Tractorman
  1. If I understand correctly, that junction connecter supports a few fused circuits and some other circuits. I don't see anything stopping one from bypassing just one damaged circuit and leaving the rest intact, just as long as the new circuit has the proper size fuse and wire gauge. - John
  2. I figured you did know that, just thought it worth a mention. I am glad that the miss was something simple - you probably had all sorts of things going through your head on that test drive, and none of them good. When I was in my late twenties, I owned a mobile auto repair business for a few years and many times I found myself working in less than desirable weather conditions; so I hope you are feeling good about what you have accomplished working in the elements under the canopy. - John
  3. The pushrod absolutely needs to be straight, as it rotates constantly while in operation to ensure uniform wear on its mating surfaces on both ends. - John
  4. Sounds like there might be a trend here - thanks for the heads up... - John
  5. It doesn't sound like the intake valves were held open - that's good. Were you able to rotate the afflicted pushrod to see if it is still straight? If the pushrod is straight I think you are good to go. The raw fuel symptom makes sense - no fresh air entering the combustion chamber. - John
  6. I don't know you that well, so I would never treat you like others do. When you are done, are you going to put the roof back on the chicken house? - John
  7. I understand that you are very concerned that the event won't happen again - I would be concerned, too. A poor ground at a single connection that combine multiple circuits could cause electrical components to randomly not operate properly. Heat could build at the poor ground connection, but I don't think it would cause heat to build in joint connector #2. There could be two ways for heat to build in joint connector #2. 1. If the connection in joint connector #2 was corroded or cracked, then normal current flowing in that circuit could generate enough heat to damage the connection. 2. If higher than normal current was flowing in that circuit, but still less current than the properly rated fuse, then heat could be generated anywhere in the weakest part of the circuit, including joint connector #2. Since there are multiple connections in joint connector #2, you could re-inspect the damaged connector to find out exactly which wires were involved. Then you would only need to inspect the wiring and components downstream from the damaged connection. Also, you should make sure nobody has added an additional electrical load to that circuit. - John
  8. The bad ground is a good find on your part - it definitely needs to be addressed. Can you expand on why you think this bad ground caused the meltdown in joint connector #2? - John
  9. @Daleb, I am not sure of what you are trying to accomplish and I think that you may be chasing your tail here. Are you still trying to find a short to ground? I ask because I don't think a short to ground exists. Are you trying to figure out why joint connector #2 failed due to heat? If you are, I think I covered that in my previous post - basically, that a poor connection (in this case, joint connector #2) in a properly operating circuit can cause enough heat to destroy that connection. A test light can be a valuable tool for troubleshooting. But, if the circuit being tested is not fully understood and / or if the testing tool limitations are not fully understood, then the test results can be useless. Most test lights draw very little current, probably about 250 milliamps on average. There are control modules on your truck that draw more than 250 milliamps (combined) after the ignition switch is turned off. These modules will continue to draw power that will easily make a test light glow for a up to a few minutes after the ignition switch is turned off. Even when the modules finally go to sleep they can still draw up to a combined total of 35 milliamps, enough to make a test light glow dimly. Different levels of trim on a truck can affect the number of control modules a truck has, as well - for example, a truck with a security system and a premium sound system will have more control modules than a base model truck (like mine). Electrical problems can be frustrating, but sometimes I get so involved that I can be my own worst enemy. - John
  10. Looks like you might be one of those one million mile guys not to far in the future. I don't know if I will live long enough to accomplish that with my truck - I just recently cleared 300,000 miles. - John
  11. We will be looking forward to hearing it run... How many miles on your truck? You may have already said and I just don't recall. - John
  12. Actually by just following the procedure, you have already reduced compression on the head gasket on the first fasteners when you have completed the first round of torqueing to 77 ft/lbs. - John
