- Replies 34
- Views 16.2k
mopar440cu 9 posts
Mopar1973Man 6 posts
Chris O. 4 posts
jlbayes 2 posts
It's a dealer only thing. You would have to program the fob for that vehicle. You can't just trade fob and expect it to work. They must be programmed by a DRBIII tool which the dealer has. Other than
Ive used these instructions to reprogram extra key fobs(remote) from my 99' to my 00' but you have to have a working fob to do it. Both of my trucks also had the factory security option. https:/
The CKP is the crank positioning sensor. Your 01 may or may not have. I think the early 01s had and the large 01s did not. The later models have only a can sensor like the 02s. Where the wire goes I d
I have got a weird problem maybe one of you can chime in with a answer on my predicament. I have a 2001 3500 5.9 with a starting issue. I already replaced the IP and got it started with the help of Doug from Blue Chip following his directions. However, it will only run with the C3 wiring connector unplugged from the PCM?? It has np power and the odometer reads NO BUSS due to the C3 plug unplugged. I am trying to trace the wires from the PCM in the C3 wiring and have not found anything yet. How would I know if a wire is bad on one of these wires? Also could it be something else? Any suggestions would be appreciated!!
Thanks!
Steve
