Seat belt light
Been horn free for the last 2 days. The actuator seems to have fixed my 3 horn honk issue.
Seat belt light
No luck. Not surprised! 😆 Ordered a new drivers side door actuator.
Seat belt light
Put a 2nd wrap around it. I’ll let you know
Seat belt light
Well, she still honked three times this morning. I only did one wrap around it. I’m gonna try wrapping it two more times. See if that does anything.
Seat belt light
Wrapped the CMT today. Tomorrow morning will be the test.
Seat belt light
Good to know on the three honks. Mine does the same exact thing! Drives me crazy! And I’m sure my neighbors at 5:30 am. Did you take the CTM completely out?
Threadzy started following Beast - 500k miles - Projects , Seat belt light , New Kicker Speakers for Beast! and 2 others
Use plastic weld. Stuff holds real good!
Suspension fun!
16k that’s some weight! Anyone ever box these frames?
Suspension fun!
Have you had a chance to tow something yet? Or are you waiting to do the trans first? A few years ago I took off my rear sway bar. To soften the suspension a bit. With my 6,000lbs travel trailer it was fine. A year a go we picked up an 8,500 dry fifth wheel. Climbing the grapevine with a little wind was not fun. Had to cruise at 35-40 mph. Not saying I could have kept going at 55 mph+ with the rear sway bar but I’m sure it definitely would have helped stabilize the load. A couple months ago I replaced the end links and bushings on both front and rear. I do have Timbrens on as well back when I took the rear bar off. . Just wondering if I need to replace my rear springs and bushings to eventually. Truck has 298,000 miles on the clock. You know just barely broke in. 😎
Understanding stock Quadzilla
Levels 4 and up use wire tap. That’s if you’ve tapped the pump. If not the most you’ll get out of the tuner is level 3. Canbus fueling and timing. When towing keep it at level 3 or below. 0 is all stock. 1 is just timing I believe. And 2 is valet mode. Whatever percentage you put there will be the amount of stock fueling. IE if it’s set at 50% you’ll get half of the stock fueling from the pump.
Always something. I put a 5 amp fuse on my Quadzilla. Hopefully it will pop first.
Mr. And Mrs. Michael S. Nelson has occured!
Congratulations!
Threadzy started following Mr. And Mrs. Michael S. Nelson has occured!
Tappet cover gasket
I changed out the cam sensor with a factory Cummins. When I did mine.
Threadzy started following Tappet cover gasket
Fourth GEN bumper installed
That’s my bro-in-laws 2002 next to mine. I put some Bilstien 4600 shocks in it after he helped me with my bumper. That truck was the reason I got mine. I had seen multiple trucks online with the 4th gen bumper. I liked how they looked. Having this one given to me I figured I’d try it. My original bumper was a little tweaked back when I bought it. I had to put self tappers in the plastics to hold them on.
You need to get a sports grill for it. This is what mine looked like before I put the sports grill on it. This is the regular grill. Everything is black but if you zoom in you can see the gap The sports grill I got was about 1 3/4 “ taller from top to bottom. and was thicker.