  13. Back to @dripley's first post regarding the head bolt torque procedure. I am sure he wants to know the correct procedure - I would, too. Although service manuals are a great resource for making a quality repair, sometimes clarity is lacking in instruction, or sometimes words or phrases are used that have different meanings for different people. When I am in doubt, I like to approach things from a fundamental point of view - in this case, the point of view of a fastener. The purpose for applying a specified torque value to a fastener is to make sure the fastener maintains its designed clamping force for a long time during normal operations when vibrations and thermal expansions / contractions are occurring. A fastener can be brought to 77 ft/lbs of torque in a dynamic state. If a person wanted to increase this torque to 82 ft/lbs of torque from a static state, then the person may find that the fastener does not move when 82 ft/lbs of torque is applied. This is the result of static friction. If the fastener does not move with 82 ft/lbs of torque applied, it is still holding a clamping force of 77 ft/lbs . It is kind of like trying to slide a heavy box on a smooth floor. It takes more force to get it moving than to keep it moving - static vs. dynamic. The following example is hypothetical and I make certain assumptions for clarity: In the case of installing a head, the fastener is to be clean and lightly oiled to ensure a uniform clamping force for each of the fasteners when tightening the fastener to a specified torque. * First, all fasteners are brought to 77 ft/lbs of torque using the proper torque sequence. At this point, the first fasteners that were torqued will have lost some of their clamping force. These fasteners will not be "loose", but for sure, their clamping force will have been reduced somewhat at this point. Procedure A: If the same 77 ft/lbs of torque is re-applied in the same sequence order, the first two or three fasteners may turn because the static friction is overcome by the 77 ft/ lbs of torque being applied. These fasteners will torque properly because they are in a dynamic state when 77 ft/lbs is reached. The next fastener may not move when the torque of at 77 ft/ lbs is applied. It could very well be that this fastener's real clamping force value has been reduced to 70 ft/lbs of torque, but static friction will not allow the fastener to turn with 77 ft/lbs of torque applied. This fastener will maintain its clamping force of 70 ft/lbs of torque. Procedure B: Starting in the same torque sequencing order, if each fastener (one at a time) is loosened only enough to allow for a dynamic torque to 77 ft/lbs to be applied, then each fastener will have a more uniform clamping force. Procedure B will have a more uniform clamping force for each of the fasteners before the final 90 degree turn of the fastener. I am sure that either procedure will work fine, but I just wanted to show that the results will be different and why the results will be different. One of the great benefits of this forum is that we can gather valuable information and use that information to suit our specific needs. @dripley, what I would do in your situation is just use a cordless drill on the maximum torque setting and run all of the bolts down and call it good. And be sure to re-check them. - John
  14. The FSM is not clear as to exactly how to perform this particular procedure, but I understand what @AH64ID is saying. If you truly want to have the most uniform clamping force throughout the head, then backing off each bolt and re-torqueing to 77 ft/lb will achieve that. From the FSM for my 2002 truck: (a) Torque bolts to 80 N·m (59 ft. lbs.) (b) Torque bolts to 105 N·m (77 ft. lbs.) (c) Re-check all bolts to 105 N·m (77 ft. lbs.) (d) Tighten all bolts an additional ¼ turn (90°) - John
  15. I just switched to RV275's about 6,000 miles ago (303,000 miles on the OEM injectors). They perform well for me. I have never heard of any negative comments about the RV275 injectors. I think there are others on this forum who have run the RV275's and different injectors on the same truck, as well. You will probably be hearing from them soon. I use the SO3 Smarty programmer - the RV275's and the programmer work well together. My truck is a daily driver and is used for towing. - John
  16. Thank you again. I will pass along this information to a friend with a 2011 truck who is considering converting to these headlights. Sounds like you and your family are liking the new truck. - John
  17. Things like this shouldn't be talked about on this forum. It's almost like using profanity. - John
  18. @AH64ID, thanks for the response. What do you think of the low beams alone, without fog lights. How are they for lighting a dark roadway ahead and off to the sides? - John
