I originally had to swap these in a week cause was hauling stock trailers for a living,but 6 yrs ago I burned a hole in #6 cyl this time, I tried to do it right.  Fabricated trans mounts using exiting trans mount locations in frame
  • Replies 46
  • Views 7.6k
  • If you like the sound of an old 275 Cummins with the roots blower and back draft manifold, you will like this old IHC KB12. This old guy has about 20 acres of antiques, mostly trucks and dozers. The G
  • Nope, only lurking on the forums from time to time Just been too busy reverse engineering CCD bus in our truck,  Like today I just figured out which digit of VIN number is responsible for AB
  • It was fun back in the day but after hauling logs for 25 years (mostly 2 sticks) and this Ford for 33 years, (installed the aux in '85) the 6 spd is just simple. Plus, like I said, it has more power a
Medium duty Freightliner, Volvo, Kenworth or Mack all used these, it uses a Volvo Master/Slave cyls
Nice, how many speeds is it.
 How did you put a hole and piston, got it too hot. How hot is hot and how long you held it there.
It's a 6 speed with ratio's close to the NV5600, but will handle 840 Lbs ft of torque, hence the 8406, fuller made other 6 speeds, 5406, 6406, I got a lot of my info from another guy I think is in N.M  but I think he had 6406, the clutch is only a single disc rated at 630 lbs ft. Went through 3 count 1,2,3 NV5600's before I did this.
Bad injector is best guess, sloppy maintenance on my part, drove to Des Moines thought it ran smoother than ever before, hooked a trailer and 30 miles later hell broke loose.
@Blueox01  Are those mid duty transmissions synchronized or unsyncronized like the larger ones, Also did you have to do a body lift to fit in your truck or floorboard modifications
This one is synchronized, had to make a doghouse for it to fit
If it can handle 840 ft/lb of torque then how much nv5600 can handle, I'm pretty sure I'm close to 1000 on my truck or so it feels that way
Some say 550-600 lbs/ft   I know I snapped the mainshaft pulling a set of doubles against a headwind in Oklahoma  that was NV5600 #1, I shelled 2 more after that. You put this case next to a NV5600 the dodge 6spd looks like a baby.
Edited by Blueox01
You probably had the older version with smaller input shaft, 01 and newer I believe is 1 3/8 where before they were 1 1/14
550 ft-lbs is the rated continuous input torque. I’m not sure what the maximum momentary input torque is, but you’re not gonna be using all 1000 ft-lbs all the time, so you’ll probably be below or just at the 550 ft-lb limit. Plus, there’s a factor of safety and an expected life factored into that 550 number, so it’s conservative anyways.
He has an 01. First year of the 1-3/8” shaft
Edited by trreed
What about g56, just looking for options for future lol
Around 675 I think? The 4th gens have 660 ft-lbs stock so it’s gotta be around the 675-700 number. G56 has an aluminum case though and can crack under high power. @TFaoro‘s was behind a 900 hp truck and is fine so it’s all about driving smart.
Edited by trreed
No clue, This 8406 has a 1 3/4 10 spline input shaft and pull type clutch
Nice pic! I’m digging your build!
Nice build.
Question: is that Mitsubishi Starion or Dodge Conquest in the back on this picture?
87 Starion ESI-R , Sharp eye!
Edited by Blueox01
:lol:  Me too I also have Mitsubishi Starion 87
