Posted (edited)
Yeah, I decided to check the WOT and boost pressure. Funny it reports my maximum boost pressure of 61 PSI:lmao::lmao2:My ISSPro gauge shows barely 47 PSI maxed out running this gauge is correct. I know that this is all MAP sensor error. I figure I'd share this tidbit.
lol,
for what it is worth the sensors max mapped psi is ~45 psi on 01/02's   anything above that is not worth looking at.
0-16 psi from ecm,
16 psi to whatever the sensor reads to is ecm+ sensor
The sensor might read to 40 or it might read to 50 but officially 45 is about the max from the late trucks that is reliable.
Naw. Good fuel to air right now just pointing out that my little HX35/40 hybrid is not capable of reaching 61 PSI of boost which I think is laughable. The 47 is my typical max shown on the ISSPro gauge. I'm just pointing out don't rely on the Quadzilla gauge being it just the ECM sensors that your seeing. It's good for diagnostic work, but for accuracy. It better off having a full set of gauges than relying on the a tuner gauges. (Edge Juice, Quadzilla, Smarty Touch (partially) being that 2nd Gen its still using the same sensor. As for the 3rd Gen and up I think is different but can speak for them.
Posted (edited)
1482° is not good fuel to air, especially empty and with it starting to backdown.
Edited by AH64ID
On 4/2/2019 at 5:01 PM, Me78569 said:
0-16 psi from ecm,
I guess what happens with people that push 80-90psi, how does qwad know how much fuel to add if sensor only goes to say 50. Guessing you just tune by smoke at that point, or dump it all in?
1 hour ago, Me78569 said:
if you are at 50 psi then you are likely at WOT and hte maps are all maxed anyways.
I'm guessing the maps max in the low-mid 20's?
About right. 20 and below is about right on the money abut reaching above 20 PSI you can toss the data out the window. The sensors skew more as it rises in pressure.
