a few more short starting attempts and have the same result – no fire on any cylinders. I am beginning to wonder if there is an injector leaking fuel into a cylinder causing low rail pressure and early ignition in that cylinder. I decide to do an experiment. I disable the grid heaters and remove a through bolt on the intake manifold so I can get close to the cylinders with a small shot of ether. The idea is to get the engine to spin faster to build rail pressure. I have my friend start spinning the starter and I give a quick shot of ether into the intake manifold. I hear the smooth clatter of all cylinders firing briefly and the engine begins run again on only one cylinder, barely carrying itself, and detonating just like before with white smoke out of the exhaust. At this point I am stumped. I am having trouble believing that replacing an injector solenoid would cause this symptom, especially after the truck ran fine for a couple of days despite the internal fuel leak. Is it possible for an injector to have been leaking a small quantity of fuel into the cylinder for awhile (even before the injector solenoid replacement) and is now showing its ugly head? I don’t have any access to the necessary test equipment to perform some of the tests that will probably be recommended on this forum. I would just like to hear from anyone who might be able to tell me if I am on the right track, or anyone who could get me started on the right track. My friend just called me and said he just read the codes with his newly purchased scanner. The only codes currently displayed are P0201 through P0206 (Fuel injector 1-6 Circuit) and the code for the disconnected intake heaters. I apologize for the long post, but I did not want to leave out any information that could help. Thank you in advance, - John
  4. Those studs are threaded - I just don't remember the diameter and pitch. I do believe they are metric. I have a used bolt / nut / washer bin and I just sorted through the nuts until I found two that fit. You could probably find a nut on your truck that fits (not the one behind the wheel) and then match that nut to a couple of them at a local hardware store. Let me know how it works out and what you think. - John
  5. "So from what you said, ecm must trigger power wires to energize coils and not the grounds" .... Yes. This brings another question that I may have asked, did you tie in both positive coil wires to a single switch? .... Yes. The two positive wires from the ECM are not used - I removed them and sealed the ends for protection. I ran a light gauge wire from a "hot" source, through a fuse (5 amp is adequate), and then to the momentary switch. From the switch, I ran a light gauge wire to one of the exposed coil terminals. I ran a jumper wire from that terminal to the other exposed terminal. So when you push a button you're energizing both grids? .... You got it! Now you can be the boss and tell them electrons when to flow! Your alternator will thank you. - John
  6. I have used a toggle switch for operating grid heaters since my truck was new. My switch is a momentary switch that is fused to a hot source. This way I can engage the grid heaters without turning the key to the "on" position. Being that the switch is "momentary", the switch cannot accidently be left on. The two codes that are set are inconsequential. This setup has worked flawlessly for 17 years and over 300,000 miles. No unnecessary post heat cycles and a lot less stress on the alternator - I wouldn't have it any other way. - John
  7. If suspension components are in good condition and the track bar is too short: * The axle will be pulled toward the driver's side of the vehicle and remain there. * The bottom of the sway bar links will follow the axle making it appear that the top of the links are leaning toward the passenger side of the vehicle. This relationship will not change after you have driven and parked the truck. For clarification, the track bar has only one purpose. It controls only side to side movement between the front axle and the chassis / cab, but still allows for up and down movement of the axle. So, if the sway bar links are sometimes tilted, but the axle is remains centered all the time then the track bar is not the problem. It could be as Dave110 suggests, that the sway bar is sliding in the bushings that mount it to the frame making it appear that the axle is moving.. It is easy to get off track when diagnosing suspension problems. At this point I would start from scratch and document your observations in detail. For example, in your first post you mention that the axle has shifted to the driver's side 1 1/2 inches and the sway bar links are tilted (this is very significant). Later you mention that the sway bar links are sometimes tilted and are sometimes straight, but you don't mention anything about the axle shifting to the driver's side or whether the axle is centering when the sway bar links are straight. - John
  8. Are you absolutely positive the axle was centered and the sway bar links were vertical when you first installed the track bar? Also, is this the first time the track bar has been replaced? There are two reasons that I ask this question. One reason is that if everything was aligned correctly and then shifted at least 1 1/2 inches over within a month, something very significant had to happen - like a coil spring broke, or something. The other reason I ask is that I replaced a track bar on my brother-in-law's 2002 3/4 ton 4x4 truck (a May build date) and the original OEM track bar that came off of the truck was about 3/4" longer than the replacement track bar. I was replacing a lot of steering components at the time and I did not notice the shifting of the axle and the misalignment of the sway bar links until after I test drove the truck. It took me awhile to figure out what was going on. I ended up removing the replacement track bar and placed both track bars on the floor side by side and found there was a difference in length - about 3/4 of an inch. There is only one stock track bar sold for the second generation 4x4 truck - they are all the same length no matter who you get one from. I know because I checked with three different auto part stores and NAPA bent over backwards trying to solve my problem, but to no avail. I ended up using Luke's Link on the original track bar. If this is not your case, then you can disregard. - John
  9. These trucks should have had an eight or ten speed manual transmissions available from the OEM. Putting a 10 speed Roadranger behind a twin-turboed 5.9 is an excellent combination. Great design and installation - I wish I could drive the truck!
