For some reason I thought it was just the 3500 that had the PITA front rotors. Never had a 2500 only 3500's. Although that hd steering on the 99 gave pretty good service life couldn't complain one bit on that one. The 02 is @ 115k and just did ball joints, and track bar. Rest of the steering is OEM as far as I can tell.
On 5/16/2019 at 10:20 AM, Rotax3006 said:
I might keep an eye out for one but a $1000 buys a lot of brake pads.
Not really. When you figure like @JAG1 a set of units bearing in the front, rotors, calipers, and brake pads. Once you run a steep grade and you overheat the brakes most everything will need to be replaced for safety. JAG1 found out that the heat from the rotors cooked the grease out the unit bearings, warped the rotors, burnt the brake pads, and possibly doing seal damage to the calipers. Only takes one steep grade to do damage.
Even better yet he wasn't towing. Just carrying his camper in the bed of the truck.
$1,000 only covers maybe 2 sets of everything.
And you do not want to find out what it's like having a front bearing go at highway speeds neither. Very hazardous shocking feeling. My truck threw itself into the fast lane without warning. I was glad no one was beside me.
Did you experience a catastrophic failure at speed? That would be a ride for sure, probably about like blowing a front tire.
I definitely drive like moparman, lots of following distance and the middle pedal doesn’t exist.
This most recent failure was a result of a frozen caliper. The other side looked new still. Need to pay closer attention when I rotate tires.
I have as well. Darting back and forth in the lanes couldn't hold it straight and completely failed in Downtown Boise. Lot of metal grind noise which was loud enough to hear in the cab with the windows up.
Again another common failure for excessive use of the service brakes. The brake fluid gets hot and cakes up to the pistons in the caliper till pistons start to hang up. Which in turn creates the problem, even more, being the piston will not fully release the brake pads. You can prevent this failure with 30k miles brake fluid changes and limiting the use of the service brakes and lean more on the exhaust brake.
This is a complete thread derail but I don't want to start a new thread just for this. Apologies in advance. Reading about things failing while driving made me think of this. Last night I finally got my truck rolling after it being down for almost 14 months. Made it probably 10 miles, blew a boot off the turbo somehow (I think it snapped, I probably over tightened it... Close to 2 years ago!). Pulled over and took me a few minutes to find it... In my back tire. FFS.
... Brakes work good though. Hah.
dDsldLGah4i5bJDna9rQ5mRSd44NGeVXSx-SwDOG
  • Sad 1
3 hours ago, Mopar1973Man said:Again another common failure for excessive use of the service brakes. The brake fluid gets hot and cakes up to the pistons in the caliper till pistons start to hang up. Which in turn creates the problem, even more, being the piston will not fully release the brake pads. You can prevent this failure with 30k miles brake fluid changes and limiting the use of the service brakes and lean more on the exhaust brake.
I should have clarified better, the caliper froze up on the pins and wore one brake pad off. I’m guessing from all the mud, snow and that wonderful magnesium chloride the state uses.  I’m in no way implying that an exhaust brake wouldn’t be sweet, I’m just not going to spend the money on me right now. Maybe down the road though.
The old standard insult to injury.........
At least it didn't end up in the turbo :sofa:
