No clue, my truck doesn't have TM so I can't tell you how it interacts.
Throwing the canbus at %150 across the board and a ton of wiretap will try and overwhelm TM, but the longer you spend in the 1 -25 mph area the more tm will pull fueling.
You can't put load on the engine enough to build boost without roasting the clutch.  It will in theory work, but I am guessing your clutch will be smoked before you launch.
Posted (edited)
If you give me some beer I'll try it with the dual disk....
But I actually like my trans in one piece.
Edited by trreed
It's a difference base flash.  so the box under the hood gets a different flash, with 1 line of code changed to use the bosot defuel for staging rather than overall limit
the 2.7 code would be replaced with 2.7+staging
But again this code is a race only type of thing.  Using the staging function will cause unbelievable stress to the drive train
no, manual trucks cannot apply load to the engine at idle without slipping the clutch.
Without a load to apply the engine cannot build boost
Haha this sounds fun, mabye after I get this tune dialed in lol.  It's almost there.  I think we made some good head way today but the truck was covered in ice including the mirrors so no telling what was behind me.
27 minutes ago, Dodgeih said:
Anyone want to do full auto swap for my nv4500????? PLEASE!!!
I have tossed this up time and time again.  I think I just need another truck that has an auto already in it haha.
2 step doesn't load the engine it just limits rpm. I think it has an upper and lower limit. So say you set it at low 2000 and high 2100. It would bounce the Rev limiter between the two specified limits.
oh, yea nope can't do that either.  the ecm gets VERY mad if you mess with fueling vs rpm.  the ecm goes into a runaway mode protection and shuts off.
