Baconbitsforu
Everything posted by Baconbitsforu
  1. I'm helping a buddy with his 1998 3500. Has the nv4500 on it. How and the heck do you bleed out the slave cylinder? I can't find any thing on it to bleed it with. [ATTACH]4518[/ATTACH][ATTACH]4519[/ATTACH]Thanks for the help!
  2. So the cup holder is good? I need to put my radio siren controller and light system on the trans hump but dident want to lose my cup holder.
  3. Mines doing the same thing Im going to try that.
  4. I would! If its legit. All the vp-44 stuff is $$$$$$ that sounds like a steal!
  5. Here's where i got mine. https://www.treadwright.com/
  6. I just hit 320,xxx miles on my 2001
  7. Any part number on that washer? Mine is leaking
  8. It was 113 here in Texarkana yesterday night...
  9. Sounds good. Mine was a pain to get out but on the way back from Napa I got a ratchet wrench in a 10MM worth every cent. Got the new starter in stalled in 10 min flat!
  10. My old started started doing that a few months ago. Left me stranded when the starter would run but not turn the motor. i just put a new starter in it works like brand new now.
  11. Yes there is a relay to that. It's switch power. Should be the bottom relay of you looking at the line of them from the drivers side. Mine was missing when I tried to use mine.
  12. I paid 3.59 last time for diesel here in Texarkana, Texas.
  13. Would that not cover up some of the Lic plate if not all of it? In Texas they get real pissy about them LIC Plates
  14. My starter just went out this morning. It was fried. no rebuilding that. I got a new one at napa for 150 bucks with lifetime warranty. Starts on first turn now.
  15. I found a post on here a while back and every one said the cheaper ones from rock auto worked the best.
  16. Its a good day when there's no new drip spots under my cummins
  17. Found it on Ol facebook.
  18. The Differential Theory of US Armed Forces (Snake Model) upon encountering a snake in the Area of Operations (AO)1. Infantry: Snake smells them, leaves area.2. Airborne: Lands on and kills the snake.3. Armor: Runs over snake, laughs, and looks for more snakes.4. Aviation: Has Global Positioning Satellite coordinates to snake. Can't find snake. Returns to base for refuel, crew rest and manicure.5. Ranger: Plays with snake, then eats it.6. Field Artillery: Kills snake with massive Time On Target barrage with three Forward Artillery Brigades in support. Kills several hundred civilians as unavoidable collateral damage. Mission is considered a success and all participants (i.e., cooks, mechanics and clerks) are awarded Silver Stars.7. Special Forces: Makes contact with snake, ignores all State Department directives and Theater Commander Rules of Engagement by building rapport with snake and winning its heart and mind. Trains it to kill other snakes. Files enormous travel settlement upon return.8. Combat Engineer: Studies snake. Prepares in-depth doctrinal thesis in obscure 5 series Field Manual about how to defeat snake using countermobility assets. Complains that maneuver forces don't understand how to properly conduct doctrinal counter-snake ops.9. Navy SEAL: Expends all ammunition and calls for naval gunfire support in failed attempt to kill snake. Snake bites SEAL and retreats to safety. Hollywood makes fantasy film in which SEALS kill Muslim extremist snakes.10. Navy: Fires off 50 cruise missiles from various types of ships, kills snake and makes presentation to Senate Appropriations Committee on how Naval forces are the most cost-effective means of anti-snake force projection.11. Marine: Kills snake by accident while looking for souvenirs. Local civilians demand removal of all US forces from Area of Operations.12. Marine Recon: Follows snake, gets lost.13. Combat Controllers: Guides snake elsewhere.14. Para-Rescue Jumper: Wounds snake in initial encounter, then works feverishly to save snake's life.15. Quartermaster: (NOTICE: Your anti-snake equipment is on backorder.)16. C-17 Transport pilot: Receives call for anti-snake equipment, delivers two weeks after due date.17. F-15 pilot: Mis-identifies snake as enemy Mil-24 Hind helicopter and engages with missiles. Crew chief paints snake kill on aircraft.18. F-16 pilot: Finds snake, drops two CBU-87 cluster bombs, and misses snake target, but get direct hit on Embassy 100 KM East of snake due to weather (Too Hot also Too Cold, Was Clear but too overcast, Too dry with Rain, Unlimited ceiling with low cloud cover etc.) Claims that purchasing multi-million dollar, high-tech snake-killing device will enable it in the future to kill all snakes and achieve a revolution in military affairs.19. AH-64 Apache pilot: Unable to locate snake, snakes don't show well on infra-red. Infrared only operable in desert AO's without power lines or SAM's.20. UH-60 Blackhawk pilot: Finds snake on fourth pass after snake builds bonfire, pops smoke, lays out VS 17 to mark Landing Zone. Rotor wash blows snake into fire.21. B-52 pilot: Pulls ARCLIGHT mission on snake, kills snake and every other living thing within two miles of target.22. MinuteMan Missile crew: Lays in target coordinates to snake in 20seconds, but can't receive authorization from National Command Authority to use nuclear weapons.23. Intelligence officer: Snake? What snake? Only four of 35 indicators of snake activity are currently active. We assess the potential for snake activity as LOW.24. Judge Advocate General (JAG): Snake declines to bite, citing grounds of professional courtesy.25. Signal: Tries to communicate with snake...fail repeated attempts. Complains that the snake did not have the correct fill or did not know how to work equipment a child could operate. Signal Officer informs the commander that he could easily communicate with the snake using just his voice. Commander insists that he NEEDS to video-conference with the snake, with real-time streaming positional and logistical data on the snake displayed on video screens to either side. Gives Signal Corps $5 Billion to make this happen. SigO abuses the 2 smart people in the corps to make it happen, while everybody else stands around, *******, and takes credit. In the end, General Dynamics and several sub-contractors make a few billion dollars, the 2 smart people get out and go to work for them, and the commander gets what he asked for only in fiber-optic based simulations. The snake is forgotten.
  19. Yes. I get what your saying. I build computer on the side so I see were your going. I got the FP Im just trying to help with the heat soak. I think a under 100 buck blower//heatsink that runs after shutdown for X amount is way better than nothing at all.
  20. There's the guy I was talking about. Do you have any pictures of this set up? Its starting to get 105 here in texas no telling how hot it is under the hood. - - - Updated - - - also how did you do the heat sink on top?
  21. Well I did some googleing and found a few guys who run the blower idea... I think Im going to try this as a test. Just get a 12 volt boat blower that will run when the key is on and 10 Min after shutdown. Pull air from the front bumper area and push it to right on top of the vp44. Well see what happens. If any thing Ill get a blower to put in the roof of the house to try and push out some of this hot Texas air.