  19. I do remember that you had trouble with the Joint connection #2 , but don't recall all of the details. However, many times people associate things like burnt electrical connections, melted solder, etc. to a short to ground somewhere in the electrical system. This is rarely the case and here is why. Assume an electrical circuit is protected by a 20 amp rated fuse and a short to ground occurs in the circuit. Instantly an excessive amount of current will flow and the fuse will blow quickly. No evidence of heat is likely to be found because the occurrence happens very fast. Now let's assume the same circuit has a continuous 10 amps flowing through it and is operating normally. Pretend that somewhere in that circuit there is a soldered or push-on connector has a poor connection. Imagine a volt meter connected to both sides of the connector - one side reads 13.5 volts, the other side reads 11.0 volts while 10 amps of current are flowing through the circuit. This equals a 2.5 volt differential across the connection while the connection has 10 amps flowing through it. The result: 2.5 volts (voltage drop) x 10 amps = 25 watts - yes, 25 watts of generated heat at a precise location. What do you think will happen over time? Think of it this way - you can buy a 25 watt soldering gun to melt solder at a precise location. In the second example you will note that the current flowing is only half of the rated fuse and the circuit is operating normally with the exception of the poor connection. A circuit in this status can operate for days or even months without detection until heat does enough damage to break the connection electrically... or start a fire. I don't think you will find a short to ground because I don't think one existed in the first place. - John
  20. No worries. The required grinding is when a Borgeson steering box is being used with an OEM steering shaft. The grinding is done only on the adapter for the steering box shaft - not on the actual steering box shaft. So all is well. - John
  21. I believe you should be good. Just make sure there is no contact with the steering box housing - in the photo everything looks okay. I probably didn't make myself clear about this. Borgeson's instructions aren't very clear about collar you mention. For safety reasons, all steering shafts must be built with a means to collapse in the event of a front end collisions. That is the main purpose of the long slip joint. I believe (because is not clear in the instructions) that the collar is there to stop the upper shaft from sliding down and disconnecting from the upper connection point in the event that the upper set screw backed off. By design the upper connection point is not fail safe. I set the collar on my steering shaft with very slight pressure against the rubber boot. I only snugged the set screw, only because I think it should give in the case of a front end collision. This is what I did - obviously you can decide where to position the collar and how tight the set screw should be. What else is of concern is that (at least on my truck and one other truck) the slip joint was so tight that no axial movement was allowed. Since the steering wheel is mounted in the cab and the steering box is mounted on the frame, there will be axial movement, although small - probably less that 1/4 ". With the sticky slip joint, the energy from the axial movement was transferred to the upper connection point and caused the set screw to continually work loose. It also transferred a random lumpy feel to the steering wheel that was quite annoying. I am rewriting this for clarification and because you didn't say whether or not you tested the slip joint for ease of operation before installation. I have read of two instances regarding the Borgeson shaft becoming loose at the top connection and the shaft actually separating from the steering wheel shaft while the vehicles were being driven. In both instances nobody was hurt. The one instance involved slow in-town driving and the vehicle was braked safely to a stop. The other instance involved mountain driving at higher speeds and fortunately the truck steered itself into the ditch on the uphill side of the road instead of over the several hundred foot drop off. So, I urge you to check for easy sliding operation of the slip joint. - John
  22. Actually, those spacers aren't useless. The exhaust fasteners (bolts) are designed to maintain their clamping force under thermal expansion / contraction and vibration. The hardness, diameter, length, and torque of the fastener is determined by the work it must do. A longer fastener will stretch a farther distance than a shorter fastener of the same specifications when torqued to the same value. It is the length of stretch of the fastener that keeps the manifold tight under all operating conditions. If the spacers were not used to keep the fastener lengths the same, then the shorter fastener (with less distance stretch) will likely become loose because its clamping force will be compromised under certain operating conditions. Using studs with lock washers / nuts or using bolts with retainers - either way, the lock washers / lock nuts or the retainers have nothing to do with clamping force. All they have to offer is if the fastener under a certain operating condition becomes loose, then the fastener won't back out. If Cummins has under-engineered the fasteners, or if the operator runs extremely high EGT's, then there is value in using the lock washers / nuts or using the retainers so the fastener won't fall out. I think either using bolts or studs are equally effective, unless some of the studs are of a shorter length. I certainly see the advantage of using studs for ease of manifold installation. I know I will be doing some head work in the near future. I will probably reuse the exhaust manifold bolts without the retainers and just periodically inspect the bolts for tightness. I think they will stay tight. - John
