AAM rear axle identification
angus
 The guy at Orielly`s tells me there is two different size 14 bolt AAM axles listed for my truck, one is a 10.5 ring gear and the other a 11.5 ring gear. I`m guessing it is 11.5 but not certain?
I`m getting ready to change the rear end grease, and looking for a new cover gasket..... He tells me both of the cover gaskets for AAM axles are $50.00 + !!  I am tempted to try the old fashioned silicone route. Any thoughts?
7 hours ago, AH64ID said:
The gasket is reusable so don't bother buying one.
From 2004 on all diesel trucks have the 11.5. 2003 can be tricky, but all HO's have the 11.5 and some SO/Cali's have the 10.5 with the 47RE trans.
I thought there must be something special about that gasket to $$$ so much.   The 11.5 holds almost a gallon of gear oil as well
