Another Rectifier/Diodes Failure
Finally got around to disassembling my old alternator.  I believe this is the factory original one.  Unfortunately I stripped out 2 of the 4 screw heads holding the diodes in! :doh:  Any tips for stripped screws? :thumb1:
Anyways,
@Mopar1973Man  The diodes you sell...do they fit in all Denso alternators found on 94-02 trucks?  I have a 98.5, which from the looks of it, is the same as a 12 valve alternator.  It doesn't have that plug on the back (see photo from FSM).
Just now, Mopar1973Man said:
Got you covered...
Most certainly. Thank You!
I found it interesting that mine burned up right at the beginning of summer.  Also this vehicle lived in California (Los Angeles suburb) all of it's life prior to my ownership.  One wouldn't think the grid heaters were used very often.  It does have a block heater too...oddly enough.
My truck was bought and has stayed in San Diego County, except for trips.  The grid heaters come on during the cold mornings here and it also has a block heater which I've never used.
$71.45
http://www.fostertruck.com/diode-pack-rectifier-bridge-for-dodge-denso-alternator.html
Vs.
$54.50
https://mopar1973man.com/store/product/61-denso-alternator-rectifierdiodes/
Nations alternator is a full replacement alternator which will require the ground wire mod to basically omit the old charge lead and route to the passenger battery. Be aware it can be quite a bit more than even a remanufactured Denso.
I dont see any numbers on the housing, i removed it to rebuild (have bridge, bearing and brushes)...but the bridge stud exits at a 90 like pictured.
Mine exits straight...i was under the impression the the bosch was totally different.
Every thing i have looks identical, mounts the same and fits accordingly...minus stud exit direction.
My battery termianl cable bolts tonthe side of the housing with the factory cover included...not the rear of the housing like this bridge would suggest.
It doesn't sound quite right. Perhaps your Denso is off of a different car or truck. You might do better to go get the correct Denso for our trucks and keep the rebuild parts for the future.
I don't know if there is a part number on the alternator.... I'm curious to find out if its for a different vehicle.
BTW, The W-T grounding mods are worth every effort in reducing damaging levels of A/C ripple even with a new or old alternator.
Edited by JAG1
https://www.oreillyauto.com/shop/b/charging---starting-16772/alternator-11425/f7cab2ae3cc0/2002/dodge/ram-2500?q=Alternator
Just as a reference photo...if this link works, you can see 2 different exits...
1 would appear to have the bridge in this article (which i bought)...the other has the exit point like mine (which would exit straight from the ring if the bridge).
Mine is not a 90 degree exit.
All i can see is sticker residue, i grabbed the parts to have on hand. Ac ripple has always been very low, but recently had some gremlins with DTC...my tuner failed and is now removed, and the various dtc's have not returned in a qeeks driving.
Perhaps yours is a rebuild that got modified during rebuild.
 I knew the ND alternators are better than Bosch from years ago experience with my first gen truck. So I changed over to ND on my 2002 even though the Bosch was still charging fine. I'm glad I did anyway.
I need to order another diode bridge from 'Mopies' (Mopar1973Man) again just to have on hand
Edited by JAG1
Using this as a reference, the top photo shows the 90 exit, and claims to be bosch rebuild...
The lower is a straight exit, and claims ND rebuild.
So, does every one here have the 90 exit bridge ? Mine has the tin rear cover and all in tact...
Well, maybe it is a model year thing.
I will verify my build date, and see from here
When search for bridegs...i get a bunch od this bridge fits XYZ series alternators....but i cant locate my numbers, and didnt think to write them down when i did try to rebuild it. I just reinstalled everything and went.
So what else, specifically, in an alternator can cause excessive AC noise.  I just replaced the diodes and brushes in my original and I'm getting the same exact reading as I was with a new replacement?  Literally, the exact same reading on my Fluke 87.  Cold engine, everything off, .068 at startup (clearly too high), and then it slowly works it's way down.  New alternator was a cheap unit which I returned immediately after doing a noise test then decided to do a rebuild of my own.
The only real issue I am having is I notice the tachometer is not moving in a fluid motion. Speed/RPM dependent?  I really might make a video of this issue because it's quite interesting.  Revving the engine in neutral it appears to be fine.  Accelerating in first/second gear it seems to move normally.  Getting into third, and cruising gears, it's obvious that it looks like a ticking motion.  Not like a wall clock, but you can tell it's not as smooth as it should be.  When using cruise control at freeway speeds it's the most obvious because you can rest your foot on the pedal and feel it adjusting up/down constantly (matching with the tach).
I would assume the cluster is fine if it's only doing it under certain circumstances.  I've sometimes noticed, at idle, the tach bounces ever so slightly as well.  I did recheck my valve lash to rule out an issue there.  I read that some members had funky issues with valves not being adjusted properly.
Still to do:
1)  Ground Wire Mod
2)  Pull 140A fuse and disconnect alternator for a test drive to see if issue goes away
