Everything posted by IBMobile
Tree damage
I put this together with camera screwed to a small piece of plywood, about 2"x3" painted black, an stuck inside to the trailer's back window with two sided tape, https://www.amazon.com/Esky-Reversing-Perfect-Waterproof-Universal/dp/B07KW5XQRJ/ref=sr_1_5_sspa?ie=UTF8&qid=1546148783&sr=8-5-spons&keywords=esky%2Bec170-11%2Bbackup%2Bcamera&th=1 cat5e wire https://www.homedepot.com/b/Electrical-Wire-Voice-Data-Cable/Cat5e/N-5yc1vZc5a2Z1z0uk5l?NCNI-5&searchRedirect=50+ft.+cat5e+cable&semanticToken=210r10000+>++st%3A{50+ft.+cat5e+cable}%3Ast+cnn%3A{0%3A0}+cnb%3A{0%3A0}+pt%3A{cable}%3Apt+rt%3A{cat5e}%3Art+qu%3A{50+ft.+cat5e+cable}%3Aqu The cat5e wire has 4 pairs of wires. I soldered the camera's power, ground, signal and shield wires to the 4 pairs of cat5e wire with heat shrink to seal. The cat5e wire was then run the length of the trailer and run out the front next to the 7 wire trailer cable. https://www.oreillyauto.com/detail/b/towing-solutions-3935/agriculture-hd-parts---accessories-19818/fleet---heavy-duty-20088/trailer-plugs---brakes-20099/trailer-connector-wiring-adapters-18814/4a93e97f1ed1/hopkins-towing-solutions-wire-connector/48295/4379674/2000/dodge/ram-2500?pos=25 A round 4 pin trailer connector was used to connect the 'video cable' to the truck. More cat5e was run under the truck up the firewall and through the grommet on the left side up the left A post to the over head where the connectors for the monitor were solder together along with an on off switch for the system. The system uses very little current so power was taken from the hot led for my 'mystery switch'. E-KYLIN 5" car monitor https://www.amazon.com/Monitor-EKYLIN-Suction-Mounting-Bracket/dp/B01FF2X1BW/ref=sr_1_5?ie=UTF8&qid=1546149220&sr=8-5&keywords=5"+car+monitor
Tree damage
It's amazing how one thing like a micro burst can add hours of worry and days of work. I glad thing are turning out OK for you. That a nice looking trailer and good luck with it. If you tow anything behind the trailer I suggest you put a camera in the 5er to keep an eye on it. I've got one for my boat trailer I put together, hard wired for about $75. It's also great for backing up or changing lanes.
How well does your truck pull 8,000 pounds
I also have the EZ and the RV275's but with a 4:10 and 245/75-16 with a 47RE. My 5th wheel trailer is 8k and some times I put about another 600 pounds behind that with a 14' boat, motor, gear and trailer. I tow all over: from the flats of Des Moines, IA to Jasper in the Canadian Rockies. On the flats overdrive is on and locked up with cruise control set at 65mph. When going up a long 6% grade I down shift to 3ed, the torque convertor locked up with my 'mystery switch' and the cruise control set to 55mph. I still have peddle left to go faster but why push it and abuse what's going to get me there and back. The fan clutch an a clean air flow over the radiator keeps any overheating problem at bay. This is what my gauges look like after going up a 6% grad after a couple miles and still going up. The exhaust is at 850°F, fluid temp exiting transmission is160°F, fuel pressure at 20psi and the boost is 20psi. The green LED light tells me the convertor is locked with the 'mystery switch'.
Wiring/Starting Problem
How does my turbo look?
I used a piece of 4" diameter white landscape drain pipe.
Guess who showed up for work today.
Did you have to show him what a hammer is for?
W-T needs some advice please
@JAG1 hasn't been able to log on to post due to computer/internet problems so he asked me to due it for him. From JAG1: W-T' called me just before Christmas and asked to have a post or thread put up about his situation with the fire in Paradise, Ca. He wants to let everyone know he is okay. His house only suffered about 15 k in damage on the back side and is heat damage only as nothing really burned. The windows are melted, glass is broken, Siding everything on that side of the house is either cooked or showing heat damage. His two garages however, were completely destroyed. One of the shops, I think 1800 sq. ft. was the one with every piece of electronic equipment inside and is now gone. Months ago he sent pictures of his specialized tech equipment consisting of an almost entire wall, a lifetime collection , some custom built to his specs. We didn't have enough time to talk much further about how he saved his truck which also was stored in there. It was an expensive shop with hepa filter system maintaining a dust free clean room in which he also stored his beautiful second gen Dodge. He says that truck never had mud under the fenders, but now has ash and mud everywhere. It was better than when they were brand new on the dealer showroom floor. This particular shop costing over 200k to build originally is now gone. One thing he needs help with if anyone wants to start a discussion, he needs thoughts/ ideas on what to do. It is dilemma of whether to rebuild and stay there, or just fix the house, maybe rebuild one garage and list it on the market. Insurance is going to take care of him and is not going under from claims, but the thought is because the whole town is gone, burned and ugly with clean up taking years, the idea of moving to a new area may be the smart thing to do. Please join in with your thoughts... Thank you Daniel for your help getting this up on the forum... 'Billy' needs advice JAG1
P0336 / ECM trouble beyond standard troubleshooting
The PCM grounds are the black/tan 14 AGW at C31 and C32. They are spliced with the black/tan 18 AGW from the datalink connector and another black/tan wire that is not used. These all join at splice S126 to a black/tan 10 AGW. It goes to the gray connector, which I think, you have removed at the right battery. When I did the ground modification I soldered all those wires together. I
My turbo with BHAF, with 109k on it, looked like that also . No play in and out or side to side. I cleaned it off with brake cleaner and let air dry.
