GSP7
Everything posted by GSP7
  1. Where did that cab come from? Yeah buddy,,, that sure is "Custom" $10,000? .
  2. Yes,,,,,,, Ive talked to Eric at Vulcan many times. He helps straightens out the Bull Sht you read on these forums and helps confirm what you want and need, or dont need, to upgrade your truck . He wont sell you stuff you dont need . .
  3. I looked at my old triple pod box that I store my old pilar in. Mine is a Autometer pod. It is a good quality. IIRC it was $30 I have one of those steering column top pods for my 4th guage. It blocks the speedo/interment cluster,,, kinda annoying
  4. I think it was Diesel Maner wher I got the 3 guage kit offer, but that was 10 years ago Maybe they still have a package deal, call them http://dieselmanor.com/isspro/EV.htm Isolator http://dieselmanor.com/dm_products/DM-CGI2240.htm .
  5. No,,,,, It was 10 years ago. I think I got them from genos or diesel manor There was just a package deal price, 3 gauge set, offered by the vender Genos still has the Fuel Pressure gauge with the Isolator https://www.genosgarage.com/product/iss-r5604r/isspro-standard-black-white Diesel manor http://dieselmanor.com/dm_products/DM-CGI2240.htm
  6. Marcus, I have the Isspro Mechanical EV1 gauges for 10 years on my truck Isspro are excellent guages They work great, Never had a problem at all . Fuel Pres. Trans Temp, Pyro, and Boost The trans oil temp EV1 is electric the rest are mechanical I actually have the idolator with my fuel pressure gauge, came with the 3 gauge kit, and never had a problem with it either. No leaks at all, ever Mechanical gauges are the most reliable and accurate. Old school Hot Rodder Style .
  7. Once again, this is a non-issue and just an opinion theory
  8. Once again, that is just "your opinion" and is a None Issue. This is true. And that picture of the size comparison is the older units not the smaller Titanium which isnt even pictured .
  9. Glacier Diesel in washington might be good Just want free shipping , no tax and no Idiots .
  10. In the western US , Who is a good dealer to buy a Fass titanium from ? Id get one from Eric at Vulcan but he doesn't deal with fass I just have to decide 95 or 165gph Im leaning toward the 95 . Im thinking the 165 will be just wasting energy returning a lot of unnecessary fuel volume back into the tank probably just causing more air .
  11. What is a Iquad v2 ? Is that a whole different unit than the quadzilla adrenaline ? Would a Fass titanium 95 gph support that? .
  12. Took me a minute to figure how you have that mounted. On the second bed bracket back and pump attached going forward toward the cab. Good Idea. Good photo angle, Looks Good Got any other pics of how your other hoses are run? I dont see the return line
  13. Gipper, I see you didnt run their 90 degree fitting on the pump at suction port. That was one of my concerns
  14. Who here is running a Fass Titanium and did a clean, nice install running your hose etc etc ? Got some question. I have a long bed. First question: Did you mount yours it at the most forward bed bolt bracket on your long bed ? Short bed would be like the second bracket back on a long bed. I called a Fass few times and asked some questions about their parts and install already. Post your pictures if ya got any
  15. I thought Id share this find https://www.homedepot.com/p/Gardner-Bender-16-AWG-25-ft-Primary-Wire-Spool-Red-AMW-326/300689784 I found a good source of wire if needed for Automotive. Online from Home Depot Good price, and it is Gardner Bender, Marine grade, tinned copper and thick insulation: "Manufactured to OEM standards are recommended for repairs or new wiring applications. The ultra-flexible Tinned Copper wire products provide maximum protection against corrosion and electrolysis. It resists salt water, battery acid, oil, gasoline and UV radiation. " I bought some various color insulation in 12 awg, 14 awg and 16 awg. Marine Grade Its better quality than the stuff at Napa auto, way less expensive https://www.homedepot.com/p/Gardner-Bender-16-AWG-25-ft-Primary-Wire-Spool-Red-AMW-326/300689784
  16. GSP7 posted a topic in General Conversations
    Jürgen Kawan
  17. I thought there was a electric connector expert on this website ? http://www.rockauto.com/en/moreinfo.php?pk=4690626&cc=1377569&jsn=568&jsn=568&jsn=568 Just need a 'male' side plug Same plug as Map Sensor and Crankshaft Sensor
  18. They never used to use salt on roads in Idaho. Least not in N. Idaho or treasure valley .
  19. Maybe.... https://www.banggood.com/Waterproof-3-Pin-Way-Wire-Connector-Terminals-For-Motorcycle-Electrical-Car-Truck-p-1044108.html?rmmds=buy&cur_warehouse=CN http://www.dx.com/p/qook-3-pin-way-waterproof-electrical-wire-connector-plug-male-female-bullet-connector-crimp-terminals-5-pcs-497883
  20. Almost got everything to install my back-up light. First I removed this in-bed plug the first owner installed with scotch clips(what ever they are called). Lucky I live in the desert, so the wiring was clean where the clips were. Im going Old School vintage style back-up light, no LED $. The original bulb in my Peterson par36 light is a #4411 par36 35w trapazoid beam, 2500 candle power I tryed a.... #4415 35w fog/flood 40x5 degree beam, 9000 candle power better but the 5 degree vertical is a thin fog beam. So some research and I got...... #H7614 50w, 70x30 degree beam, 2000 candle power Wow. this bulb lights 10 times more area and brighter than the other two inside my dark shop. The candle power rating doesnt mean much.. Plus the 70x30 degree beam is great for a back-up. I cant wait to test it tonight out side
  21. Is there anywhere to get the same type male and female plugs for the back-up(neutral safety) switch? To make a inline plug-in pigtail so I dont have to cut the factory harness wires to splice in a remote aftermarket back-up light on/off switch
  22. I have a small and huge soldering irons and also a weller gun that I use mostly
  23. That's the thing about buying on line. You really dont know what you are buying. If its quality or some cheap knock-off junk, no mater what they advertise it as
  24. Better price here. Some dont show the size printed on the tube. Are these all 3m? https://www.amazon.com/100pcs-Insulated-Shrink-Connectors-electrical/dp/B01C26ZBMG/ref=pd_cp_328_1?_encoding=UTF8&pd_rd_i=B01C26ZBMG&pd_rd_r=GJCQ7E86TBGVMSKHZY05&pd_rd_w=79jk9&pd_rd_wg=W81Wq&psc=1&refRID=GJCQ7E86TBGVMSKHZY05 https://www.ebay.com/itm/100-Mixed-3M-Heat-Shrink-Butt-Electrical-Crimp-Terminals-Wire-Cable-Connectors/182164495120?hash=item2a69d99b10:g:50wAAOSwuYVWmDQd