  23. Yes, that is correct. The internal vane pump generates more flow than can be used by the combination of supplying fuel for the injectors, internal control circuitry, and fuel flowing over the 14 psi relief valve returning to the tank regardless of any fueling demands. Because more flow is being generated than can be used, the pressure must rise to the relief pressure of the internal vane pump (over 100 psi) and flow the remaining fuel to the suction side of the internal vane pump. The lift pump must always generate more flow than the combination of the fuel being consumed by the injectors and the fuel being returned to the fuel tank from the VP44. If the lift pump does its job, there will always be a positive fuel pressure reading at the test port. The remainder of the fuel flow from the lift pump will flow over an internal lift pump relief valve and either return to the suction side of the pump or return to the fuel tank via a separate line. I don't have an explanation for this situation as there are some unknowns here and as you said this happened many years ago. It is possible that under wide open throttle, there were disruptions of fuel flow that the test gauge didn't show. Any disruption of fuel flow could cause bucking. When you added the booster pump, that could have masked the true flow problem and made the symptoms disappear. Just speculation on my part. It is very interesting that you mention this, because I am experiencing a similar condition, but only when towing up a continuous grade with a steady throttle, and not at full power. This symptom has appeared after installing new RV275 injectors. Our definition of bucking could be different, but I am going to try to figure out what is going on and I may even get to the point of adding another lift pump in series just to see if the symptoms disappear. If I do this, I will post the results. - John
  24. Yes, this is correct. Actually, it is not odd. There is a fixed displacement vane pump inside the VP44 injection pump. This vane pump rotates at the same rpm as the VP44 and provides fuel flow for cooling of the VP44 as well as some other duties. The internal vane pump provides much more fuel than is being consumed by the injectors. Consequently, the fuel pressure rises internally and the excess fuel is forced over a relief valve that is set at over 100 psi (not sure of the exact pressure) and the fuel is returned to the suction side of the internal vane pump. The inlet of the 14 psi relief valve is in common with the outlet of the internal vane pump (operating at more than 100 psi), so there is always fuel flowing over the 14 psi relief valve regardless of the lift pump pressure. The primary function of the lift pump is to supply more fuel to the VP44 than the VP44 can consume for cooling and powering the engine under all operating conditions. Since lift pump is flowing more fuel to the internal vane pump than the internal vane pump can use, this flow restriction is what determines the lift pump pressure reading that you see on the lift pump pressure gauge. My VP44 and lift pump were replaced under warranty at 87,000 miles. An in-tank lift pump was installed (a factory decision). The original lift pump was still good - 12psi at idle and 7 psi at wide open throttle at 2500 rpm in 5th gear. The in-tank lift pump tested at 6 psi at idle and 3 psi at wide open throttle in 5th gear. I was not concerned. I ran the configuration this way until 250,000 miles on the odometer and then I removed the in-tank pump and installed a frame mounted FASS 95 g/hr pump with a suction screen. I did this modification to make a roadside repair possible. At this time I also added a low fuel pressure warning switch with an indicator light on the dash. I am now at 309,000 miles. The replaced VP44 has logged 222,000 miles with lift pump pressures that never see anywhere near 14 psi and most of the time considerably less. Also, I have been using the Smarty S03 programmer for the last 50,000 miles and I just replaced the OEM injectors with RV275 injectors. All of the fuel lines are stock and with the exception of a 150 micron suction screen for the lift pump, the fuel filtration system is stock. Back in 2001, Mopar-Muscle posted the results of a test using a flow meter installed on the return line after the collection point of all returning fuel flow. Below is part of a thread out of the Cummins Forum showing the results of two tests. - John Test # 1 well some of you guys ain't gonna like this , especially those led to believe (and those that believe it) ... the bigger is a MUST theory . spent a couple minutes running some tests with a DIGITAL/mechnical flow meter and a MECHNICAL fuel pressure gauge , items under test ... 