Calling Commercial diesel mechanics(air line questions)
I have a Parker store down the road from me. I use them for all my fittings. See if there is one near you. http://ph.parker.com/us/en/products
Limited Pedal, VP problem?
I spoke to @JAG1 yesterday. He's doing fine and busy building a new house for someone. He hasn't been able to post here for awhile due to, he thinks, a bad server with his internet provider. He and Mike are working on it.
1999 no start
Get a test light or a volt ohm meter and a jumper wire . Test for 12 volt at terminal A/brown wire at the starter motor when the ignition switch is in the start position, if voltage then starter motor/contacts are bad. If no power at the brown wire for the starter motor then: At the starter relay test for power all the time at pin #30. If no power at #30, check fuse #2/30 amp. At pin #86 check for power when the ignition switch is turned to the start position. If no power at pin #86, check ignition switch for power at yellow wire, if power then check power at jumper yellow wire to yellow/red wire. Ohm test pin #85, should be near 0 ohms in park or neutral, if not check wire to trans mission and test neutral safety switch.
Stanley's Truck Remodel- Dove in Head First!
Like eating a cow, one bite at a time. Take your time and it will all be good. I've used that clear JB Weld for plastic. It work good, sets up fast, makes a strong bound and stinks like....
Rear brakes locking up and overall poor braking performace.
Here some info.
47re died this morning
- Electrical Article - Grid Heater Bypass
The CEL will come on in my truck. With it on all the time from the disconnected grid heaters then when a more serious problem occurs, for example the crank sensor going bad, I wouldn't know it until the engine died. In California, as in some other states, the trucks have to go through some type of inspection. If the CEL is on, or a code stored, or the monitors not set from a code being erased then it is an automatic inspection failure.- Electrical Article - Grid Heater Bypass
Grid Heater Bypass Installing this bypass will allow you to manually control if and for how long you want to run the grid heaters when the ECM is commanding the grid heaters on. This will reduce the load on the alternator/charging system and in turn reduce the harmful AC voltage. This bypass will also keep the fault codes P0380 Intake Air Heater Relay #1 Control Circuit and P0382 Intake Air Heater Relay #2 Control Circuit from being set. Parts needed: 1. 2 micro relays, terminal 87 (5) normally open (NO) with suppressor 2. 2 5 watt / 20 ohm resistor 3. 1 single pole single throw switch (spst) 4. 2 male bullet and 2 female bullet connectors 5. 2 ring terminals 7. Rosin core solder 6. 10 female quick connect terminals 8. Heat shrink 9. ¼” protective wire cover 10. Electrical tape 11. Wire 18 AWG 4 different colors would be nice. 12. Optional 3 ATC fuse holders with 2 amp fuse 13. Something to mount the relays and resistors on. 14. 5 or more 6” zip ties Micro relay Putting it together To mount the relays, resistors and fuses I used part of a used relay mount from a Volvo that I found. It was cut and modified to fit the parts. I didn’t want to cut the wire harness at the fire wall to access the solenoid trigger wires, yellow/black and orange/black, that goes from the Engine Control Module (ECM) to the grid heater control solenoids. I ran two wires to each solenoid connecting to the trigger wires with the male bullet connectors. This sent the trigger signal back to the control relays at terminal 30 (3). Two more wires were run from terminal 87 (5) of the control relay back to terminal 86 of the grid heater solenoids and connected the wires with the female bullet connectors. You can cover the wires from the firewall to the solenoids with the ¼” protective wire cover. I installed the rely/resistor housing under the dash secured with a sheet metal screw and attached the ground wires to the dash sheet metal. For power I tapped into the fuse box on the left side of the dash and installed one of the ATC fuse holders and a 3 amp fuse. The control switch is installed into the left side of the steering column cover; I didn’t want it sticking out of the dash. With the switch in the on position the control relay contacts 30 and 87 close and the grid heaters will operate normally giving heated air to the cylinders. The switch in the off position the control relay contacts 30 and 87a are closed and the ECM signal goes to the resistors mimicking the grid heater solenoids. No check engine light and reduced electrical load on the charging system. The switch can be operated on or off before during or after engine start up. Another added benefit is if your batteries are weak the grid heaters can be turned off saving power for the starter. Written by: J. Daniel Martin, Martin’s Mobile Maintenance AKA IBMobile 12/21/2018 View full Cummins article- Grid Heater Bypass
