FASS Sump Long Term Reliably
- Replies 9
- Views 4.4k
Dieselfuture 3 posts
dripley 2 posts
Mopar1973Man 1 post
015point9 1 post
Popular Days
I'll never do a sump again or spend $$ for a drawstraw. Bulk head fitting thru fuel module (and to plug drawstraw hole) 1/2 inch (diesel compatible pipe) down to where you suck fuel at. Put in a bo
I've run two different sumps, two different trucks. Never any leaks. Nothing can ever get close to it to rip it off, pretty much impossible, it's nowhere near the lowest point on the truck. Follow the
So I'm in the process of putting the truck back together and I ran into an issue. My fass draw straw is oof the old design, the new fittings I got for my fass don't work with the fass95. So I was going to take the inner during on the draw straw and use that on the fass pump. But that leaves my draw straw.
I was looking at getting the Fass Sump kit since it allows you to draw from the inside of the bowl. Being here in Jersey I don't foresee any issues with hitting brush, etc that could cause it it be knocked out. I refuse to use a sump that requires an external hose, as I'm currently dealing with an enlarged hole for my old draw straw.
If your wondering this is what it looks like.
https://www.xtremediesel.com/fass-stk-5500-fuel-sump-kit?gclid=EAIaIQobChMIyKPM25us5wIVGKSzCh20sQvFEAQYASABEgL2a_D_BwE
Anyone have any long term reports of it's reliability, if it leaks, etc. I'm currently on the fence with buying one, vs trying to find more fittings.
It would be nice to get back to putting 30 gallons of diesel in the truck lol
