- Replies 22
- Views 9.1k
Mopar1973Man 5 posts
Dieselfuture 4 posts
NIsaacs 3 posts
Silverdodge 2 posts
Thanks for the warning on the oil passage. Ill make sure to watch that close.
Make really sure where the leak is coming from, oil cooler gasket is rare. Use a flashlight. Head gasket leaks right above the cooler are common. The narrow band print-o-seal gasket next to the coolan
I figured you were clear about the leak but thought I would ask for a double check, lol That hole is not a head bolt hole, it is the bypass port. So a lot of coolant pressure there with
Dang!
I'm not catching any breaks these days. Doing my weekend inspection on the truck and noticed my coolant reservoir is down to the add mark just about and then noticed the small drip puddles on the floor. Tracked down the leak to my oil cooler gasket is leaking. Hopefully, that is a fairly straightforward repair for that gasket. Any information on this task would be great.