Grid Heater Bypass Installing this bypass will allow you to manually control if and for how long you want to run the grid heaters when the ECM is commanding the grid heaters on. This will reduce the load on the alternator/charging system and in turn reduce the harmful AC voltage. This bypass will also keep the fault codes P0380 Intake Air Heater Relay #1 Control Circuit and P0382 Intake Air Heater Relay #2 Control Circuit from being set. Parts needed: 1. 2 micro relays, terminal 87 (5) normally open (NO) with suppressor 2. 2 5 watt / 20 ohm resistor 3. 1 single pole single throw switch (spst) 4. 2 male bullet and 2 female bullet connectors 5. 2 ring terminals 7. Rosin core solder 6. 10 female quick connect terminals 8. Heat shrink 9. ¼” protective wire cover 10. Electrical tape 11. Wire 18 AWG 4 different colors would be nice. 12. Optional 3 ATC fuse holders with 2 amp fuse 13. Something to mount the relays and resistors on. 14. 5 or more 6” zip ties Micro relay Putting it together To mount the relays, resistors and fuses I used part of a used relay mount from a Volvo that I found. It was cut and modified to fit the parts. I didn’t want to cut the wire harness at the fire wall to access the solenoid trigger wires, yellow/black and orange/black, that goes from the Engine Control Module (ECM) to the grid heater control solenoids. I ran two wires to each solenoid connecting to the trigger wires with the male bullet connectors. This sent the trigger signal back to the control relays at terminal 30 (3). Two more wires were run from terminal 87 (5) of the control relay back to terminal 86 of the grid heater solenoids and connected the wires with the female bullet connectors. You can cover the wires from the firewall to the solenoids with the ¼” protective wire cover. I installed the rely/resistor housing under the dash secured with a sheet metal screw and attached the ground wires to the dash sheet metal. For power I tapped into the fuse box on the left side of the dash and installed one of the ATC fuse holders and a 3 amp fuse. The control switch is installed into the left side of the steering column cover; I didn’t want it sticking out of the dash. With the switch in the on position the control relay contacts 30 and 87 close and the grid heaters will operate normally giving heated air to the cylinders. The switch in the off position the control relay contacts 30 and 87a are closed and the ECM signal goes to the resistors mimicking the grid heater solenoids. No check engine light and reduced electrical load on the charging system. The switch can be operated on or off before during or after engine start up. Another added benefit is if your batteries are weak the grid heaters can be turned off saving power for the starter. Written by: J. Daniel Martin, Martin’s Mobile Maintenance AKA IBMobile 12/21/2018- 6 comments
- 1 review
- 1
- Merry Christmas
@dripley You need a bucket so you can carry a tune. Merry Christmas- Is anyone else as pissed off, upset, and concerned as I am about Trump banning "Bump Stock"???
Here in the progressive state of California my AR has been banded in it's current configuration, it's very bad, looks like an assault weapon and those 30 round mags I had to get rid of so I wouldn't be a felon. In another state it would all be legal. As for the NRA, They haven't helped out here at all.- Extended crank to start
That $379 price for the RV's from DAP has a $100 core charge. When I bought mine I kept my cores and paid $428. With no timing/fuel controller won't those 90 HP injectors be smoky?- Thoughts on fuel cooler
Read this thread, it may help answer some questions.- Extended crank to start
Replace them with Bosch RV 275, 50HP over stock, no smoke, high quality, last a long time, about $430 for 6 with no core.- Poor ride quality/Bouncing around
Push come to shove we can set up a time to drive my truck over those spots and see if there is a difference in ride.- Poor ride quality/Bouncing around
You live in the same county I live in and drive the same roads. I 've experienced the same thing when driving on different sections of freeways around here. I attribute it to the lane being beat to death and the road surface uneven by the heavy trucks usage of the road. I think you drive on interstate 8 more than I am but that road east of El Cajon is bad. My truck bounces like crazy on north bound interstate 15, just north of the San Diego-Riverside county border and south of the U S Border Patrol checkpoint when I'm in either of the two right lanes. The right south bound lane of 15 just south of highway 76 was tore up and repaved 2 years ago because it was so bad. - Electrical Article - Grid Heater Bypass