  10. Yes, you should be able to hear an in-tank pump while it is running and you should be able to hear a engine mounted pump running, as well. Without knowing what fuel modifications a previous owner did and if you can't hear an in-tank pump running, then, unfortunately, you will have to pull the fuel cartridge from the tank (as mentioned above). I bought my truck new and the VP-44 failed at 87,000 miles. The dealership replaced the VP-44 and removed the engine mounted lift pump and installed an in-tank lift pump complete with wiring harness and relay - all under warranty. This was the factory fix at the time. Keep us posted... - John
  11. That's good news - I was hoping for that kind of an explanation. Thanks. - John
  12. Yes, I did. It was your suggestion in a different topic that prompted me to do that earlier today. Thanks for that tip. I am going to loosen more supports that hold the fuel line and try the method again. It is just seeping now, but I need to get it stopped. - John
  13. I bought 6 new Bosch RV275 injectors one year ago (the price was right - $425 for the set) and finally installed them last Friday. The original injectors operated for 303,000 miles and had never been removed. They were still performing well – as in smooth idle, good power, and good fuel economy. I didn’t want to push a good thing too far. The job went smoothly with the help of this site. All of the old injector tips were clean considering the miles and years on them. I did notice however, that there is a black coating of something kind of oily / powdery (not sure what it is) in the intake area just below the grid heaters. It is not present in the air horn and the hose from the intercooler – they are very clean. I wonder if worn valve guides combined with lots of exhaust brake usage could be the cause. Maybe someone who has had experience with this can shed some light. The marks are from me using a scraper. I am having a problem with a very small leak with #1 injector line at the injector. When I removed the injector lines, I did it in groups of three, but I left all of the blue clamping points tight. When I put everything back together, the connection at the #1 injector showed signs of leaking (wetness on the head around the fitting) on a 5 mile test run. So, I loosened the #1 injector line at the injector and loosened the blue clamp nearest the injector and then tightened the injector line followed by tightening the blue clamp. No evidence of a leak on a 5 mile test run. However, after a 50 mile trip the head is slightly damp around the injector connection. I will try again, but this time I think I will loosen the clamps and the mounts and repeat the procedure to get the leak stopped. If anyone has any tips, please speak up. I like the performance of the RV275’s. I immediately dialed the Smarty tune back a setting. OEM injectors: SW5 – Torque Management 5, Timing 1, Duration 5 RV275 injectors : SW3 – Torque Management 4, Timing 2, Duration 2. Smarty Settings: Torque Management (1-6) Each higher number incrementally reduces torque management at low engine rpm’s. Example: TM-6 equal zero torque management and allows for high torque at low rpm’s. Timing (1-4): Each higher number incrementally advances ignition timing . (#1 is stock, #2 is stock with after market injectors) Fuel Duration (1-5): Each higher number incrementally increases fuel duration. (#1 is stock) The RV275 injectors definitely deliver more fuel. So far, the tune I am using with these injectors is performing well, lots of torque on the low end easy to drive without smoke. I am setting the tune as to how I drive with a manual 6 speed transmission and operating engine rpm’s between the 1500 to 2000 rpm range for almost all driving conditions. I will post more information as I get some miles on the new injectors and let you know which tune I end up with. - John
  14. I don't see a problem with the alternator - it looks to me like it has a quick-connect feature. - John
  15. I agree, and that is my method. I have jump started many vehicles in this manner. I still have the original Bosch alternator (brushes and bearings at 215,000 miles) with 303,000 miles on the alternator now. - John
  16. Some things that your video doesn't show... * You say "some hesitation starting" - does that mean the starter is cranking slowly?, or is it cranking at normal speed and just takes longer for the engine to start? (Starting the video before you turned the key would help us diagnose.) * Are you operating the throttle or is the engine going to high idle on its own? * What is the ambient air temperature? Is this a cold start? - as in the first start of the day? I am going to assume some things here. It was the first start of the day. You waited to start the engine until the "Wait to Start" light went out. The starter cranked for a longer than normal period of time. When the engine started either you brought the engine rpm up and held it there or the high idle feature was enabled. (Thanks KATOOM for this information) So, if this was your procedure, I would say that the alternator was charging normally throughout the duration of the video. The grid heaters would have drawn 200 amps while waiting for the "Wait to Start" light to go out. The starter would have drawn about 400 amps while cranking. After the