Electric Assist Turbo anyone?
- Replies 9
- Views 3.8k
CUMMINSDIESELPWR 2 posts
dieselautopower 1 post
kzimmer 1 post
backcountrymountains 1 post
My first question.... what are they doing about the efficiency of losing ~20% of power each way? It is bound to be a brushless 3ph motor, owing to the 3 wires, which means thats an inverter box. Looks
Waste of money. Get this instead its only $30 on ebay! Seriously the electronic spool will help emissions and performance... essentially supercharging vehicle until exhaust ga
I know it all comes from rednecks, I remember friend of mine using a vacuum cleaner in his Chevy cavalier with 3.4l to get it go faster, it seemed to work at low rpm, all he needed was to add a turbo
Anyone else see this ?
What lag? @dieselautopower thoughts ?
From what I have seen Garrett has battery that is charged then discharged rapidly when the turbo needs help spooling up.
The coolest part is gathering energy from the turbo when not on boost. It will use the turbine as a generator to pump power back into the charging system.
https://www.garrettmotion.com/electric-hybrid/garrett-e-turbo/
Edited by Me78569
