04 keeps eating turbos
Cueballtech
Rebuilt motor in frame, due to dropped valve
New injectors, studs, head gasket, gauges
Holset turbo = failure within 7 days (oil into exhaust side)
Replaced with cheap eBay turbo = excessive shaft play within 14 days
AFE blade runner= 3 weeks starting to show signs of excessive shaft play.... And slight oil blow through exhaust side
This is getting really old....
Replaced oil feed line and adapter at the turbo when I installed the eBay turbo with new ones...
Any advice or help???
Edited by Cueballtech
On 2/12/2017 at 1:45 PM, Cueballtech said:
Yes
What are you using to verify oil pressure?
If it's the stock gauge and it dropped to 0 that means you were under 6 psi for at least 30 seconds. I'd be worried about a lot more than just the turbo.
Edited by AH64ID
Got the new turbo put on, also replaced all fluids, oil cooler, oil filter housing, pressure relief valve, oil filter and gaskets...
Had a lil Gray smoke on start up but cleared up after running a lil while, truck sat for a month while waiting on parts...
Exhaust manifold was dry on inside, exhaust dry on inside, turbo dry.... I'm confused
On 2/12/2017 at 6:42 PM, Cueballtech said:
Well I let it idle a lil after a drive a lil bit ago and the oil pressure fell off the gauge
You need to verify the oil pressure with mechanical gauge. Dash gauge is nothing more than a dummy light. You might have bigger issues killing turbos being the oil pressure might not be high enough in pressure.
@AH64ID What's the standard for CR engine oil pressure? Is it still the same minimums...
MINIMUM PRESSURES (At least what I know for 2nd Gen)
10 PSI at idle
30 PSI at 2,000 RPM's
