Doubletrouble
Staff
Everything posted by Doubletrouble
  1. That is a long list. I know how you feel working out in the elements, it sucks. Before we moved i had a garage but nothing would fit inside, all work was done in the gravel driveway in front of the garage.
  2. Just want to touch base with everyone. I've been very scarce lately. I've been dealing with a lot. Trying to get something moving with dad's legal case ( from his car accident that ultimately took him from us) and more recently my mother was battling stage 5 kidney failure along with multiple infections at the same time. She lost her battle and passed away at 9am October 8th. Since then I've been very busy arranging the funeral, after service luncheon and handling other business since mom's will appointed me executor. I have a ways to go before I can fully wrap things up. Mom's house will have to be cleaned, repainted inside, yard work done and then put on the market to be sold. I have to be in court for dad's case Friday at 3pm, hoping some good news will come from that. It's been a stressful ride the past month and have some more ahead but I will keep pushing forward and eventually find the end of this bumpy road.
  3. Looking forward to seeing it also!
  4. I bought my parts from a combination of allstate gear and torque king I believe. I had to replace the input shaft, main shaft and counter shaft. Mine was pretty trashed. I also replaced the tail housing, OEM was an aluminum peice, I replaced it with a cast iron piece from torque king.
  5. Doubletrouble commented on Mopar1973Man's blog entry in Beast
    While beast is laid up for repairs please please please paint the grill! 🤣 Sorry buddy, that bare yucky plastic gril drives me crazy. Lol
  6. That's cool, I like this idea!
  7. Congrats on finally getting her nailed down.
  8. Wish I had the skill to do body work like that. Looks great
  9. Yep, all proprietary info. TOP SECRET!
  10. That would be great info to have on hand. Hopefully you can get a reliable and accurate source for those chime codes.
  11. Way to go Ford.
  12. That should eliminate it from drawing in any air then.
  13. Is it possible that you are pumping aerated fuel from the lift pump to the injection pump and that is causing the loss of prime? Somehow the lift pump could be sucking in air as it also draws fuel and sends it on its way full of bubbles which would facilitate a rapid loss of prime.
  14. Nice to finally "meet" you Suzanna! I've heard alot about you, Mike and have had many phone conversations where you have come up in topic. Glad to see you have both found some happiness during your medical issues. And CONGRATULATIONS on the upcoming wedding! I hope to someday make my way west to meet Mike and now you in person.
  15. We are currently experiencing freezing rain. They're calling for up to 1/4 inch of ice.
  16. Glad to hear you cancer free @Mopar1973Man! Chiropractor for the spinal compression?
  17. Yes, I saw that. It may be worth looking into. Would low lift pressure cause the fluctuation that he is seeing? I don't know but, any fuel starvation is bad. Also, could there be air in the fuel. Bubbles would certainly cause dips in pressures. Obviously that would be isolated to the suction side of the lift pump. Anything on the pressure side would be in the form of a leak.
  18. Ok, I'm a novice with common rail. Would the firing of the injectors cause a fluctuation? I would think so, to this extent though I'm not sure. Also, what is the preferred pressure from the lift pump? This would cause me to question pressure and or volume from the lift pump. Is there a "big line kit" between the lift pump, oem filter and injection pump?
  19. The exhaust on mine was on there when I bought it about 5ish years ago. So far it's holding up against the elements pretty well. It's a 4" from the turbo back via a 3" to 4" adapter of some kind right on the turbo. It has 2 straight through type mufflers (think old school cherry bomb type) and it's not really that loud. It sounds pretty good actually when I'm towing one of the 10k lbs fifth wheels. She has a nice growl to it. Only downside is where the pipe goes over the rear axle it is in the way to mount the spare tire in the oem location under the truck so it rides in the bed under the tool box.
  20. Welcome to the site
  21. Oh wow. Is the main case ok? Look it iver good for cracks. I would suggest a full rebuild at this point. Everything in there has been hot with no oil to cool and lubricate. Check all the gears for damage, you had bits of metal flying around in there. I recommend at the least replace all the bearings, syncros and anything else that even looks suspicious.