2000 RAM , DD2's , DD TTPM on level 2 (??) and a HOT PE , ( all levels tested the same at WOT)factory pickup , factory lift pump , factory fuel filter housing unmodified , all banjo bolts intact and unmodified except the banjo to the input of the lift pump is replaced with a 90* swept areoquip type -6AN hose end , the bolt at the lift pump had the schrader cut off and drilled and tapped to a 1/8 npt ( for the gauge) and the banjo fittings between the lift pump and the fitler housing have been drilled to 9/32nd . again all banjo bolts are not drilled out as i have on my ram ( test conducted on the DTT RAM ) . we installed ( LaserBob is helping me and getting #2 fuel poured on his head ) a Sonnex digital flow meter ( inside ID is 5/16") in the return line back to the tank , cut in right at the trans crossmember . gph numbers are fuel returned to the tank . DD2 , DD TTPM (True Torque Power Module) FP volume idle 11 psi 18gph cruise 8 psi 24gph WOT 2 psi 30gph DD2 , TTPM , HOT PE ANY LEVEL FP volume idle 11 psi 18gph cruise 8psi 24gph WOT 0 psi 30gph yes you read that correctly , fuel pressure went to 0 and the fuel volume back to the tank did not change from WOT with 2 psi . the truck did NOT stumble , buck , spit , fart , fall on it's face , nothing , ran like all heck at 0 psi , i will note , my truck ran the same at 0 psi with the DD3's , EZ and a HOT PE . tomorrow we will install -8 lines and an HP carter pump , take flow readings in exact same spot and see what the results are . Mopar-muscle, Apr 24, 2001 Report Test # 2 well , here we go again , todays test was interesting to say the least , and we believe we have it figured out . added the carter HP 15psi 110gph pump on the frame rail next to the tank , -8 bulkhead in the bottom center of the tank , -8 line to the pump , -6 line from this pump to the inlet of an unmodified factory 2000 fuel filter housing , the rest of the system is as delievered from the factory except for a banjo bolt that had the schrader cut off and tapped to 1/8 npt for the gauge , the digital flow meter in the exact same location reading flow back to tank after the tee on the engine . with DD2 , DDTM (True Torque Power Module) psi volume idle 11. 5psi 18gph cruise 9psi 24gph WOT 6 psi 30gph with the HOT PE on any level idle 11. 5psi 18gph cruise 9psi 24gph WOT 4psi 30gph with the addition of the new pump and larger gravity fed pickup point the flow to the tank did not change , though pressure was up , the carter having an internal bypass is living with the backpressure on its output . the concenus is the VP44 is the restriction . the return line from the pump is only returning the excess fuel from the VP44's own internal pump , the more you feed it the higher the backpressure on the line to the pump . the guys with the large pumps , bigger lines and regulator mounted as close to the VP44 as possible have a large amount of the excess flow returned directly to the tank , this is not a bad thing ,( except that at a low fuel level it is possible to foam the fuel in the tank with the large amount of fuel dumping back into it from 2 sources ) but is really overkill as the vp44 uses a set amount of fuel and this is proved by the higher pressure seen with no increase in flow back to the tank . again , the higher the pressure , the lower the flow , BillW explained it perfectly on the prime loc bashing thread and no one ( including myself) understood it or tryed to test it to see if it was true . someone asked if there was a pump that was between 60 and 100 gph , again carter to the rescue , there street pump , 15 psi , about 70 gph , this pump mounted as close to the tank as possible is the best scenerio . the factory designed the system to have the least amount of restriction with the most flow given the flow characteristics of the VP44 . i have not seen the info on HVAC's 34 hp increase with fuel system mod , i will be talking to him to find out the poop on that . we also felt what happens when you have no flow , we had a low fuel level in the tank and under the bulkhead at the botom of the tank , the engine cutout , if the 0psi had no flow , we would have experienced this same bucking . next we will move the factory lift pump back in place of the carter hp pump [This message has been edited by Mopar-muscle (edited 04-26-2001). ] Mopar-muscle, Apr 25, 2001 Report
  25. I have used the Pennzoil Synchromesh for the life of my NV5600 transmission - 308,000 miles so far. It has never had any shifting problems and has never been disassembled. I have replaced the rear shaft seal at 268,000 miles. I used this oil only because when the truck was new, synchromesh oil was required. Since it has worked well, I never tried anything else. - John
