- Replies 18
- Views 5.3k
dripley 4 posts
cs15dah 4 posts
Towrigdually 2 posts
Gregturley 2 posts
Chrysler ordered the axle from dana/spicer, but did their own engineering for the spindles bearings etc. When you follow the bill of materials for the rear ends through dana, you come to a
2 9/16” for the nut I remember right. Haven’t used my socket since I bought a conversion kit from torque king this way I didn’t have to use the factory nylon nut or that piece that holds it. but yo
Should be a dana 70
I watched a few vids on YouTube, then started to take my driver's side hub off. I pulled the axle out to discover my truck doesn't match the videos I've seen online.
The vids appear to have a lock ring and a dowel that keeps the somewhat large nut from turning. Mine seems to have a piece of the metal pulled up, to create two tabs, to block the hex nut from backing out.
I folded the two tabs down so I could take the nut off. But I can't seem to get any tools in there to turn the nut.
I don't recall the size, but with calipers I think I measured 66 mm for that nut.
Any ideas?
Edited by cs15dah
