Throaty, Spooly 2nd gen
8 hours ago, notlimah said:
That's a good idea on the wrap, what did you use?
I didnt use "wrap" because wrapping the exhaust causes the pipe underneath the wrapping to rot from extreme heat and rust.  Instead I used two of these blankets. Thermo-Tech
I have two of them end to end.  Here's what they looks like. :thumbup2:
7 hours ago, joecool911 said:
So a culvert pipe and tee post is all I need?
Yes, one or two T posts is all you need.  For that matter, all you're doing it adding mass to the exhaust pipe to change the reverberating pitch.  T posts are just cheap.
You need to remove the spade on the bottom and just clamp it on.  I used one but thought about adding another.  Never did because I eventually bought a new exhaust system.....and because any drone I did have at that point was so minimal that I just didnt care enough to add another T post.
Here's what it looked like too.  And before you say anything, yes did look redneckish but it was very difficult to see unless you crawled under the truck. :whistle2: Actually I never liked how the whole straight pipe job went and thought the guy did a sloppy job.....
Edited by Cowboy
Fixed the images ( :
The T post you see in that picture I posted is just what I had laying behind the barn.  The straps I picked up at the hardware store.  Really it was just an experiment I tried on afternoon that worked and I never got around to trying to make it look any more appealing.
