New guy needing help truck down
I have a 2001 Cummins 4x4 6-speed the truck starts and idles fine but I'm getting several codes and have dead pedal and the rpm on the tach drops to zero at idle
The codes are
P0122
P0238
P0341
P1689
What I've done so far is
Replaced apps with a timbo
Replaced map sensor
Replaced cam sensor
Cleaned every ground I can find
I'm really now sure where to look from here
Thanks for any help in advance
The codes are
P0122
P0238
P0341
P1689
Replaced map sensor
Replaced cam sensor
First read over the diagnostics of each code.
There is only 1 ground wire to worry about. The rest of the grounds are subsystems like lights.
Have you tested for excessive AC noise?
