Time for New Injectors, will 7x10s be ok with stock turbo
Minimum pop pressure is 293 bar and its time to replace. This is why I don't like aftermarket injectors typically set below 310 bar which is stock. Then aftermarket builders know they can improve flow but at a cost of shorter life span. Hence why I popped at 320 bar, idle is 7% after close 100k miles.
5 minutes ago, dave110 said:
The whole injector discussion drives me nuts.
You me and plenty others :lmao:i changed injectors 4 times in last 50k :ahhh:firs 3 times not knowing what I wanted the last one was hoping to get few hundred thousand out of, not sure if it'll happen.
1 minute ago, hdpwipmonkey said:
Pretty sure that's what the quad said.  I'll go double check once I get back home.
Make sure the engine is up to temp all assesories are off etc, at least that's how I did it. Guess outside temp may have something to do with that.
But did you not say that smaller injectors like my 50's should not be popped that high (320 bar)?
Edited by dave110
Where the heck ha e you been? Good to see you alive and well.
One thing l have gathered around here is no matter how much are trucks should   e alike the more different they seem to be.
Well ..... :rolleyes: life got a hold of me. Got busy at work, then was trying to change jobs little closer to home that didn't work maybe for the best. Wife ended up changing her jobs, not sure how that will turn out yet, she's not too happy at the moment but it is a paycheck. Her other job subbed her department out to India after all that talk a year ago at their annual get together they were bragging on how they care. It's all how you look at it I guess. Just seems that this year is so screwed up I had little time to respond or comment, I did try to keep up, but I'm probably a month behind on reading. Maybe I'll start catching up now that things are slowing down a bit. Good to know you are all here as well, I miss being a small part of it at times, good people here :thumb1: although we all have our belly buttons.
320 bar is where I'm at 100k miles roughly and 7 to 11% engine load at idle and perfect 800 RPM still (+/-5 RPM).
310 bar is what the stock injectors and RV275 are popped too.
305 bar is what most injectors builder like to use but at the cost of shorter longevity and more fuel flow.
300 bar is another I've seen on some injectors where looking for more fuel flow.
293 bar is the bottom limit set by Bosch for injectors.
280 bar typically you start hitting close to 0% engine load.
260 bar the idle will be close to 850 to 875 RPM and engine load of zero.
59 minutes ago, Dieselfuture said:
Well guess I'm not doing too bad then, hard to believe I'm still holding 320bar, unless there's something else is off that our trucks are different on to make your load like mine and rpm higher. @Mopar1973Man any idea as to why the difference. I remember when I got injectors installed they were around 12 load I want to say. Need to find my old posts and see, @JAG1 don't even think about changing my data :shifty:
Why? Did I do that to you before? I think you musta' had a bad dream about the 'mad moderator'
Thats the spirit!!!!
I miss derailing threads, sorry @hdpwipmonkey
Guess I'm kinda on topic talking about injectors and belly buttons.
@Mopar1973Man I'm confused now, if you still have 320 bar after 100k then you're doing awesome. I'm just not sure with all this data where I am at this point with my numbers. Figured I'd be around 300bar with my readings. I'm definitely getting confused now :think:
Being off topic was something we were very good at a while back. As long as we never lost sight of the topic we were pretty good at doing that though maybe all would not agree.
Just now, Mopar1973Man said:
Bosch stock and RV275 injectors are popped at 310 bar.
I had mine popped at 450, boy are they strong now. Cant keep the fuel in my lines.
I also have 3 more Blue Moons in the cooler. They pop but not sure of the pressure on them. One pop and they are done.
  • Haha 2
There we go. Last sentence on post #11. That's why I didn't go to 320 with my 50's. I trust you :wink:
Edited by dave110
25 minutes ago, hdpwipmonkey said:
We'll, took the truck back out and got it all warmed up and here are my numbers...
It's running good so I'm happy with it.  My numbers are better.  I think it was 930ish and load of 2-3 before the injectors were installed.
My engine load is about there but rpm is lower, so I'm still confused as to what math applys here
4 hours ago, Dieselfuture said:
No you didn't but I know you want too just to mess with me :poke:
I haven't been myself lately enough to do much around here. You know after a long haul of a hard job...... combined with other difficulties I'm taking a much needed vacation. Hopefully I'll be back with some wonderful thread hijacks all you guys can jump in on :thumb1:
Weird... Idle should be 800 RPM period. I wonder if the crank sensor on your truck is tired? Any other error codes? (If any).The only time this is above 800 RPM is when the APPS switches to THROTTLING then the idle software is shut off. This would cause the high idle.
I've got to ask again another weird one Stock APPS of Timbo's APPS? A bad APPS with the throttle line still grounded would make it idle high and low engine load. Could be a possible an error code for APPS possibly? This is common for someone that has tapered with the voltage. I would replace the APPS with a Timbo APPS but that's me.