engine started the post cycling of the grid heaters would have begun - again drawing 200 amps continuously because of the high idle. The alternator puts out 136 amps maximum - much less than the 200 amp draw from the grid heaters. The battery voltage falls to around 12 volts and remains there ( as it should) because the alternator that really is charging just can't keep up. The grid heaters draw whatever current is available from the alternator (which is not enough) and draw the remaining current from the batteries which drops the voltmeter down to around 12 volts and holds there.. I noticed in your video that when you said the alternator just kicked in, it appeared that the engine had dropped to an idle and the grid heaters had cycled off just a moment before. That would explain the rise to 14 volts in the voltmeter. If the starter is cranking slowly, then I would be looking at batteries that are in poor condition, corroded or loose wiring connections, worn starter contacts, etc. - John
  17. Only the people near sea level elevation have the rounded figure of 14 psi. Where you are in Colorado Springs, the atmospheric pressure is about 11.8 psi. Just being technical. - John
  18. I think the "0" pump pressure and "lost power and started smoking" symptoms are likely to be from the same problem since they occurred at the same time. If the fuel flow to the VP-44 is restricted for whatever reason, it could cause the "bluish" smoke. - John
  19. You only need to turn the steering wheel back and forth enough to load the steering linkage (no more than 30 degrees each way). The friction of the tire to the ground helps to load the linkage. This way you can use your wife's cookie sheets for other things. - John
  20. You will get better "real life" test results if you set the vehicle back onto ground for the tie rod end, center link, drag link, and track bar checks because the joints will have to do some actual work. I block the rear wheels, set the park brake, and have someone operate the steering wheel back and forth with the engine running while I perform the inspection. I like your method for checking suspension ball joints and wheel bearings. - John -
  21. Still have the "Y" style myself - just over 300,000 miles still on original left and right tie rod ends, have replaced center link and drag link once. Of course I am using those ridiculously small tires recommended by Mopar1973Man and the goofy sticker on my driver's door. - John The above post was an attempt at humor. - John
  22. Set the voltmeter to display AC millivolts (not DC) - John
  23. Stick with your previous procedure. As IBMobile says, Fuse #10 (50 amp) goes to the part of the ignition switch that gives power to the BLk/WHT wire that you were testing. Test it again with Fuse #10 pulled. Post your results. One step at a time... - John
  24. I have made assumptions on what you are testing, what tool you are testing with, how you are connecting with the testing tool, and the state of the connection with the ignition switch. I have made these assumptions (correctly or incorrectly) because you did not state the details. Here are my assumptions about your test: * You are using a multi-meter displaying voltage. * You are testing the output of the ignition switch, specifically the black wire with the white tracer and the light blue wire shown in the wiring diagram provided by Mopar1973Man. * You are performing your test with the wiring harness connected to the ignition switch (normal condition). * The ignition switch is in the off position. * Your multi-meter black test lead is connected to a known good ground * You are probing the BLK/WHT wire with the red test lead and you are recording 11 volts. * You are probing the LGTBLU wire with the red test lead and you are recording 10.7 volts. If this is how you are doing your ignition switch test, then your recordings may not be conclusive because the multi-meter does not place a load on the circuit - you could be reading stray voltage, or a back feeding voltage. By simultaneously connecting a test light at the same connections as your multi-meter, you can place a small electrical load on the circuit, thus eliminating any stray voltage. * If the test lamp does not light and the voltage drops to zero, then the ignition switch is not likely the problem. * If the test lamp does light and the voltage remains the same or near the same, then the ignition could be the problem, OR, another circuit could be back feeding. - John
  25. Not necessarily - for a couple of reasons.. For clarification, I am assuming that you are performing the ignition switch tests with the wiring harness connected to the ignition switch. A multi-meter does not load the circuit when performing a voltage test. Consequently, stray voltage can influence the test results. Using a test lamp simultaneously with the multi-meter will be beneficial here. If the test lamp does not light and the voltage drops to zero, then the ignition switch is not likely the problem. If the test lamp does light and the voltage remains the same or near the same, then the ignition could be the problem, OR, another circuit could be back feeding. Electrical troubleshooting can be a challenge. You need to be diligent in following specific steps and always double check your work along the way. - John
