- Replies 107
- Views 20.5k
Lol...isn't that the same technique that she uses on you?
That video show a GM conversion. They're OK, but not worth the extra money, in my opinion. The Borg HD will do everything that the GM conversion will do, but at 1/3 the price. Besides, the GM conversi
I worked on your transmission just today, Wade! I'm pushing hard to get it shipped by the weekend for you... You know, I have built literally thousands of these transmissions, and I still
I'm going to do my first transmission service. I bought a Goerend Trans Pan for the better drain plug, better drainage slope inside, better gasket according to other forum discussions. One problem keeps coming up is leaks and drips when done. So I'm wondering how so it won't drip when done. Should I use RTV to both sides of the gasket? One guy says he puts RTV on and then tightens the bolts only finger tight, waits an hour and then torques the bolts to spec.
Wondering too about the trans temp sending gauge port on the side. Does that accept Isspro Temp sending units?
Anyone ever done a Goerend Trans Pan?
Thanks for any ideas/ tips
Edited by JAG1
